Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - E23 / E32 (1977 - 1994)
Old 06-19-2011, 09:45 AM
735i rusa 735i rusa is offline
Mein Auto: BMW 735i
85 735i - No spark on plugs
The car was running then died while idling on the freeway. It started again and then died while idling again a couple minutes later.
Upon examination there was no ignition spark. We replaced the cap, the coil, the rotor, a small relay that turns on and off the ECM, pulled the ECM and put it in another BMW of the same model and verified it was working but the car still did not have a spark.
We then unplugged and cleaned every connector we could find in the engine compartment. After this the car started. It was idling for 20 minutes and then died but restarted again. We turned it off and it would not restart. We unplugged and replugged in all the connectors again and it still would not start.
*A previous electrical problem was that the starter would not activate through the ignition switch so we installed a starter button directly to starter solenoid.
Can anyone give advice on what to try next? Thanks!
could it be the crankshaft sensor
Old 06-28-2011, 06:08 PM
Mein Auto: BMW 735i
it was the crank shaft sensor
problem fixed
Old 06-28-2011, 06:14 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
just saw the post and was going to say crank sensor, but it looks like you have got it sorted.
df
Old 01-01-2013, 07:35 PM
Fokyl Fokyl is offline
Mein Auto: Hyundai
Where is the crankshaft position sensor on the M30?
Old 02-06-2013, 06:26 PM
SFbay SFbay is offline
Account Under Review
Mein Auto: BMW 745i
Crankshaft sensor
