Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 10-27-2012, 05:13 PM
bigSystems bigSystems is offline
Mein Auto: 2014 535i m-sport
Originally Posted by hd750Li View Post
I'm confused....What is exactly your navigation system - DVD or CD? In your post...you mentioned about obtaining CD...but then you said inserting to a DVD drive.
I hope you realize that those aren't exactly the same right?
Woops! :-)
Rear DVD Navigation System with proper DVD Disc. 2005 745li
2014 535i Current - MSport / Cold Weather Pkg / Driver Assistance Pkg / Premium Pkg / Multi-Contour Seats
2005 745Li - Sold
Old 10-27-2012, 05:59 PM
hd750Li's Avatar
hd750Li hd750Li is offline
Mein Auto: F02 750Li
Can you post a close-up picture of your DVD map disc - the label side?
Old 10-29-2012, 08:25 PM
customgsxr customgsxr is offline
Mein Auto: 05 745i
hey guys need some help.. I have a 05 745i NAVI02 i need the cd or dvd for it... i live in new england and right now it has a florida disk in it.. i checked and it does have the firmware 8.4.4
Old 10-30-2012, 05:01 PM
stuartjohn24 stuartjohn24 is offline
Mein Auto: BMW F01
Originally Posted by bigSystems View Post
Woops! :-)
Hi,
You should be using the 'High" DVD and not the 'Professional' I'm sure if you got it from the dealer then you have the right one.
The DVD/CD drives are a common failure, My NAVI01 died and I have since replaced it with a NAVI03.
You could try cleaning the lens, there is a fan in the NAV unit and it sucks loads of dust through the unit and alot gets deposited on the DVD/CD and lens itself, the disc in my NAVI01 had been in there 9 years! it was filthy!
Worth a try, I would keep an eye out for a replacement on ebay, I waited ages and got my NAVI03 for $250 which was pretty good!
Stuart
Old 02-02-2013, 12:50 PM
Whipplecharged Whipplecharged is offline
Mein Auto: 750Li
This applies only to US/Canada North America DVD Trunk-Loading Navigation Unit.
Disclaimer: Use this instruction at YOUR OWN RISK. I will not accept responsibility or liability for any damages to your car.
Here are a few improvements of the latest V32 firmware:
  • Reading dual layer DVDs
  • Loading voice files (male or female)
  • Fix: Navigation system is inoperative after arrival at destination
  • Fix: Incorrect address book
Step 1: Use the secret iDrive menu to determine what's your NAV version. Here's how:
  • Press the iDrive knob down for at least 10 seconds
  • Turn the knob 3 clicks clockwise
  • Turn the knob 3 clicks counterclockwise
  • Turn the knob 1 click clockwise
  • Turn the knob 1 click counterclockwise
  • Press the knob down firmly and release
  • Select "MOST Devices".
  • Scroll down and select "Navigation".
  • Scroll down a few pages until "Software Version" is displayed.
If version is 8.4.4 hex, then your system is NAVI02 which already had the latest firmware. Nothing needs to be done. Skip the rest.
If version is 9.x.x hex, but not 9.8.2 hex, then your system is NAVI03. Proceed to the next step.
E65, E66 NAVI01 (CD-drive): later version is 7.3.2 (not applicable here)
E65, E66 NAVI02 (DVD-drive): latest version is 8.4.4 hex
E65, E66 NAVI03 (DVD-drive): latest version is 9.8.2 hex
Step 2: Download the latest firmware V32
https://www.rapidshare.com/files/67875757/v32_usa.bin
https://www.rapidshare.com/files/1460690572/v32_usa.cue
https://www.rapidshare.com/files/3919791712/v32_usa.toc
Note that V32 is the latest released firmware from BMW.
BMW engineers stopped producing upgrade for E65/E66 after 03/2008.
There are many other versions V32.1 or V32.2 floating around on the net.
They are customized firmware, not the genuine BMW released firmware.
Alternatively, you can buy this firmware CD from the dealer.
This is the product number: P/N 01 59 0 141 891 index "y"
Step 3: Burn firmware (cue or bin) to a CD (or DVD)
You will need a single blank CD-R 700MB, not CD-RW.
Specified write speed 48x or 52x is not really important.
Verbatim and Memorex are reliable brands.
Other brands such as Maxell, Imation, TDK, or Sony are just fine.
For Windows users, you can use Nero Burning or freeware such are ImgBurn (http://www.imgburn.com/).
For Mac users, you can user Burn (http://burn-osx.sourceforge.net/Pages/English/home.html).
Burn at the lowest speed 1x to 4x if possible.
Always verify the image to make sure the burn was good.
Step 4: Install the firmware
This is the official instructions from BMW SI B65 21 02:
  • Insert the key fob into Ready state. Do not start the car.
  • Enter the navigation menu.
  • Remove the road map DVD.
  • Insert the navigation operating software CD V32 into the navigation unit.
  • Select "Yes" with the controller to install the software.
  • The software will then load in two steps, taking approximately 10-15 minutes.
  • Do not touch the iDrive while the software is loading.
  • When the installation is finished, the CD will be ejected. The message "Installation Successful, Remove Software loading CD and press OK" will appear. At this point, select "OK" with the controller.
  • The navigation system will then "Reinitialize".
  • When prompted, insert the road map DVD.
  • Make sure the battery is sufficiently charged. DO NOT SWITCH OFF THE IGNITION DURING UPDATE PROGRESS, otherwise you'll kill your navi.
The files aren't available anymore for downloading? Does anybody have them to email or repost?
Old 02-07-2013, 06:20 PM
wtr1906 wtr1906 is offline
ICE COLD
Mein Auto: 04 745i
Can we get a re-up please?
Old 02-07-2013, 11:30 PM
SuperSnoop's Avatar
SuperSnoop SuperSnoop is offline
Mein Auto: 2007 760Li
The link I posted is still live.
Old 02-08-2013, 05:54 AM
hd750Li's Avatar
Use these:
http://netload.in/dateiJfH9jWQpv5/v32_usa.cue.htm
http://netload.in/dateizOdXDgd79o/v32_usa.toc.htm
http://netload.in/dateiUMfqTC7mzz/v32_usa.bin.htm
Old 03-08-2013, 01:18 PM
CUZ2BME CUZ2BME is offline
MASTER DEE
Send a message via AIM to CUZ2BME Send a message via Yahoo to CUZ2BME
Mein Auto: 06 BMW750i, 04 BMW745LI
Question will this process update the map or this will only update the Firmware if so what does the Firmware do?
Old 03-08-2013, 07:15 PM
hd750Li's Avatar
Think of it this way:
Your navigation system is a computer. Firmware is the operating system. The operating system won't change the pictures saved in the computer.
Old 03-09-2013, 08:02 AM
MASTER DEE
Ok I understand so how can I get and update DVD map disc? Can I download a copy and of North America or The USA
Old 03-09-2013, 11:01 AM
hd750Li's Avatar
eBay is the way to go.
Old 03-12-2013, 01:07 AM
tamir15 tamir15 is offline
Mein Auto: 2006 750i E65
hd750,
my sw version is 9.8.2 hex so do i need v32 firmware update or not?
Old 03-12-2013, 05:39 AM
hd750Li's Avatar
Originally Posted by tamir15 View Post
hd750,
No
Old 04-02-2013, 10:52 PM
rodneyd9 rodneyd9 is offline
Mein Auto: 2006 750LI
New member here I have a 2006 750LI and trying to update my Navigation system. (hd750Li) I have followed your instruction to a T I have downloaded the cue and bin files to a cd-r and a dvd-r. But after following the instruction and get to the point of putting the firmware disk in. Once inserted all my screen say's is please insert cd/dvd? Kind of at a lost here could you possible tell me where I'm going wrong here?
Old 04-03-2013, 05:30 AM
hd750Li's Avatar
Try to insert that CD/DVD to a laptop or desktop to see if it can be read. My guess is the burn did not write data successfully to the disk. Or the disk was bad!
Old 04-03-2013, 05:56 PM
Ok I think I see what I was doing wrong but we do need both files the cue and bin file correct?
Old 04-03-2013, 06:06 PM
Sorry I reread your instructions it was either or lol let you know if I done it right going to try to update the Navi now.
Old 04-03-2013, 06:07 PM
hd750Li's Avatar
If you use ImgBurn, you only need one file. However you will need to download both cue and bin. The burning software is smart enough to select the right one.
Old 04-03-2013, 06:09 PM
I used Roxio
Old 04-12-2013, 09:40 AM
See-5 See-5 is offline
Mein Auto: E66 750li
Hi
sorry but I'm confused..
mine is 9.8.2 hex
is this the latest or shall I upgrade ?
and if so which files shall I download from the three.
thank you
Old 04-12-2013, 04:26 PM
Nygel's Avatar
Nygel Nygel is offline
Mein Auto: BMW 750Li
you have the latest, good to go.
"If version is 8.4.4 hex, then your system is NAVI02 which already had the latest firmware. Nothing needs to be done. Skip the rest.
E65, E66 NAVI03 (DVD-drive): latest version is 9.8.2 hex"
Old 04-12-2013, 09:28 PM
b1gm1ke b1gm1ke is offline
Mein Auto: 2007 BMW 750Li
Question, I have a 2007 - 750Li with E66 NAVI03 that needs the v32 software update. I found a 2013 Eastern High version map on e-Bay. Will I need to update to v32 in order to use the new map DVD disc? And if so, in order to make the v32 software update Disc, do I simply download both files and burn both to the disc and just put it in the Navigation DVD drive? Finally, if you know, will I need some type of access code for the Map DVD disc from e-Bay or do I simply get the disk and use it? I know it is allot of information I'm asking but I really do appreciate it.
Old 04-13-2013, 08:19 AM
hd750Li's Avatar
Follow the instructions to know whether you need firmware update or not. Though update is optional. No, you don't need access code.
Old 04-13-2013, 08:38 AM
Thanks for the info hd750Li.
Sent from my SPH-L900 using Bimmer App
HTML code is Off
