Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 02-02-2013, 12:41 AM
MigzE30 MigzE30 is offline
Mein Auto: 1985 BMW E30 325e
85 E30 z3 shifter
Hey everyone, so I recently bought an 85 325e, and just the other day my shifter stopped grabbing gears. Tomorrow I'm going to replace the shifter with a z3 shifter. I have a feeling this might not be the problem though... Does anyone have any ideas what else it might be if this new z3 shifter doesn't cure my problem ? Thanks guys.
Old 02-02-2013, 08:13 AM
downhiller's Avatar
livin large
not holding in gear, new tranny
grinding gears could be clutch, master or slave cylinder or bad syncros/new tranny
Old 02-02-2013, 08:46 AM
Well I'm about to replace the shifter in a little and if that's not the problem lll definitely check those Out, Thanks a lot.
Old 02-02-2013, 09:06 PM
downhiller's Avatar
livin large
easy thing to check, pop the trans oil filler cap out and check the color, if its normal color, itll probably be more towards the clutch. if its silver metallic, then the syncros are shot and either need new tranny or rebuild
Old 02-02-2013, 09:47 PM
Well today was a total failure.. I pulled out the shifter and tried installing the z3 shifter but the bushing wouldn't fit. I'm just going to end up lifting the car entirely so I can fix that and to check out the linkages, ill probably end up dropping the tranny to check it out too.. Ill make sure to check the filler cap also :/
Old 02-03-2013, 05:24 PM
BMWFatherFigure's Avatar
Old School
I must admit I had no idea why you thought a Z3 shifter would fit. You will have to dig deep for this one, both into the car and your pocket, sorry.
Current:
Previous:
Old 02-03-2013, 06:07 PM
I was told by many people it would fit and work as short shift.. the previous owner had installed (or at least tried to) a terrible shift linkage, the base was all loose and made my shifting sloppy. I'm just going to lift the car, and check/replace piece by piece.. Ohhhh well right ? At least I'm learning. Thanks guys..
Old 02-03-2013, 08:09 PM
downhiller's Avatar
livin large
i thought there was a kit you could buy that includes the z3 shifter and linkage but a new bushing kit that allows the conversion
i know its been talked about before a few times
Old 02-03-2013, 08:15 PM
downhiller's Avatar
livin large
http://www.bimmerfest.com/forums/sho...=short+shifter
http://store.uucmotorwerks.com/evo3-...t-ixxi-p2.aspx
there it is then of course a proper ssk
Old 02-03-2013, 08:31 PM
Perfect.. Ill definitely look into it some more !
Old 02-04-2013, 05:07 PM
garagistic's Avatar
garagistic garagistic is offline
Mein Auto: e30
Z3 shifter will work in your e30.
We run it on our own v8 m3. Great feel. Good price.
Here is the write up which includes the z3 shifter:
http://garagistic.com/index.php?page...arrier-bushing
Old 02-05-2013, 05:05 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Garagistic, what about offering something like that in kit form ?
The delrin bushes I can get from you, but the Z3 shifter etc. ? Not in Namibia
Since I am going to get your delrin bushes (and my shifter is not that sloppy yet), it would be great to convert it to a short shifter whilst at it
Don't take life too seriously; no one gets out alive !
Old 02-05-2013, 04:15 PM
garagistic's Avatar
Mein Auto: e30
We will look into it for you.
Btw we sent you a pm regarding a package deal.
Old 02-06-2013, 01:29 AM
Old School
OK so with a KIT OF PARTS a Z3 shifter fits. I have no prob with that. I just didn't think it would be a walk up start. It wasn't.
Current:
Previous:
Old 02-06-2013, 01:38 AM
garagistic's Avatar
Mein Auto: e30
Actually none of the parts in the writeup are used for the z3 shifter to work. They were only there because they are recommended to do while your there.
However, the only one that works is the Z3 1.9 shifter.
That z3 shifter is a bolt up short shifter in an E30. Its actually very common practice. Tried and true. We run it on our very own e30.
Some z4 shifters will also work. Even other z3 units, but they require bending of the selector rod in most cases.
http://m42club.com/writeups/shifter/...structions.pdf
Proof/more reading on this modification:
http://www.e30zone.net/e30zonewiki/i...ter_conversion
http://www.r3vlimited.com/board/showthread.php?t=199446
http://www.e30tech.com/forum/showthread.php?t=76659
http://m42club.com/forums/showthread.php?t=73
List goes on. A quick google search will work wonders.
Old 02-06-2013, 05:26 AM
Old School
OK, so I was nearly right and quite a bit wrong......
Current:
Previous:
Old 02-06-2013, 07:40 AM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
That sounds like my life.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 02-18-2013, 11:17 PM
NEW PROBLEM
So after all, the problem with my vague shifting was that on the shifter plate which holds the shift lever still, there were these 2 little blocks which allow the plate to bolt onto the transmission, these 2 little blocks where completely burnt through. I managed to buy a new shifter plate with a shifter and almost new bushings from my local autoban for only $20. I then bought the 2 little blocks for $7.50 ea. I installed the new plate ( pain in the ass ) and my shifter shifted perfectly. 1 problem though, it lets me change it into gear only when the engine is off. When I turn it on, it won't let me put it into any gear. Im guessing maybe some cables in my clutch are disconnected because my clutch feels a little loose, I felt it on my friends E30 and it was much more tough to step in. Or maybe slave or master cylinder ? Any one have an idea ? Thanks for looking
Old 02-19-2013, 12:13 AM
D'oh, You kids!
Why'd you post the exact same thing in two threads?
Quotes to live by:
BMW-CCA #441426
Old 02-19-2013, 01:49 AM
I accidentally posted it in this one first then thought it'd be better in the thread since you had spoken about removing the exhaust and heat plate
Old 02-19-2013, 05:45 PM
downhiller's Avatar
livin large
clutch isnt disengaging. see if you have any fluid in the master
