Old 02-06-2013, 02:06 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
Working on a spare tire solution
Those of you coming from the E9x platform are probably familiar with the spare I dug out of the ETK...
http://www.bimmerfest.com/forums/sho...d.php?t=297373
new car, new solution a much cheaper alternative. i gave my original kit to my brother when he got an E90.
1) bmw E60 spare tire rim- $60
1) kuhmo 135/90/17 tire - $30
1) harbor freight scissor jack - $20
1) 15mm spacer + 5 45mm lugs - $40
1) gorilla telescopic lug wrench -$20
$170 total
I already had some of the parts, so it was about 130 total
spacer is only needed for the front of the F30, the brakes are even larger than the E90 335i. I went with 15mm to be able to have a full extended lip spacer. i suspect a 5-10mm would work based on observed clearance, but the 5 would have cut down on hub lip length and the 10 would have needed an extender cap.
so far, i've tested the spacer with the E60 spare and tire, clears the front brakes and no clearance issues.
i picked the 135/90/17 as a) it is between my winter and summer tires in size (26.5 vs 26.8 and 26.0) and it was rather inexpensive.
next step is to get the tire mounted on the rim and to test the final config.
the jack, although inexpensive, looks alot more sturdy than the bmw kit jack (some reports of it failing due to the plastic screw block stripping out have been noted). i never had any issues with the E60 kit jack, but it does look a little flimsy
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Old 02-06-2013, 02:13 PM
otonimus otonimus is offline
Mein Auto: 2013 BMW 328i Sport Line
Looks good. Where are you getting the rim?
Old 02-06-2013, 02:19 PM
ordered it up from tischer bmw
list price is 75
Old 02-06-2013, 02:27 PM
boltjaM3s boltjaM3s is offline
Banned
Mein Auto: BMW M428i
I just use this. Takes up no space at all.
BJ
Old 02-06-2013, 03:07 PM
pony_trekker pony_trekker is offline
Mein Auto: 5
Runflats all the way.
Popped a flat in my hertz rental, no hertz truck for miles, had to change that bad boy and missed my flight. If the donut would have popped I would have drove that sh!t on rims.
Funny thing is it had an oil change window sticker. Car had 28k. Oil change sticker had a reminder that on 1/18/13 at 21k Hertz should have changed the oil.
Old 02-06-2013, 06:29 PM
Mark K Mark K is offline
Mein Auto: '17 GTI '16 981 CS
Right. I don't give two sh*ts about driving a rental on run flats. Fine with me. Will dump it in 3 days max.
Driving MY car on runflats? Not in a million years - I won't be dumping it after 3 days.
_
2017 Golf GTI |Silver over tartan cloth| MT| Base S, no options. Oh, wait! ... It does have a spare tire!
2016 981 Cayman S | 6-speed MT| Active suspension | Sport Exhaust System | Torque vectoring (with LSD) | Sport seats + | Sport design steering wheel
2013 VW Golf TDI [CONFISCATED]
2011 E92 335i 6MT ZSP ZCW (ED May 17th 2010) [SOLD]
