Old 04-14-2010, 04:42 PM
domainman domainman is offline
Mein Auto: 323i
Question 2000 323i car shakes / Ignition Coil replacement questions
I have a Year 2000 323i with 130K Miles on it. The car usually shakes when I start it up in the mornings. Sometimes even during the day. Sometimes it shakes too much and I turn it off and restart it and then it behaves.
I have OBD scanner and most codes point towards bad ignition coils (A mechanic who changed cars thermostat last winter also said it needs new coils). I am thinking of replacing all 6. Spark plugs were already replaced recently. Here are the few questions I have.
1. Shall I go with Bremi or Bosch? ( Currently it has Bremi coils).
2. Shall I also replace Plug connectors or the old ones should be fine?
Old 04-15-2010, 04:19 PM
Mein Auto: 323i
Can anyone answer these please? I couldn't find clear answers from search.
I appreciate all the help!
Old 04-15-2010, 07:16 PM
chilltown_jc chilltown_jc is offline
Mein Auto: 2000 BMW 323CI
Hello, Funny you post this I just recently change my ignition coils on my 323CI. It's fairly easy to do... I would go with the Bremi. With the plugs it's your choice, the plugs do not go bad unless you realize the connectors are not looking to good. It wouldn't hurt changing.. I would check online for the ignition coils.
Old 04-16-2010, 07:29 AM
kunal_D's Avatar
kunal_D kunal_D is offline
Mein Auto: 2008 335i Sport 6MT
My car does this on occassion as well. In the morning it shakes slightly but is fine after about a min or so. A few times the car idled rough, but was good after a restart and it sometimes throws a cylinder 1 misfire code which never stays on for more than a day. I've learned to live with it, as it only does it once every 3 months or so. The coils are one of the few things that I have not changed. If you end up changing the coils, let us know if it worked for you.
08' E90 335i, Sport, Premium, Logic 7, 6-spd
01' 330i TiAG, ZSP, ZPP, ZCW, 5spd - R.I.P 04/12- gone but not forgotten.
Old 04-16-2010, 09:31 AM
Mein Auto: 323i
So I have decided to go with Bremi coils part # 12131748018. I should have these changed in a week or so. Will keep you guys updated.
Old 12-06-2010, 07:09 AM
denvermgb denvermgb is offline
Mein Auto: 2004 x3; 2002 325xit
My car did the same thing this AM, shaking on the start up, got codes: 1619, 1350, and 1343. I think when I replaced the plugs yesterday, I put the woven ground wires on each end, I think I attached them wrong, which is grounding out those two cylinders/coils. I looked at the Wiki and I did not see explicit instructions on how to attach these wires back, and I cannot remember exactly how they attached. Any photos or ideas would gbe appreciated.
Thanks in advance!
Old 12-06-2010, 07:12 AM
By the way, this is my '02 325 XIT.
Thanks!
Old 12-06-2010, 07:31 AM
P_T's Avatar
P_T P_T is offline
Supporting Member
Mein Auto: 323 Ci
I have a 2000 323 Ci and recently replaced some coils. The Ignition coil - Bremi - Factory is 12131748017 New Replacement # 12137599219 and it's made in China. I got two from Bosch coils # 12 13 1 703 228 from Pelican for $48 each and one from German Autoparts.com, which has the same coil for $49.61, and it worked also.
PT
___________________________________
Old 02-01-2013, 05:02 PM
Sherbach Sherbach is offline
Mein Auto: 325i
Hi, I'm a "chick" and that doesn't mean I shouldn't know how to fix my own car, but...well, I don't...I do know, however, when the proverbial crap is hitting the fan with my 2001 325i. I think I've spent more on this car in the past 3 years then what I paid for it....anyway, yesterday I had the front O2 sensor changed, (the other one was changed a few months ago, and I have a rear one because this is a California car). The scanner showed that was what was wrong, so the front O2 was changed, they said the back one looks fine. Today I start the car, (its been very cold here in Nashville) and I had that same rough idling, and I thought, this idiot mechanic didn't do the job! I have a cheap scanner myself, the codes that came up were PO1343 and 1350. I found a few answers on here as to what this is....misfiring on the ignition and the 5th gear? Once the car is warmed up it seems to drive fine. Then this afternoon the engine light came back on. So, my question is this...if it's spark plugs, are they easy to change on a BMW, and what is a coil pack...I keep reading about that...and how much is a job like this going to cost me...because I'm very close to getting rid of this car anyway....thanks for any help!
Old 02-01-2013, 05:42 PM
Originally Posted by Sherbach View Post
So, my question is this...if it's spark plugs, are they easy to change on a BMW, and what is a coil pack...!
Here's my pictorial M54 engine spark plug DIY (If I can do it, anyone can):
- One user's pictorial DIY for replacing the BMW M54 engine spark plugs (1)
The general consensus is coils don't go bad in sets so only one would normally need to be replaced at any particular time.
Here's how to test coils:
- How to test a BMW ignition coil (1) (2)
Old 02-02-2013, 08:08 AM
Mein Auto: 325i
Thanks!
Just one other question. Since this happened the morning after I'd brought my car home from the mechanic, after having the O2 sensor changed, could this issue have been caused by something they did? I was having the same issue, rough idling, shaking before warming up, hesitation, and the scanner said O2 was bad. Engine light came on. This time, engine light came on the next morning with the same symptoms, scanner gave me those codes. My son is an electrical "dude" and said he could probably change out the spark plugs, he's just never worked on a BMW before. Thanks for all your help!
Old 01-27-2014, 09:52 PM
spydey123 spydey123 is offline
Mein Auto: BMW 323ci
Hello I have a 323ci and when I initially start it idles a little rough...a sort of vibration sensation or shaking there and then it settles....however, I'm not to keen on having my Beemer shaking and rattling as such. I'm not sure if changing the spark plugs and ignition coils will fix the issue or not...the RPM needle moves up and down a little on a cold start and slowly settle down. Any thoughts are appreciated. Thanks
Old 01-27-2014, 10:06 PM
OscarN's Avatar
OscarN OscarN is offline
Mein Auto: 2000 328i
It's your Vanos.
GERMANY
TIAG 328I ZPP
DIYs: Vanos Oil line, Water Pump w/ Pulley, Radiator Hoses, Valve Cover Gasket, Belts, FSU/FSR, Rear Wheel Bearings, Sway Bar Links, NGK BKR6EQUP Spark Plugs, M1 0W-40 oil changes
Mods: V2.5 Angel Eyes
Old 02-18-2014, 12:00 AM
Alika808 Alika808 is offline
Mein Auto: X5/330/Range Rover HSE
I read some correspondence the brand Bremi coils have been recalled by BMW for factory defect. This might not fix your problem.
Old 02-18-2014, 02:53 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
You`re responding to somebody who`s been MIA for four years....read the dates....
The road goes ever onward....
(R.I.P. Jever)
