Old 04-24-2009, 05:41 AM
doncoggs doncoggs is offline
Mein Auto: BMW Z4 2003
Z4 CD Player...Clicking noise?
G'day everyone, I have this annoying clicking sounds that occurs once the engine has been switched off, it continues for about 10 seconds on every occasion? Can anyone tell me how to fix the problem...thanks
Old 04-24-2009, 06:31 AM
jragan's Avatar
jragan jragan is offline
Mein Auto: 07 Imola Red/Black MCoupe
Does the same clicking also occur if you open the driver's door after the car's been sitting a while? If so, then it's normal and doesn't need "fixing".
His: E86 ///M Coupe: Pics Track Pics Vids
Hers: 997-1 C4S: Pics
Old 04-24-2009, 07:09 PM
Yeah as the door is opened as well...but why does it make that noise, i no its not much, just kind of annoying, that all...cheers mate
Old 08-29-2009, 12:57 AM
kjbrazil kjbrazil is offline
Mein Auto: 2005 525i
I've been having this same problem. It's incredibly annoying and would like to have it resolved. I just recently went under my extended warranty and I'm pretty sure these types of issues are not covered. Let me know if you found a fix.
Old 08-29-2009, 06:03 PM
jragan's Avatar
It's not a bug or an issue or a problem to fix. It's the car spinning the discs up to speed so they're "ready to go" when you turn the car on. It's a convenience FEATURE.
Old 08-29-2009, 06:37 PM
It is NOT a feature. It is an issue with the CD player. Yes, it's performing a normal check but it should not make that much noise (or any noise at all for that matter) when doing so. How would you describe something as "normal" when the entire time I've owned the car it has never done it and now suddenly it does? It's also not "normal" for a mid-size luxury sedan to make a loud disc spinning noise every time a door is opened.
Old 08-29-2009, 10:47 PM
Jermy1304 Jermy1304 is offline
Mein Auto: 2003 BMW Z4 3.0i
I have this issue that is very similar. When listening to the Cd Player with the car running I get a staticy click that occurs every 25 seconds or so. No idea what it is......sounds like a quiet static pop coming from under the dash
Old 11-19-2009, 01:47 PM
chargedZ chargedZ is offline
Mein Auto: 2003 Z4 3.0
This issue started for me about two weeks ago...and I agree this is NOT normal. Has anyone found a solution to this issue? Other than replacing the head unit that is...?!
Old 11-19-2009, 02:24 PM
So far no solution that I've come up with besides replacing it. I was thinking about trying to clean it with an automobile CD player cleaner. It could be possible that over time it's just gotten dirty inside which could cause the noise and the occasional trouble playing CDs. I've been thinking about this one: http://www.amazon.com/Dry-Automobile.../dp/B0002IEEUC. Even if it doesn't work I guess it only sets you back about $10.
Old 11-19-2009, 11:19 PM
I agree...it's worth trying to clean it. I am going to call the local dealer, see if they have run across this issue before. Although it's unlikely that they will have a solution besides replacing it. I also will ask my local BMW tuner, see what they think.
Old 11-20-2009, 11:12 AM
All sounds good. Let us know what the dealer/tuner says and I'll let you know how the cleaning method works out.
Old 11-21-2009, 01:00 PM
I haven't had a chance to make any calls yet...but I fear the worst at this point.
The clicking noise now stays for a couple minutes and it's freaking out when trying to receive or eject CD's...once I get the CD in and working...it works fine.
I know a good car stereo repair man locally, I might see if he has any ideas. Might be cheaper to have him fix it then replacing the HU.
Old 12-28-2011, 08:32 PM
pyronical pyronical is offline
Mein Auto: E92 335i M Sport
Sorry to necro bump this old thread, but I have the identical problem with my head unit. Wondering if anyone found a solution.
Old 02-05-2013, 04:19 AM
ST Nathan ST Nathan is offline
Mein Auto: 2003 Z4 3.0i
Pretty much exactly what this guy said.
Got the same issue with rapid clicking sounds coming from the head unit when a cd is in, upon opening door or turning off the car. Would be great if it's fixable without replacing the whole thing. It's been doing this for the 4 years or so that I've owned the car and hasn't gotten any worse, but it hasn't gotten any less annoying either.
