E34 (1989 - 1995)
Old 02-06-2013, 01:50 PM
FlynFish FlynFish is offline
Mein Auto: BMW 525iT
Just following up to see if all is still well? I have a similar issue so this may be a helpful way to a happy ending...
Old 02-06-2013, 05:34 PM
fryntyr fryntyr is offline
Mein Auto: 1991 BMW 525I
Yes, the CTS was the main problem. Ran excellent and picked up a several MPG. At least until someone hit and run it and totaled it out.
Bought it back from insurance to use the parts. Found a nice grey with black interior 91 525I non-runner for a great price to swap parts from the wrecked one and ended up only being the fuel pump.. HA!!!!!!
Runs and drives awesome. I did swap the bilstiens off the wrecked one and the newer wheels and tires. Very happy.
Now I have a great drive train and most the body and interior to use if I find another one.
Old 02-06-2013, 05:41 PM
samsonnyc samsonnyc is offline
Banned
Mein Auto: 525
Why did your car not run normally when you disconnected the cts during testing ? Since that was the problem ?
Was it because of all the other vacuum leaks ?
Old 03-12-2013, 02:39 AM
motorcitycobra motorcitycobra is offline
Mein Auto: M5 S38B36
CPS Crankshaft Position Sensor
I did not read all the posts above ... just stopping by and throwing in this information ...
Had this issue with engine sometimes stalls at idle myself - after several other tries I found out the pretty old CPS and/or itīs electric cable connetions have been the reason. The signalling is sensitive and a damaged cable shield may allow other eletrical things to interfere or disturb the signalling; or sometimes there are simply no signals arrive fromt he CPS. If so, the CPU does not know crankshaft = pistion position and no ignition impulse can be sent.
See the damage which leaded to poor signalling ...
