The latest X3 brings some added style and some new features to the BMW SUV family. Talk about the new F25 now!
Old 01-31-2013, 11:04 AM
Hesham Hesham is offline
Mein Auto: Z4 (E89), X3 (F25)
2013 X3 - Heater Fan issue?
Did anyone have an issue with their heater fan not working in really cold temperature?
I have a 2013 X3 28i and on a really cold day (-30c) after starting my car, I turned on the cabin fan/heater and nothing happened. There was no air being blown into the car cabin no matter what temperature/fan speed setting I chose.
I ended up driving with no heat for a few minutes and once the car warmed up the fan started working normally again. I am suspecting it had to do with the very cold temperature we had that day and the fact that the car was parked outside overnight. Something may have frozen and prevented the fan from properly working!
It seems odd that this would happen on a new BMW, and I was wondering if anyone had a similar experience.
This only happened once (on that day when it was -30c) and the fan seems to work normally since.
Just wondering if I need to be worried about it?
Thanks.
Hesham.
Old 01-31-2013, 11:16 AM
noka noka is offline
Mein Auto: 2013 x35i M-Sport
-22F? Holy crap!
2013 x35i (Space Gray, MSport, CW/CWII, DHP, Premium, Premium Sound, Technology, BMW-Apps)
Retired:'09 C300 4Matic, '09 GTI, '06 750i, '05 C55, '04 R32, '03 M5, '02 GTI, 01 M5, '00 M-Coupe, '00 540i/6, '99 M3 Coupe, '98 M3 Coupe, '96 328i, ..., '86 4000CS Quattro, ... too many to list
Old 02-02-2013, 07:48 AM
csmcphail csmcphail is offline
2011 X3 35i
Mein Auto: 2011 X3 35i
Likely not an issue
Sensors look at ambient temperature. Fan won't activate until engine has warmed to the point where you can be spared a blast of icy air coming from vents.
Old 02-02-2013, 10:31 AM
slambmw slambmw is offline
Mein Auto: x3
I thought this was a problem, but check the dial beside each vent. You can actually change from cold to warm.
Old 02-02-2013, 10:47 AM
I thought that was only on the center vents.
Old 02-02-2013, 11:40 AM
Mein Auto: x3
Sorry, the centre front/rear vents only. Don't understand why you need to change the temperature when you can set the value on your centre console.
Not sure why they have this secondary temperature control for essentially the same purpose.
Old 02-02-2013, 11:49 AM
Some people like the cabin at a certain temp but prefer to have cooler air in the center, which is more likely to hit their face. I think it is kind of a 'safety' feature, as cooler air on your face is more likely to keep you awake if you are tired than warm air (but I could be wrong about that).
Old 02-02-2013, 06:28 PM
lbjgh's Avatar
lbjgh lbjgh is offline
Mein Auto: 2013 X3 M-Sport
The heat comes from the engine not the "heater". With the hvac on auto the fan will not blow cold air on you as per this post.
If you prefer -30c air blowing in your face you can drive with the window down with your head out the window or manually turn the fan on high before the engine warms up.
On those cold days I prefer not to have cold drafts but the steering wheel and heated seats cranked.
