Old 02-03-2013, 08:41 PM
Kevin Halbleib Kevin Halbleib is offline
Mein Auto: 740il
740il sunroof will not open
I have a 1995 740il with a Sunroof that will start to open and then stop.
Any suggestions?
Old 02-04-2013, 04:55 AM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
Try initializing it. Press the sunroof button up and hold it there. It will move to a position and pause-keeping pressing the button during this pause and it will set off again. Just keep that button pressed until it stops a second time - IIRC that will be in the closed position. It should now operate normally.
If this doesn't work, repeat, but press/hold the butoon towards the rear of the car. Both methods can work
Old 02-04-2013, 08:42 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Ditto chrisn7...if there's no broken mechanisms in the rails/tracks...then try reinitializing the roof panel...see the directions in the far right column under "power loss or malfunction":
Q {BMW CCA Member #191509}
(SOLD)
Old 02-04-2013, 09:19 AM
Mein Auto: 740il
I will try.
Thanks,
Kevin
Old 02-05-2013, 06:51 PM
Mein Auto: 740il
Tried to reset. No change. Cannot figure out how to manually do it.
Old 02-06-2013, 05:50 AM
BMWFatherFigure's Avatar
Old School
You could have debris caught up in the cables. It happened to me - some idiot with a loosing Lotto ticket. Needed the stealer to get it out.
Current:
E38 Parts Car
Previous:
Old 02-06-2013, 05:55 AM
Mein Auto: 740il
How do I get to these cables?
Old 02-07-2013, 01:14 PM
QSilver7's Avatar
You can manually open the sunroof using the "Z" shaped tool in your trunks tool kit. Remove the sunroof access panel, and the tool's hex-shape slides into a matching hex opening in the sunroof's motor. See #11 (the tool) and #6 (the sunroof motor) in the diagram below:
Click this link for more sunroof diagrams: http://bmwmobiletradition-onlinecom....30&hg=54&fg=05
(sunroof tool)
(SOLD)
Old 02-07-2013, 03:05 PM
Mein Auto: 740il
I will give it a try.
Thanks,
Kevin
Old 02-10-2013, 10:28 PM
Old School
I'd use the stealer - they break it - their problem. (ok mine was under warranty at that time)
Current:
E38 Parts Car
Previous:
Old 02-11-2013, 06:11 AM
Mein Auto: 740il
IT worked. Went back and forth back and forth, got easier everytime.
Now the electronics are working.
Thanks!
