E34 (1989 - 1995)
Old 02-06-2013, 12:31 PM
M540FELLA's Avatar
M540FELLA M540FELLA is offline
Josh
Mein Auto: 95 540i m sport
E-brake?
Hi all,
I have a question about the emergency brake. Kinda dumb,if you pull your ebrake will your wheels lock up. Mine don't and I suspect I need to change the springs or something.
Old 02-06-2013, 12:36 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Originally Posted by M540FELLA View Post
Hi all,
Haven't tried it on my BMW, but I used to do it with my VW rabbit in my young stupid days. If I'm correct, I believe that the brake is actually just a parking brake and that is its actual intended function. You have to remember that your car is very heavy and it would take a lot of rear wheel braking force to lock up the wheels.
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 02-06-2013, 12:43 PM
cutter67 cutter67 is offline
Mein Auto: 530,m6,633
yes it should lock the wheels up. i would try adjusting it first. try the cable then at the shoes also
C:\Documents and Settings\mark\My Documents\bmw6 2 006.jpg my challenge car build http://www.bimmerfest.com/forums/sho...d.php?t=674904
Old 02-06-2013, 05:47 PM
BMWFatherFigure's Avatar
Old School
Mein Auto: E23;E30;E38;R50;R55
+1 on adjusting. Shoes first then cables. Also find a long down hill and use the e-brake to control speed - as per handbook. Don't go too wild. Then in N the wheels should lock.
Current:
Previous:
Old 02-06-2013, 11:06 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
of course, it wont lock the wheels if the car is in drive or is in gear and clutch engauged, depending on the cars setup. but in neutral for both, yes you should be able to lock the rear wheels
pull the hand brake on in a manual FWD car and thats how you can do stand stills in them, something that is MUCH harder in a RWD car
