Old 01-30-2013, 05:35 PM
cisco150 cisco150 is offline
Mein Auto: 02 745I
Originally Posted by SFbay View Post
You have rear cover plate leak!
Fan clutch is bad too, it activates once engine is 105+
If your engine running at 107+ it means fan clutch died long time ago bc its been working too much all the time.
Thanks bro ill order the clutch fan and I hvce it at indy for trans sleave and guibo- flex disc and center drive shaft bearing ill have hime test it to see if leaking at the plate
Old 01-30-2013, 11:45 PM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
Asia??? Hmm do I sound Asian??
Ha ha I'm no darker than you
If I were you I would do the rear plate for this money, bc you have no wheep hole leak, may be vp leak.
Keeping fingers crossed wont do anything, and thinking that rear plate for some miraculous reason is still normal after 10yr ??? It's no different from valley pan, same exact design and is prone to failure. M62 has a crossover pipe, which you can replace easy after intake removal. N62 sucks at this point!!!
Did you know they had e65 with straight 6 M54 and M57 in Europe??? Imagine problem free e65!!! V8, V12 is not very popular there and is expensive.
Sorry I can't understand this post, I think your asian accent is coming out in your typing?
Anyway, a quick way to test the valley pan/rear plate is pressure test the system, if theyre leaking you will see it right off the bat.
Old 02-01-2013, 07:15 PM
SFbay SFbay is offline
Account Under Review
Mein Auto: BMW 745i
Can't understand? May be you should consider some English lessons???
"Right off the bat" won't always work for these engines)
The goal is to get 105-103 on idling and tranny temp within specs
Old 02-01-2013, 07:27 PM
First_745Li's Avatar
First_745Li First_745Li is online now
Mein Auto: 2003 745Li
"My Engrish is no so good"..learn
Me sum Engrish lessons..lol
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 02-01-2013, 07:31 PM
So today I noticed 105 at the light but down to 101 when I pulled off..also in another thread I posted a stored fault of 8E111..which was explained in the thread by other members.. I wonder if I'm also in for the coolant pipe/valley pan/rear plate revamp.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 02-01-2013, 09:11 PM
Mein Auto: BMW 745i
If aux fan kicks in when idling, you're good.
In 40 days I'll get 95C tstats.
Old 02-03-2013, 12:06 PM
Mein Auto: BMW 745i
Just yesterday my friend drove his 750 2007 89k uphill and got coolant pipe leak!!! Horrible leak it's pouring water like crazy!!! He had bmw coolant, so it doesn't matter which coolant- it affects any car after 70k miles. But I told him its good you have coolant pipe vs rear plate
95C tstat will help a lot
Old 02-03-2013, 12:58 PM
dolfan13's Avatar
dolfan13 dolfan13 is offline
Mein Auto: 545i
So I went with a little more water in my coolant mix.About -20c mix which is roughly 45/55 . Never over 105c and goes down to 103c at idle.99c to 102c cruising.Maybe patch for now but I'm never going up to 50/50.
Old 02-03-2013, 02:56 PM
Mein Auto: Nothing
Thats what I've noticed, 50/50 is much hotter.
Old 02-03-2013, 08:06 PM
Mein Auto: BMW 745i
Did it go over 105 before?
Old 02-04-2013, 02:15 AM
dolfan13's Avatar
Mein Auto: 545i
Would bounce up to 107c with AC on only after few min idle.Not that now ever .
Old 02-04-2013, 12:14 PM
Would I assume its working if it's not climbing higher than 105? I'm sure my question has been answered in previous post somewhere in this thread ..... But what would be the easiest way to verify that the aux fan is kicking in?
Might be the longest 40 days one has had to wait...
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 02-04-2013, 07:32 PM
Mein Auto: BMW 745i
No, 105 is too much, it only stays there for few seconds until aux fan cools it down.
Old 02-06-2013, 10:34 AM
Ok thank you.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 02-06-2013, 01:45 PM
Mein Auto: BMW 745i
Update:
Did rear cover!!
Now it's all perfect
Temp doesn't go higher than 93C!!!!!
Aux kicks in at 93
Old 02-06-2013, 01:46 PM
Update:
Did rear cover!!
Aux kicks in at 93
Awesome! That's using the tstat you modified, right?
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 02-06-2013, 04:39 PM
Mein Auto: BMW 745i
Yep 95C
Car runs fast, just smoked small Harley the guy was staring at me like "wtf?". Idk may be Harley sportster is slow?? But he couldn't make from start even though he pushed really hard))
Old 02-06-2013, 06:51 PM
745iguy's Avatar
745iguy 745iguy is online now
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
thats good news thanks for keeping us posted.
Between the SAS cleaning kit and this tstat idk which i should be more excited about
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround, +Puddle Light Logo Projector
.. more updates to come
PREVIOUS 2002 745i
Old 02-06-2013, 07:05 PM
Mein Auto: BMW 745i
What's sas???
Btw all tests passed so it'll pass the smog easy
Old 02-06-2013, 07:21 PM
745iguy's Avatar
Secondary air system that aga kit is now available also
PREVIOUS 2002 745i
Old 02-06-2013, 07:26 PM
745iguy's Avatar
Hoping these next 500 orso dollars will be the leap of no more frequent leaks and issues after that it will be a total of 5k in things ive done myself recently did the alt bracket, replaced a linkage to the ride height sensor in the front, and inner tie rods and while i had it up i figured id give the seals around the headlamps another coat of silicone to be safe and outside cleaning
ID:	361110   Click image for larger version
PREVIOUS 2002 745i
Old 02-06-2013, 07:45 PM
Mein Auto: BMW 745i
Ha ha you don't need anything to buy:
I just removed those egr valves, poured a lot of carb cleaner with wd40, waited overnight, then bought 5$ wired thing to clean pipes in the kitchen, sticked it in, twisted etc,
Final and testing stage is to blow it with compressed air, just any rubber hose will work as adapter.
Tada and I got air from muffler.
No errors all checks out
How much they won't for such a "high tec" equipment???
Don't believe in their "high tec" dissolvers etc this how they make money.
Old 02-06-2013, 07:56 PM
745iguy's Avatar
did you get to this without removing intake manifold? if i can get to those valves without doing that and can still remove those valves with removing the bulk head and using chemicals and some kind of long wire tool i would do it. without the dme flash i have done both my sides are clogged (idk how badly, cant be too bad last time i knew the code would shut off and on, on its own) they want around 250ish iirc for that kit with the wire brushes and etc to put into that and they recommend using chemtool or some such liquid. if i can ill go buy the carb cleaner and try a wire of some sorts but the question is length, how strong is it etc. look at the thread about it to see pics of the kit itself.
PREVIOUS 2002 745i
Old 02-06-2013, 08:14 PM
Mein Auto: BMW 745i
Ha ha 250$??? Well it cost them 10-20$ to make this kit
Yes you can remove those valves, but you need some skills and patience. But!!! Once it's removed you gotta be really carefull not to brake that 80$ Y pipe bc it's brittle most of the times. Anyhow you remove 2 nuts from each head, move that valve, stick that brush wire and pour some nice solvents!!!
Done!!!
But, definitely much better with intake removed.
250$ saved don't worry it will work.
If you feel air from exhaust you're good
Btw how do you know if your Y pipe is intact??? Very common it just brakes, cracks, and you have a leak, so not necessary your ports are clogged.
I got that brush from orchards supply
9$ smth
Old 02-06-2013, 08:29 PM
745iguy's Avatar
I suppose i really just dont know at all. Guessing from that alt bracket its probably brittle.
That gasket was like plastic stuck inside the slot for it. had to heat it up and use a nice pick to get it out, then i had to clean it all up with a wire brush.
So my bet is my pipe that goes under the manifold to those valves are brittle also... Come to think of it the old Y pipe CCV hose cracked when i tried to remove them when i did my driver side VCG so i might as well just buy a new one lol
PREVIOUS 2002 745i
