6 Series
Old 02-04-2013, 12:42 PM
mattymetzger mattymetzger is offline
Mein Auto: BMW 645ci
are my front shocks worn out?
I'm just in the process of installing some Eibach springs, after i had the original springs removed I was able to completely push in the shocks and they would not extend unless I pulled them out. Is it time for new shocks? If so, are Bilstein a good choice?
Old 02-04-2013, 03:18 PM
asiansensation7 asiansensation7 is offline
Mein Auto: M-Skateboard
Sounds like they're shot, shocks/struts should rebound on their own. Bilstein is a good brand of shocks for stock replacement. If I remember correctly, they can also valve them to your specifications if you know the exact spring rate of your Eibachs.
Old 02-04-2013, 03:58 PM
bigscore's Avatar
bigscore bigscore is offline
Mein Auto: 05 645ci
Bilstein Sport for your Eibach lowering springs.....
No car is quite like a BMW....
Old 02-04-2013, 07:25 PM
Yorgi's Avatar
Yorgi Yorgi is offline
The Bilstein Sports may be your only option. They go for about $700 at Turner Motorsport. Personally I like Koni better than Bilstein but they are both very good.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 02-05-2013, 05:58 AM
Thanks for the replies.
Ordered a set of Bilsteins, while I'm at it, I will replace all 4.
20" wheels 245/35 - 285/30, black grill, 10W white LED angel eyes, Eibach lowering springs on Bilstein shocks,
AC Schnitzer pedals, Sprint Booster, electronic exhaust cut-outs, red brake calipers (painted)
Old 02-06-2013, 08:23 PM
bigscore's Avatar
Mein Auto: 05 645ci
I dont think they make Koni's for the 6....
Wish they did though...
Old 02-06-2013, 11:52 PM
Yorgi's Avatar
I could not find any Koni's for the 6 after a quick search. I will look harder though if I ever need to replace my stock shocks.
mattymetzger, let us know how you like the Bilsteins vs stock.
'04 M3 - track
Old 02-10-2013, 05:19 AM
called Budds (BMW Dealer, Yorgi will know them) and when they got back to me they told me that it is normal for these shocks to not come back out if they are pushed in. Doesn't really make sense to me but then I couldn't find anything wrong with the way the car handled. It doesn't matter now because I heave Bilsteins ordered which should arrive on Tuesday. But now I'm thinking I should have gotten an adjustable coilover kit.
Old 02-10-2013, 09:46 PM
Yorgi's Avatar
I think coilovers are overkill on a 4,200lb GT car like the 6er. With the Dynamic Handling (variable stiffness anti-sways) the car is already ultra flat in the corners. If you wanted to slam the car then you need coilvers, and for that the KW V3 are the best ($2,700).
Springs plus Bilsteins should be a very nice improvement.
'04 M3 - track
