Crankcase Vent Valves - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 02-02-2013, 03:09 PM
Nitrogen's Avatar
Nitrogen Nitrogen is offline
Mein Auto: BMW 650i Convertible
Remove the following covers.
Locate the cap and pry off cap with angled screw driver, be sure to get all the clips off
Remove the seal and spring as shown.
Compare parts old vs new to make sure you have the correct part also you can see where the defect is.
Insert new spring and seal. Also observe notch on valve cover make sure the vent cover notch aligns with that marking for proper install.
When replacing cap you should hear 6 clicks to confirm proper seating. Replace all the covers (it helps to put grease on the holes of the valve cover badges they insert much easier) clear all check engine lights using scan tool.
That's it your done! Happy speeding!!!
Sent Via iPhone using BimmerApp
Old 02-04-2013, 07:05 PM
All-Or-Nothing's Avatar
All-Or-Nothing All-Or-Nothing is offline
Woo Hoo FREE Donuts
Mein Auto: 2004 645Ci Convertible
I want to change mine just because this was such a good DIY......Thanks alot.
Old 02-04-2013, 10:46 PM
Nitrogen's Avatar
Haahahahahah Thanks my first one and I know it wont be my last!!!!
Old 02-05-2013, 08:30 AM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Freude am Fahren
Mein Auto: BMW E63 650i
Thank you for the DIY Nitrogen. At which mileage should I consider doing the CCV?
Once a 6'er, always a 6'er.
Old 02-05-2013, 08:42 AM
Nitrogen's Avatar
Thanks......Mine was prompted by a check engine light. So I don't really know but mine went out at 100k miles. I would say around that would be the target or a little sooner. Rubber only lasts for so long. As you can see in the picture how it was torn.
Old 02-05-2013, 08:51 AM
07 E63650i's Avatar
Freude am Fahren
I'm only at 57k right now, but I'll probably do it around 75k. I'm still amazed that your car made it up to 122k with only a few issues!
Old 02-06-2013, 03:39 PM
davewoolley davewoolley is offline
D Woolley
Mein Auto: 05-645 / 14 435I
Was there something going on with the car that made you do this?
Old 02-06-2013, 08:15 PM
Nitrogen's Avatar
Check engine light came on and the car was idling rough and surging at times.
Can't remember the exact code.
Old 02-07-2013, 03:52 AM
D Woolley
I don't know of any codes but mine does idle rough and haven't been able to locate problem.any particular place to get the parts?
Old 02-07-2013, 04:50 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
I replaced my CCV a couple months ago. I bought two CCV's based on the 645i CCV DIY also posted here. I returned one because I only found one CCV on my car which agrees with your DIY for the 650i.
So this was one of the changes made when they updated the N62 motor I guess from the 645i to the 650i (and 550i , 750i)? You may want to update your very excellent DIY to let folks know. Nice job on the post.
'07 650i Coupe - Black Sapphire Metallic
M6 bumpers, skirts & wheels
BMW M Cross Spoke Composite 101 Rims 20"
HUD, Comfort Access
Old 03-19-2013, 09:42 AM
Bk650's Avatar
Bk650 Bk650 is offline
Nerdy G
Send a message via AIM to Bk650
Mein Auto: CLS 550
Was your car smoking with the torn CCV? It was suggested i change mine cause im getting some smoke out of the tailpipe from idling too long
Greg A
650i on 22's Asanti, mtec v3 angel eyes, Custom exhaust...(retired)
2000 GS300 heavily modded(retired) gone but never forgotten
1998 LS400 Daily driver (retired)
2005 Range Rover HSE (family car) Lost in Divorce
Old 03-19-2013, 05:23 PM
07 E63650i's Avatar
Freude am Fahren
Yes, a worn CCV can cause poor idle and smoke.
Old 03-19-2013, 09:56 PM
Nitrogen's Avatar
Yes it might smoke at times, and have erratic idling and also serge. It's a cheap fix only about $25-30 each from the dealer if you hunt on the net you might find them cheaper.
Hope that helps!!!
Old 09-15-2014, 07:06 PM
usingleton usingleton is offline
Mein Auto: 2004 645 CI Convertible
Thank you, I bought two of these as well. Was quite surprised to find that I only had one CCV on the drivers side
04 BMW 645 Ci
Old 09-15-2014, 10:38 PM
Yorgi's Avatar
Yorgi Yorgi is offline
04 BMW 645 Ci
Take a look at tampamarks spark plug DIY, you can see there is a CCV on both sides of the 650i motor. You can see both on the CCVs on the 645Ci motor in brown370's Coolant Leak Repair DIY.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 09-25-2014, 05:21 AM
ccv inside the hose
Actually I figured out my issue. The indy shop that replaced my valve covers gave me the updated covers. With the update, the passenger side does not have ccv but the drivers side does. He didn't know why and after searching and searching for answers to the annoying whistling sound, I broke down and went to the stealer ship. They informed me first that I had the wrong cover. 10 minutes later, they returned and told me that I needed an updated hose. The ccv for the passenger side is actually in the house. Problem solved!!!
Old 09-27-2014, 03:03 PM
hcrash hcrash is offline
Mein Auto: BMW 645ci Convertible
I did mine coz mine was very rough and the engine management light was on...and its a new car...light gone doesn't jerk forward idling very even is more economical...5 min job...and it does have 2 one each side...just thought about sharing it))
