The X5 SAV Forum
Old 02-03-2013, 08:30 PM
Toopricey01 Toopricey01 is offline
Mein Auto: 325 xi
2005 x5 reading misfire
I have a 2005 x5 I have taken it to the BMW dealer and they still can't not fix. Check engine lights flas and at times it will not go over 5 mph, but if the codes are reset it will be fine for a day or two. Codes are reading misfire on 5 and 7 also multiple misfires and running to rich, can someone please help me out with this please. Have replaced plugs and coils and they supposedly did a smoke test and still nothing... thank you
Old 02-04-2013, 09:13 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Help us help you better...once again, the most important details about your "X5" is missing. Please consider creating a signature that has your model/model year/build date. The E53 X5 has multiple models/engines/transmissions/parts/etc that change during the production from the 2000-2006 model year.
If you have the 4.4 (N62) engine...do a search using "intermediate levers" as the search phrase...or do a google search using "bmw e53 x5 intermediate levers"...and see if your symptoms match this issue.
Q {BMW CCA Member #191509}
(SOLD)
Old 02-04-2013, 01:01 PM
If it is fine after you reset the SES light then you have a misfire in which after a while, the computer is shutting down the injector(s). The engine may have a "slight " misfire, but after x numbers of misfires has been registered on the computer the computer will shut down the injector in the cylinder that is misfiring so now you don't have a "slight" misfire, but a misfire all the time. A "Lean Condition" will be classified by the computer as a misfire even though the cylinder is firing.
Old 02-04-2013, 05:45 PM
sunny5280 sunny5280 is online now
Mein Auto: 2011 X5-M
Possibly the oil separator hoses? See this thread for details:
http://www.bimmerfest.com/forums/sho...=oil+separator
They're easy to check and an inexpensive fix if they're the problem.
Old 02-04-2013, 07:08 PM
How do you know that the car is running rich? What was the code for the rich condition?
Old 02-06-2013, 01:02 PM
DTANDJT DTANDJT is offline
Mein Auto: 2006 X5, 2005 Mini S
Did they check the spark sensor?
Old 02-06-2013, 03:10 PM
What's a "Spark Sensor"?
