F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11) |
| View Poll Results: HVAC fan button worn out/peeling what is the solution? | |||
| replace the button |
27 | 45.00% |
| take apart the whole console and replace the entire HVAC face plate |
33 | 55.00% |
| Voters: 60. You may not vote on this poll | |||
#176
I too have to say the HVAC system in my car is the best I've ever experienced; I almost always leave it on mid-range auto at 70 and the temperature and fan speed is always perfect! If cold out, I dial up to 84 and if hot out down to 60. I never shut off the compressor (it's double switched anyway, knowing when and when not to engage). I also have climate comfort glass.
#177
Moving the temperature manually to very hot or cold will not affect heating/cooling speed. The system will automatically utilize max cold or heat as needed (along with faster fan speeds) to bring the cabin to the set temperature as quickly as possible. The air temperature, and fan speed, will moderate automatically as the cabin reaches that point.
BMW-CCA Bimmerfest Supporting Member 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim Prior: 2008 335i 6MT Sedan | Black Sapphire/Terra Leather | Premium | Cold | CA | OEM Alarm Prior: 2005 330i 6MT | Black Sapphire/Sand Leather | Premium | Cold | UGO | OEM Alarm Last edited by markl53; 02-02-2013 at 10:43 AM. |
#178
Oh, and what does the "A" and "M" mean on the air-recycle button. I figure "Auto" and "Manual", but does it basically mean that it'll figure out for itself when to recycle the cabins air (as opposed to bringing in outside air) if you have it clicked to "A"? |
#180
-Corey |
#181
Pretty much. However, even in "no" mode (neither LED lit), the recirculation mode will be enabled "silently" if maximum cooling is needed. The "A" position is supposed to detect "noxious" fumes and the like, and turn on the recirc mode by itself.
BMW-CCA Bimmerfest Supporting Member 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim Prior: 2008 335i 6MT Sedan | Black Sapphire/Terra Leather | Premium | Cold | CA | OEM Alarm Prior: 2005 330i 6MT | Black Sapphire/Sand Leather | Premium | Cold | UGO | OEM Alarm |
#182
