Old 02-05-2013, 10:51 AM
superfi77 superfi77 is offline
Mein Auto: Lexus
Oil change after break-in period?
hi all,
Just curious if anyone replaces the oil after break in period? I don't think the dealership would offer this?
Old 02-05-2013, 05:16 PM
Elk Elk is offline
Mein Auto: ~
If you choose to change the oil prior to the 15,000 miles recommended by BMW, you need to either do it yourself (exceedingly easy) or pay to have it done.
If you use the search function you will find many, many threads discussing oil.
Old 02-05-2013, 06:30 PM
WaxComb WaxComb is offline
Mein Auto: 2011 535i
It's also been said that BMW typically breaks the engine in at the factory. In that case an oil change would probably not be helpful.
Freude am Fahren
Old 02-05-2013, 06:58 PM
-=Hot|Ice=-'s Avatar
-=Hot|Ice=- -=Hot|Ice=- is offline
Been there, Done that.
Mein Auto: Does it matter?
Only for M Cars.
Originally Posted by CaptainAudio
In the words of one of Bimmerfest's greatest minds:"Been there, done that"
Originally Posted by boltjaM3s View Post
Half the fun of succeeding in life is fighting the fight and making it.
Old 02-05-2013, 07:45 PM
Rover Rover is offline
Mein Auto: 3 series
They don't break the engine in at the factory. It takes 500 to 1000 miles to do that.
An oil change at 500 to 1000 miles may not hurt....in that you may get some of the initial engine shavings out of the system.
Old 02-05-2013, 08:27 PM
Taeksoo Taeksoo is offline
Mein Auto: 2013 335i Sedan
I'm also interested in this topic. I got about 2,500 on my 335i sport and I'm thinking I'll pay for first one in spring.
I've read allot of threads on this and what I got out is.... There is no harm in doing it. But there COULD be harm if not done. I don't think anyone has any solid proof and mostly it's about what makes you feel better.
So, for me little money is worth it. Otherwise I'll wonder if I should have done it if something goes wrong later. BTW, I'm wanting to keep this for a long time. If you are not then don't.
Sent from my SCH-I535 using Bimmer App
Old 02-05-2013, 08:37 PM
Elk Elk is offline
Mein Auto: ~
I encourage you to do it yourself as this is the easiest oil change you will ever do. It's literally a ten minute process.
In addition to BMW labeled oil, the approved oils are:
Castrol Syntec European Formula SAE 0W-30
Mobil 1 SAE 0W-40
Pennzoil Platinum European Formula Ultra SAE 5W-30
Valvoline SynPower SAE 5W-30
Old 02-05-2013, 09:55 PM
jjcruiser's Avatar
jjcruiser jjcruiser is offline
Mein Auto: 328i
Just curious why you would say this. Is it easier than a later oil change, for example? Or do you just mean in an F30 car?
Old 02-05-2013, 11:00 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
I think he means in general.
The filter is under the hood, near the front of the engine, the oil plug is easily accessible under the engine, youll probably spend more time setting up the ramps than changing the oil
Sent from my GT-N7105 using Bimmer App
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Old 02-06-2013, 07:07 AM
Michael Schott Michael Schott is online now
Moderator
Mein Auto: 2017 VW GTI Sport MT
Welcome to 1980. BMW does do a run in on the cars at the factory. It's not a substitution for the real world break-in that BMW describes in the owner's manual but I doubt that with modern manufacturing techniques there are but a few shavings in the engine. Plus we are talking about very sophisticated engines with high tech synthetic oil. There is no need for a break in oil change in this day and age.
Old 02-06-2013, 10:38 AM
Elk Elk is offline
Mein Auto: ~
The filter is under the hood, near the front of the engine, the oil plug is easily accessible under the engine, youll probably spend more time setting up the ramps than changing the oil.
Exactly. The F30 is very maintenance friendly.
Old 02-06-2013, 10:43 AM
Elk Elk is offline
Mein Auto: ~
Originally Posted by Michael Schott View Post
Welcome to 1980.
Let's nip this in the bud, now and leave it with there are many who disagree with this position, and those that do agree.
This horse is so dead it has already completely decomposed.
Old 02-06-2013, 12:57 PM
Yobyot's Avatar
Yobyot Yobyot is offline
Mein Auto: F30
It may be "said" that BMW breaks-in the engine at the factory, but it wouldn't be true.
In 2005, I visited the plant in Munich where the N52s and the V-10 for the E60 M5 was built. The high-volume N52 was tested on a machine then installed in cars. The V-10 was hand-built and tested by hand.
When I picked up my F30 last July, I toured the factory again. The N20s and N55s were also being tested for a few minutes in an automated machine then assembled into cars.
Oil change discussions on BMW forums are like religions: everone's is different.
For my part, I can't see how it's good for an engine to go a year or 15K on the original lubricant. I had mine changed at 4K miles.
MY12 335i ZSL with a deep dive into the options list
Produced: 2012-06-22
ED: 2012-07-19; Arrived in Jersey City: 2012-08-23
Redelivered: 2012-09-12
Old 03-21-2013, 04:46 PM
search search is offline
Mein Auto: 328i
quick questions, i am gonna diy to change my oil at 75k mark, but what is the good interval to do the oil filter change and is it as easy as well?
Old 03-21-2013, 05:01 PM
Mein Auto: 328i
7.5k, my bad
Old 03-21-2013, 09:43 PM
That70sGAdawg's Avatar
That70sGAdawg That70sGAdawg is offline
on 5th Bimmer
Mein Auto: 2013 528i Dark Graphite
My new baby is getting one at 2500 miles...
Call me old school, but I've paid for others abuse with used BMW's.
Old 03-22-2013, 07:36 AM
spicytofu spicytofu is offline
Fungineer
Mein Auto: 2011 E92
I changed mine at 1500k, saw lots of silver shavings and shiny floating particles. Its always a good investment.
Ordered 4/20/2011 - Delivered 4/20/2011
Has a little bit of this, some of that - a happy camper.
Old 03-22-2013, 08:28 AM
finaloption finaloption is offline
Mein Auto: '13 f30 n26
hit 3500 miles today, so i will do an oil change this weekend using GC. from the DIY pics posted on f30driver, it looks very very easy
http://www.f30driver.com/bmw-f30-pho...20-Oil-Change/
edit: added link of diy
Old 03-22-2013, 12:28 PM
bmw_or_audi bmw_or_audi is offline
Mein Auto: Passat 1.8T MT
Wouldn't the filter pick up any particle that is big enough to see?
Old 03-22-2013, 12:30 PM
Btwy, Audi now does the first oil change at 5K, and then every 10K afterwards.
For the A4 at least, it has been claimed at various times that the factory oil is a little different, supposedly tailored for some sort of a break-in, and that changing it prematurely is not a good idea. But I have no idea whether that is true or not
