Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 01-29-2013, 09:33 AM
Jswett Jswett is offline
Mein Auto: 1995 740i (e38)
New battery, 740i still won't even try and start
I went and got a brand new diehard gold battery, exact replacement. Still nothing when I turn the key. Everything seems fine, all power functions working. Any ideas?
Old 01-29-2013, 04:25 PM
BMWFatherFigure's Avatar
Old School
Mein Auto: E23;E30;E38;R50;R55
No crank or no catch and run?
Current:
Previous:
Old 02-01-2013, 09:42 AM
QSilver7's Avatar
QSilver7 QSilver7 is online now
Could anyone have entered a CODE to immobilize the car without telling you? If this were true...you'd here a "gong" sound and the word CODE would appear in the MID.
Q {BMW CCA Member #191509}
(SOLD)
Old 02-02-2013, 09:05 AM
mikejenkins mikejenkins is offline
Mikej
Mein Auto: E38 750i, E34 540 Touring
Starting at the simple end, rather than technical, my 540 acts the fool sometime. At a filling station, during a MOT etc.
The problem was a connector behind the oil filter. Two wires running directly to the starter motor which emerge from the plastic covering ontop of the engine. In despair one day I cut the plugs off and joined the wires. It started!
So, my point is check for power at the starter (if you can find it down there somewhere), and work back. You might be lucky and find a bad connection.
It could be worse. We also have an E38 750. I had to swap the starter motor. Next time I might pull the engine first
Mike!
HTML code is Off
