Parting Out
Parting out M5/M6 E60/E63 S85 engine
Parting out M5/M6 E60/E63 S85 engine with only 32k miles, let me know if you want pics of a specific part.
Cylinder head cover + profile Gasket ZYL. 1-5 Cylinder head cover + profile Gasket ZYL. 6-10 Control unit for ionic current AT-adjustment unit (VANOS) ZYL. 1-5 + solenoids AT-adjustment unit (VANOS) ZYL. 6-10 + solenoids Vanos Oil line + connecting line Vanos High-pressure pump + GEAR wheel + Sprocket PRESSURE ACCUMULATOR ( bracket available ) TIMING CHAIN Vanos gearbox, inlet Vanos gearbox, outlet Adjusting pulley with lever with Belt tensioner Connecting rod Connecting rod + piston and rings set of piston Rings Flywheel Clutch Vibration damper INLET CAMSHAFT CAMSHAFT EXHAUST Camshaft sensor Oil pump + suction pipe Oil sump pump Engine wiring harness Actuator Idle control device Fuel INJECTION TUBE + 10 fuel injectors Throttle Housing Assy + Hall sensor Thermostat housing + thermostat Connector ZYL. 1-5 Connector ZYL. 6-10 I also have the cylinder heads. I also have many hoses and lines, let me know what u need and Ill check. |
I need an intake Manifold adjuster I believe the part number is 11617544805
It is the box on the manifold on the drivers side Thank you |
I can't find it with the part# u gave me. if you can find it on realoem.com, send me the part# so i can check if I have it. Thanks
bump
Mass Air Flow?
you have the stock headers? how much for the set of 10 throttle bodys? price for each shipped to 94601
bump
ist of whats left:
Cylinder head cover + profile Gasket ZYL. 1-5 Cylinder head cover + profile Gasket ZYL. 6-10 Control unit for ionic current AT-adjustment unit (VANOS) ZYL. 1-5 + solenoids AT-adjustment unit (VANOS) ZYL. 6-10 + solenoids Vanos Oil line + connecting line PRESSURE ACCUMULATOR ( bracket available ) TIMING CHAIN Vanos gearbox, inlet Vanos gearbox, outlet Adjusting pulley with lever with Belt tensioner Connecting rod Connecting rod + piston and rings set of piston Rings Flywheel Clutch Vibration damper INLET CAMSHAFT CAMSHAFT EXHAUST Camshaft sensor Oil pump + suction pipe Engine wiring harness Fuel INJECTION TUBE + 10 fuel injectors Throttle Housing Assy + Hall sensor Thermostat housing + thermostat Connector ZYL. 1-5 Connector ZYL. 6-10 oil level sensor I also have the cylinder heads. I also have many hoses, vanos hoses and lines, |
bump
