Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11)
Old 02-03-2013, 07:08 AM
Sharbotcom Sharbotcom is offline
Mein Auto: F10 535xi MSport
Hooking up Battery Tender
Guys:
I've finally gotten a Battery Tender and topped up my battery charge (I was having a few low battery warnings). All seems good now since I did the overnight charge. I used the two battery posts under the hood and attched the charger using the allegator clips. My question is I want to attach the eye rings and leave the cable easily accessible through the grill so I can simply connect the battery tender and plug it in without having lift my hood etc. (I plan on plugging it in overnight once a month or as needed during the winter season). My question is which locations are the best to attach the eye ring connectors? Anyone done this or do you guys just use the allegator clips?
Thanks,
Bill
P.S. a picture of the locations would be really helpful
2011 535i xDrive, Dark Graphite Metallic, Veneto Beige Dakota Leather, M Sport Package, 316, 322, 3AG, 5AD, 5AG, 5DL, 609, 620, 655, 677, 6FL delivered Christmas Eve '10, Mods - quad tips, 20% tint, JB4.
Old 02-03-2013, 07:35 AM
alextremo alextremo is offline
Mein Auto: F10 550i
Alligator clips. I do mine about once per month as well and it's not that time consuming to open the hood and hook it up.
Old 02-03-2013, 12:13 PM
Quacker Quacker is offline
Mein Auto: 2012 535i xDrive
I did what you want to do. I used ring terminals right on the battery post you used.
I was careful when removing the nut on the hot side to not strike anything with the wrench (used an extension to elevate that wrench handle) and kept some sideways tension on the connection that is already there, to insure that the existing circuit was not interrupted. I did this to insure that there was no memory loss or reprogramming needed. I have no way of knowing if breaking the circuit would have caused such an issue, but better safe than...
I installed an inline fuse and led the wire out through my lower grille. This last part was not so easy so I used a piece of coat hanger wire fed in from the front of the vehicle. When I finally found a path that worked, I duct taped the battery wire to the coat hanger wire, and pulled it back out.
Good luck!
2012 535ix Space Gray, Cinnamon, SAT, Premium, Prem sound, Cold W., Sunshades, Gloss Black Grille, Gloss Black Side Markers, RE970AS 245/45/19 non-run flats that run very smooth + quiet and also correct the otherwise optimistic speedo
Old 02-03-2013, 06:42 PM
Chuck W.'s Avatar
Chuck W. Chuck W. is offline
Mein Auto: 12 BMW 535I MS Alpine Wht
I hard wired mine and ran the wires out of the bottom right air scoop. The wires push up into the scoop when not in use. You will need to add some length to reach though. The charging nuts come off to reveal studs that the rings go right over.
2012 BMW 535I 14K Miles
ED Pick Up on 12/03/2011; US Pick Up on 01/27/1012
Alpine White, M Sport, Blk Nappa, Cold Weather, Luxury Seating, Premium, Premium Sound, Tech, Sports Trans, Active Cruise, Heads-Up
Mods - Quad Exhaust Tips, HID Fog Lights, Clear Front Reflectors, M5 Spoiler, Calipers Painted Black, 12.5 mm Rear Wheel Spacers, 5% Tint Rear - 35% Tint Front - 50% Tint Windshield
Coding by itschase (Chase)
Next; ED of 2014 M4
Old 02-04-2013, 08:07 AM
Thanks guys. The first semi-warm day I'll pop the charging bolts and run the cables.
