Old 02-03-2013, 01:24 AM
teklord69 teklord69 is offline
Mein Auto: 2001 330ci 5-Spd
Stereo and possible electrical problem solved!
For almost a year now my radio would make a popping noise on startup from one of the rear speakers. There are also times when the car suddenly loses electrical power out of nowhere. Not until the other day I decided to fade the radio to the rear that I realized the rear right speaker does not work. I thought i was a blown speaker but when I plug that speaker to the left rear wires it works. So i traced the wire and found this:
The wire was frayed and was sandwich in between the rear shock tower bolt. This must have happened when I installed new shocks a while back and I wasnt careful setting the speaker wire aside.
ID:	360515   Click image for larger version
Old 02-03-2013, 03:50 AM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
So that fixed the stereo problem, but it won't have anything to do with the car losing all power.
Have you checked to make sure that the battery cables at the battery and at the car body are tight?
2000 540/6 Slightly tweeked...everywhere
Old 02-03-2013, 11:08 AM
Thanks..Yeah the batt terminals are tight. I will have to check the ground connections later.
