The X5 SAV Forum
Old 02-03-2013, 03:04 PM
kzhlin kzhlin is offline
Mein Auto: BMW X5
How to replace low beam headlights?
Hey guys,
One of my low beams lights stopped working and I ordered this new set: http://www.hidextra.com/h7/5000k/
How do I install it? I read that I just need to remove the 3 screws around the round housing? Do I have to remove the whole headlight unit prior to installation or will a small screwdriver be able to remove the screws?
Thanks,
Kevin
Old 02-03-2013, 05:24 PM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
If prior to facelift model. 3 screws removes the round cover. Remove the "U" shaped clip and that allows the rubber bellows to slip up the HT cable. Then there is a bulb retained to twist to get the bulb out. PROBLEM: The X5 does not use H7 Xenon bulbs unless you retro fitted the xenon lights.
Sure would help if you were to tell us what year and model you are driving and anything else you might think would help us to help you.
GL.
Old 02-03-2013, 06:21 PM
Mein Auto: BMW X5
I'm driving a 2003 BMW X5 3.0i
Did I order the wrong bulbs? I did not "retro fit" or do any modifications.
How would I remove the 3 screws? The space is tight (especially for the screw on the bottom). Will I just have to use a small screwdriver?
Thanks!
Old 02-04-2013, 06:26 AM
Zulu95's Avatar
It is tight but it can be done in situ. The OEM Xenons use D2S/D2R bulbs.
Old 02-04-2013, 08:09 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Help us help you better by creating a signature that contains your model/model year/build date (or add it to your info that appears to the upper right).
There are multiple e53 models, engines, transmissions, headlights (halogen & HID) that occurred during the production from the 2000-2006 model year. By having this info permanent in your posts...there isn't a lag in responses/replies waiting for more details. Sometimes diagrams & part nbrs & other info may need to be looked up before replying to your post...and by having NO information at all...can make forum members not answer or respond to your posts due to lack of information.
Again, help us help you better by clicking the USER CP link at the top of the page and create a signature that contains info about your X5. If not, just remember to post model info (as you came back to do in post # 3 above).
Q {BMW CCA Member #191509}
(SOLD)
Old 02-04-2013, 02:29 PM
Mein Auto: BMW X5
Thanks guys! QSilver7, thanks for the advice. I updated my signature.
My X5 came with Xenon lights, and "hidextra.com" told me that me replacement bulb is the H7.
Did I order the wrong bulb?
Thank you!
2011 E92 335i
2003 E53 X5 3.0i
Old 02-05-2013, 09:29 AM
tmvE39/E53/Z32's Avatar
Mein Auto: Dinan //M5, Dinan 4.8iS,
You did and you can blame it on "hidextra.com" too
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
Old 02-05-2013, 02:51 PM
Mein Auto: BMW X5
Last question(s) hopefully:
1. Do I buy D2S or D2R bulbs?
2. Which are the best bulbs (brands? models?)? Closest to OEM quality or better? I heard Phillips was good.
3. What temperature (4300k, 5000k, etc.) matches the OEM bulb?
Thanks guys!
2011 E92 335i
2003 E53 X5 3.0i
Old 02-10-2013, 12:01 AM
Mein Auto: BMW X5
Where can I get a screwdriver small enough to remove the bottom screw on the round housing? I tried multiple screwdrivers, and none are able to remove the bottom screw from the driver's side.
2011 E92 335i
2003 E53 X5 3.0i
Old 02-10-2013, 06:46 AM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
At SEARS
http://www.sears.com/shc/s/p_10153_1...=31-77990142-2
Old 03-30-2013, 10:32 AM
Jimxw Jimxw is offline
Mein Auto: BMW330i
How to replace low beam xenon HID bulbs 2006 BMW 330i http://youtu.be/v-irmBq9OLg
search on youtube:
My car is a 2006 330i Sedan with HID lights. The left side low beam light was dead after 7 years since I bought the car. Dealer was asking for $200+ for just checking what was going wrong. I decided to do the replacement myself. So I bought the exactly same HID bulb from amazon which cost me $35, and I used a coin (a quarter) as the only tool to finish the job. Cool? Please keep in mind that you take your own responsibility if you try doing this yourself.
