Old 02-06-2013, 11:51 PM
SFbay SFbay is offline
Mein Auto: BMW 745i
Originally Posted by 745iguy View Post
I suppose i really just dont know at all. Guessing from that alt bracket its probably brittle.
That gasket was like plastic stuck inside the slot for it. had to heat it up and use a nice pick to get it out, then i had to clean it all up with a wire brush.
So my bet is my pipe that goes under the manifold to those valves are brittle also... Come to think of it the old Y pipe CCV hose cracked when i tried to remove them when i did my driver side VCG so i might as well just buy a new one lol
But you did coolant pipe job, right??
Why didn't you clean air passages at the same time??
Old 02-07-2013, 04:38 AM
dolfan13's Avatar
dolfan13 dolfan13 is online now
Mein Auto: 545i
SFbay you still going to sell us some 95c tstat man!
Old 02-07-2013, 05:43 AM
745iguy's Avatar
745iguy 745iguy is online now
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
I did not PO claims he did.
At 147k by now i would bet id have a serious prob by now
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround
.. more updates to come
PREVIOUS 2002 745i
Old 02-07-2013, 10:20 AM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
Ha ha 250$??? Well it cost them 10-20$ to make this kit
Yes you can remove those valves, but you need some skills and patience. But!!! Once it's removed you gotta be really carefull not to brake that 80$ Y pipe bc it's brittle most of the times. Anyhow you remove 2 nuts from each head, move that valve, stick that brush wire and pour some nice solvents!!!
Done!!!
But, definitely much better with intake removed.
250$ saved don't worry it will work.
If you feel air from exhaust you're good
Btw how do you know if your Y pipe is intact??? Very common it just brakes, cracks, and you have a leak, so not necessary your ports are clogged.
I got that brush from orchards supply
9$ smth
My pipe is broken, and I paid $60 for a new one.. I do have to take off the intake to replace that right?
Old 02-07-2013, 11:01 AM
Mein Auto: BMW 745i
Yep and once you're there replace valley pan and coolant pipe
Old 02-07-2013, 05:58 PM
Mein Auto: Nothing
Exactly what I'm going to do.. going to go with the AGA pipe in a week or two.. Will hope and pray my rear plate isn't bad but I am sure it will be..
And if it isn't it will shortly after..
Old 02-07-2013, 07:37 PM
Mein Auto: BMW 745i
Yep it's my story
Fixed leaking valley pan and it blew rear cover)
What a great car!!
I think either my foot is too heavy or my mpg is low?? 14-15mpg city;((( oh well it's 4,4 anyways
Old 02-07-2013, 07:40 PM
745iguy's Avatar
Jees i wish i get like 12 in my city. Ive just always thought crappy gas or the fact there is a stop sign or lights at every intersection.
PREVIOUS 2002 745i
Old 02-07-2013, 08:09 PM
Mein Auto: BMW 745i
Oh so it's okay I remember seeing 18-19mpg but I'm definitely driving it really hard.... Mine is LI btw.
Also replaced rubber boot from tb to maf, they have redesigned it, and I think it seals better, so it revs nicer
Old 02-08-2013, 08:33 AM
745iguy's Avatar
Hm ill replace it n see if it makes any diff. Ill be snowed in for a few days now tho
PREVIOUS 2002 745i
Old 02-08-2013, 08:47 AM
First_745Li's Avatar
First_745Li First_745Li is online now
Mein Auto: 2003 745Li
SF, got a part# for that boot?
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 02-08-2013, 11:12 AM
Mein Auto: BMW 745i
Just a boot, it has small plastic hose sticking out, mine was weak.
http://www.rmeuropean.com/ZoomImage....2_GEN_E095124A
Old 02-08-2013, 11:14 AM
oh that... ok thanks.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 02-14-2013, 02:35 PM
Mein Auto: Nothing
Hey SF, any news on the tstats? Also, how hard was it to drop your trans? I am wondering if I can do myself and replace that plate..
Old 02-14-2013, 07:32 PM
Mein Auto: BMW 745i
Yeah I need to contact them, but it hasn't been 2 months yet.
Before removing tranny check for any signs of leaks between tranny and engine.
Old 02-14-2013, 08:54 PM
Mein Auto: Nothing
I talked to AGA again and they told me that the rear plate hardly ever leaks. They said, they have seen about 2-3 in the last 200 E65's.. He said it's much more likely to be the cooling pipe/valley pan. Today my temp went up to 110c. But I was messing with the coolant mixture again, so I will have to go back to the last mixture.
Old 02-14-2013, 09:29 PM
Mein Auto: BMW 745i
110 is a lot!!!
And it's not summer yet.
Do the pipe and you'll thank me!
Once again you listen to aga folks who say if no leak no pipe problem, right??
But it is, remove your wp and dry the pipe inside and you'll see water coming out from the cooling pipe, which only means its coming from valley pan, bc it full and you cannot drain it lower than those water channels. This leak at high temp will greatly reduce water pressure- therefore valley pan return won't be able to open tstat.
Old 02-15-2013, 05:44 AM
dolfan13's Avatar
Mein Auto: 545i
Hey cmpcpro what mix were you using at 110c.Ive found 60 water 40 antifreeze is working great for me.Temps here have been down to single digits up to 70f and my engine temps have worked our well.Yep here in Ky we have wild climate changes sometimes day to day.I also took engine cover off after reading e46 guys do this a lot.Dosnt really bring coolant temps down but they say it lowered oil temps by 10 to 20.
Old 02-15-2013, 10:26 AM
Mein Auto: Nothing
110 is a lot!!!
The 110 only hits after about thirty minutes of bumper to bumper traffic and then stopping completely as soon as I move it goes away and it just started adding more coolant so will drop down my mixture. I agree I know as soon as I change my pipe this will most likely vanish.. Just spent $700 on the front struts so will have to wait a week or two for pipe but am going to put at top of my list. As for my mixture I am now about 50 50 again so below that has been better every time
Old 02-15-2013, 11:33 AM
Nygel's Avatar
Nygel Nygel is online now
Mein Auto: BMW 750Li
Has any member here tried the "Evans Coolant" and if so what has been there results, real world. Just asking cause it looks interesting.
thanks
Old 02-15-2013, 11:42 AM
Mein Auto: Nothing
thanks
Not yet, I have been wanting to try it but I don't know how to get ALL the water out of this system.. with the water cooled alternator, aux pump, etc.
Old 02-15-2013, 12:36 PM
745iguy's Avatar
Drain the block the rad and flush with the Evans prep. As long as you get under 15% iirc from their website, you should be good. Comes with test strips i believe; to see. Or you can empty some again after filling to dilute and refill but with Evans that will get costly.
PREVIOUS 2002 745i
Old 02-15-2013, 04:17 PM
Mein Auto: BMW 745i
And what?? Will it fix the leak???
Read about Evans crp and you'll find out that it keeps your engine hotter than regular coolant. No pressure, but cooling sucks
Old 02-15-2013, 06:15 PM
745iguy's Avatar
i wasnt suggesting it would fix the leak, was just explaining what to do is all if he wanted to try it....
PREVIOUS 2002 745i
Old 02-15-2013, 06:19 PM
745iguy's Avatar
It wont matter to me either way. I think my insurance is going to total my car by the way the adjuster was talking to me about the car... and if they dont Im going to sell it because i definitely dont want one of these after an accident going 60mph and spinning. Nemo got me
PREVIOUS 2002 745i
