Discussion pertaining to the flagship BMW here. |
#26
Class action lawsuit against BMW
I have the same problem with the transmission. I am hiring an attorney to file a class action lawsuite against BMW. If anyone would like to joint my class action please responde to this posting as soon as possible.
#27
Yeap, sign me up! Emailing you my info
#28
See my post regarding BMW and BMW dealer run arounds and what it ended up costing me. If you have had dealers give you the same run around, please let me know. Thank you. http://www.bimmerfest.com/forums/sho...d.php?t=673797
#29
#30
I bought my 2006 750i with 87,000 miles on it. After a few months, I was driving on the highway and it was bumper to bumper traffic. When I was stopping from 2nd to first gear I heard a bang and thought that someone hit me from the rear.
This was the first symptom and not the last. It was becoming more frequent as time went on. After doing much research in this forum, it was brought to my attention that it wasn't the transmission at all causing this violent bang. It was the GUIBO joint. Well, I finally had the time to drop the car off at my sons garage so that he could do a few things. The 2006 750 I has 116,000 miles. For about 3 months, I had to add coolant about once every 400 miles. So he put the car on the lift, pulled the exhaust and dropped the tranny. He replaced the coolant pan at the engine block, wasn't leaking, but since he was there, he replaced it. He had the tranny on the stand and he replaced the guibo joint. He said that that was worn to shreds and definetly was the cause of the loud bang. I checked in on him last night and he had the tube out of the valley pan. He said that normally you had to pull the tube out from the front but since he had the exhaust and tranny out he decided to go a different route. He pulled the tube out from the back towards the rear and replaced it with a new tube since the tube comes with the o-ring that caused the major coolant leak. Since he put the pipe in from the rear, he had to use some special adhesive to make sure the O-rings stay in place. Since the coolant only pushes about 15psi's he said that it would be fine. Today, I took the car for a test drive and popped it into S. Came out of first to second to third as smooth silk. I'm so happy that finely I have the ultimate driving machine. I give this website credit for turning me onto INPA, helping with every issue over the last year and half. Helping me with the infamous coolant leak, the guibo joint banging, the transmission reset pedal trick, the integrated control module, the yaw sensor, and any other issue that may come up. I'm also very fortunate to have a son that is a mechanic prodigy and a great mechanic. He did a great post on the infamous SAS issue, carbon build up in the heads, on the 2004 745I that we were able to clear. If anyone is looking for a great mechanic, just let me know. He is in Hyannis, MA.
2006 750 I Last edited by fratan; 02-24-2013 at 11:15 AM. Reason: adding info |
#31
The Guibo joint is designed to ABSORB shocks and vibrations from the driveline. It's intended purpose is to NOT coverup the BANG when you go from 2-1 gear. That's an internal transmission or torque converter problem that needs to be addressed. That new Guibo will be shredded like the old one pretty fast. As far as what you are saying about the pipe, that's a bit odd. It's a pressure fit pipe, the covers need to come off and the new O-ring is sandwiched in. You can do that or use the All German Auto (AGA) Repair kit which has better O-rings so it doesn't happen again. Also there isn't a coolant pan, just a little container that's made out of plastic. I think maybe he replaced the transmission pan? That's needed when it's leaking or when you are doing a fluid change as the filter is built into the pan.
2006 BMW 760Li - Alpine White w/ Creme-Beige 2004 Acura TL - Satin Silver/Quartz 2007 Acura MDX - Nimbus Grey/Taupe 2010 Honda Accord Basque Red/Beige |
#32
As far as that guibo goes funny you mention that because in another post i had suggested the hard down and up from 2-1 and 1-2 to be the adapter and sleeve (plug oring and gasket for mecha that keeps oil pressure) and i was told i was wrong and the guibo fixes that and if the gasket inside was blown the tranny wouldnt engage, blown yes maybe but leaking or on its way out it will lead to strange tranny behavior.. So can somebody else Chime in because i was always sure that hard shifting was a sign of that internal gasket going but maybe im out of my mind???
06 X5 3.0 Toledo Blue Metallic/Light Beige 2: Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades, +Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs, +White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround .. more updates to come PREVIOUS 2002 745i |
#33
#34
I was referring about the rear coolant cover on the back of the engine which is a known problem with the e65's. This wasn't leaking but we decided to replaced it anyways since we had access(proactive fix). I've been driving with the bang since 90,000 miles. That bang kept getting loader and more frequent and felt like a slip in the transmission. If you have the bang then there is no mistaking the noise. It's like someone has rear ended you. I had the car for 1 month and driving with a friend of mine on the highway when we came to a stop. I then accelerated and bam. My friend told the driver behind us to pull over and he said he didn't hit us. I believed him because it happened once before but not so hard.
There is no more slipping or banging since replacing the GUIBO joint. I never heard about the torque converter but will further research. My son is confident that the bang was caused from the guibo joint slipping from being worn out while the car was performing its stopping process. As far as I'm concerned, the problem is fixed and I'm styling with the smoothest ride out there. Now I can ride in S mode. BooYah!
2006 750 I Last edited by fratan; 02-24-2013 at 04:29 PM. Reason: more info about the bang |
#36
did you get anywhere with bmw corporate on this?
There is a recall campaign on it!
#38
Hey guys,
I'm not entirely sure if my problemm is the same as most of yours, (I'm new to cars) but here's what happened. I convinced my dad to go ahead and buy an 06 750li from an infinity dealership in ATL, it was a great deal for relatively low miles (80k). All was well until recently. The check engine light (the one that actually looks like an engine) has been on for a couple of months. I wrongly assumed that it had to do with the next service checkup. Anyways, just yesterday, as we were visiting a friend, the series of events took place: -drove up an inclined driveway, car fully loaded with people. -reversed on said driveway -tried to go back up and encountered a "transmission fault error" -I wasn't driving but it felt as if my dad were driving through mud. The car was rpm'ing highly and my dad parked it on level ground. The car seemed to want to stay in neutral or reverse. -upon restarting it a few minutes later it drove fine, but the check engine light is still on. Now idk if it's the same, but ever since the check engine light was on my dad's been complaining of jerky shifts and slow acceleration from stop. I don't know what's wrong but frankly I'm disappointed with the car, going as far to say that our 08 Altima is a better ride :/ I'm hoping it's as simple as an IVM fault. And I'm willing to try anything to fix it on my own. I would like my dad to actually enjoy his ride instead of being worried about it every time he hits the accelerator. Hope you guys can help. |
#39
The check engine light has nothing to do with the Transmission fault. The light should have been brought to the sellers attention within the 30 day period. The 2006 750i is a great car much better than an Altima but requires about $1000-1500 of servicing per year.
You need to find a reasonable mechanic that uses INPA or if your computer savvy load INPA into a laptop so you can read the check engine codes and reset them when necessary. When I bought my 2006 750 I, I had some recalls fix with the dealer which BMW paid for. Call BMW USA and they'll check your car to see if these recall campaigns were fix. One recall had to with the brakes. Also, put the key into the ignition without your foot on brake and push the button, once the button is pushed hold the gas pedal down for 25 seconds. This will reset the transmission. There is a good possiblility that you may have a transmission leak either in the Transmission sleeve or the bridge seal adapter between the mechatronics and tranny. These parts are cheap but you need a mechanic to put it up on a lift. Good luck and continue reading, this site is great and if I can do it anyone can.
2006 750 I |
