Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 02-04-2013, 10:30 PM
E30Betsy E30Betsy is offline
Mein Auto: red 325ic
Rear Cabrio Window Regulator
Hi! I'm trying to remove the rear driver's side window regulator (and window since it's attached) in my '91 325i cabrio. My Bentley manual says to undo two bolts at the top and then the whole thing should lift out. No such luck. I undid the bolts and the window-regulator is not budging. Is there some other hidden bolt holding the thing in that the Bentley manual missed?
325ic, diy, rear window, window regulator
