Old 02-05-2013, 04:28 AM
jrblanks jrblanks is offline
Mein Auto: Z3
Z3 engine while idle surges
My Z3 when stopped seems to be surging and when the headlights are on they cut in and out when this happens. Any ideas? I just replaced the water pump and thermostat.
Thanks for the help.
Old 02-06-2013, 05:52 AM
aba4430 aba4430 is offline
Mein Auto: 1987 Subaru Brat
Simple thing to check is your gas tank cap seal. If the seal is worn out it will lead to surging during idle.
'87 Brat
Old 02-06-2013, 06:22 AM
Mein Auto: Z3
Okay, thanks. I will purchase a new gas cap today.
Old 02-06-2013, 06:32 AM
The cap will be expensive; the seal can be replaced separately (~$6).
'87 Brat
Old 02-06-2013, 06:34 AM
Mein Auto: Z3
Do you know if I can purchase the seal at a local part store like AutoZone or is it a item that has to be bought from BMW?
Old 02-06-2013, 06:44 AM
I recommend the local dealership. Should be an in-stock item. Make sure you have the OEM cap, if not the seal (OEM) might not be compatible.
'87 Brat
Old 02-06-2013, 07:45 AM
Mein Auto: Z3
Okay, thanks.
Old 02-06-2013, 02:14 PM
ashevillez3 ashevillez3 is offline
Mein Auto: 2000 Z3 2.8 convertible,
I'm having a similar issue but only at start up when cold. After car warms up surging goes way. My first thought is the car needs a robust tune up... plugs, fuel filter, air filter already changed. No codes showing up. Just thinking out load but have you tried pulling codes and is maintenance up to date?
