E34 (1989 - 1995)
Old 02-01-2013, 01:46 PM
e34_spangler's Avatar
e34_spangler e34_spangler is online now
e34 User
Mein Auto: bmw e34
Engine oil press light
I replaced my valve cover gasket yesterday and im getting this engine oil press light coming on and so I checked my oil level its got plenty of oil and the engine sounds great but this light scares me
Sent from my SCH-I535 using Bimmer App
1992 525i
beyren mesh wheels
Dinan Performance chip
Ka motors carbon intake
st suspension's springs
Old 02-01-2013, 02:05 PM
Monsignor's Avatar
BMW CCA Memeber #445389
Mein Auto: M50 Big Body
hmmm, VCG should have such an effect on the oil pressure.. coincidental? Did you torque it all down right? Its the gasket on properly? More details please..
1995 525iA 250k mi Shifted Performance E34
2006 325i/6 48k mi
2003 350Z 87k mi Shifted Performance 350Z
Garden State Euros
Old 02-01-2013, 02:35 PM
e34 User
Mein Auto: bmw e34
yeah i did just like in the Bentley manual said and theirs no sign of leaking and i have plenty of oil what else details where you looking for haha sorry don't know what to say the car has always run great for me, did all inspection and oil changes when i should.
1992 525i
beyren mesh wheels
Old 02-01-2013, 03:12 PM
e34 User
Mein Auto: bmw e34
Noticed its only coming on when car is almost at a stop and or at a stop
1992 525i
beyren mesh wheels
Old 02-01-2013, 03:35 PM
zfxpE34 zfxpE34 is offline
Mein Auto: 1995 BMW 540i E34
You did change the oil filter right?
Old 02-01-2013, 04:42 PM
e34 User
Mein Auto: bmw e34
unless my mechanic didn't i didn't should i? i saw on other forums for the m20 engine that depending on the oil i put in it can throw this light i did put some oil in cause of how low i was cause it was leaking cause of the gasket needing replaced
1992 525i
beyren mesh wheels
Old 02-01-2013, 06:44 PM
rv6rick rv6rick is offline
Mein Auto: BMW
Same thing happened to me and it was the dreaded notorious oil pump bolts that were coming loose and falling out. Dropped the pan and there were 4 bolts laying in there. Replaced the bolts and it was OK for a few thousand more miles then the light started coming on again at idle and would stay on longer and longer. I put a new oil pump in it and it took care of the problem.
Rick in Ohio
Old 02-01-2013, 06:56 PM
I had this issue, changed my oil filter, and bam no light.
Old 02-01-2013, 08:43 PM
e34 User
Mein Auto: bmw e34
Ill try the oil filter tomorrow probably! Thanks a lot guys!
1992 525i
beyren mesh wheels
Old 02-02-2013, 03:09 PM
e34 User
Mein Auto: bmw e34
Changed oil and oil filter no light but still have this annoying top end noise? Any ideas
1992 525i
beyren mesh wheels
Old 02-02-2013, 03:24 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is online now
Humble E34 lover
Mein Auto: 1992 525i
Could you shoot a vid of the engine noise and post it? It's terribly difficult to diagnose noises without being able to hear them.
I note that you have a 92, so that rules out Vanos which can typically cause a noisy engine.
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 02-02-2013, 04:14 PM
e34 User
Mein Auto: bmw e34
will post soon! thanks
1992 525i
beyren mesh wheels
Old 02-02-2013, 04:31 PM
e34 User
Mein Auto: bmw e34
here you go i hope this helps!
1992 525i
beyren mesh wheels
Old 02-02-2013, 05:05 PM
BMR_LVR's Avatar
Humble E34 lover
Hmm... nothing jumps out at me. It could be a worn/early failing hydraulic lifter. It doesn't really sound like what I've heard before with a loose spark plug, but it may be worth checking to ensure that all of yours are tight. It's easy to do and it's free. You could at least rule that out.
By they way, you da' man for taking the vid in the snow like that. Props.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 02-02-2013, 05:13 PM
e34 User
Mein Auto: bmw e34
its all about the BMW right?(: anything for it! haha but yeah ill check that! i mean i got this noise before when my old man put in regular and i stopped him right away haha and got the ultra back in and stopped the noise, so idk this one bottled me
1992 525i
beyren mesh wheels
Old 02-02-2013, 05:16 PM
BMR_LVR's Avatar
Humble E34 lover
FWIW, I run regular all the time (flame suit on) I have in all of my Bimmers with no problems, but not wanting to start a "regular vs. premium" war
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 02-02-2013, 05:21 PM
e34 User
Mein Auto: bmw e34
no no please not another war on here! haha and i only ultra cause im running a dinan performance chip and i've noticed big differences in the octane that is used
1992 525i
beyren mesh wheels
Old 02-02-2013, 06:47 PM
Microtesties Microtesties is offline
Unregistered User
Mein Auto: 1990 BMW 525i
I don't think this is an octane issue, doesn't quite have the knock I would expect from a misfire. Metallic tapping is what it sounds like to me, which would likely be cause by the valve-train. Though before you go tearing things apart check the simple things, I once had a similar sound that was caused by a small piece of plastic hitting the fan. Keep in mind though, if you did have low oil pressure before, and are now getting a ticking noise from the head a stuck hydraulic lifter fits the bill. Correct me if I'm wrong, but hydraulic lifters shrink/expand due to changes in oil pressure.
Also, can a valve cover gasket really have an effect on oil pressure? I've never heard that before...
Year: 1990
Model: 525i
Transmission: 5 speed
Mileage: 250k
Old 02-02-2013, 07:14 PM
e34 User
Mein Auto: bmw e34
yeah i figured it was just by luck that i got that light when i replaced my valve cover gasket ill take a closer look tom. hopefully it'll stop snowing haha
1992 525i
beyren mesh wheels
Old 02-02-2013, 07:40 PM
Unregistered User
Best of luck! When you first start it up tomorrow, try to see if the noise is a bit more pronounced then quiets down after a second. That could be a hint toward a valve-train problem.
Unfortunately, remember that lifters should be replaced as a set, rather than individually.
Year: 1990
Model: 525i
Mileage: 250k
Old 02-02-2013, 08:03 PM
Are you sure your oil was actually changed? I would suggest another change.
I had the exact noise, lifter was ticking. Changed oil again and gone.
I'm glad the filter rid you of that pesky light.
Old 02-02-2013, 08:14 PM
e34 User
Mein Auto: bmw e34
no i literly was just out in the garage today and put 7 quarts in so its changed haha i did some research and saw on other BMW forums guys are swearing by lucas additivies
1992 525i
beyren mesh wheels
Old 02-02-2013, 08:20 PM
Lucas has kept my little ford escort alive with 230k and still running like the day My dad bought her in 98
Old 02-02-2013, 08:21 PM
And you said the mechanic might not have changed the oil filter, so I was just curious.
The purolator filter at auto zone is garbage.
Old 02-02-2013, 08:29 PM
e34 User
Mein Auto: bmw e34
yeah i said that so thought i might as well do and oil change and filter haha sorry if i confused you
1992 525i
beyren mesh wheels
