DIY Complete X3 Cooling System Overhaul - Page 3 - Bimmerfest - BMW Forums
Old 03-16-2012, 09:05 PM
nrigroom nrigroom is offline
Mein Auto: E83
littleE46 - I owe you a note of thanks as well for the excellent write-up. I just used steps 3 through 5 of your instructions to change my drive belts. Took me about an hour. Got the T45 torx bit and a 16 mm socket which made the job a snap.
Your instructions are far better than even the BMW TIS instructions for this job. The latter are not as detailed, especially with regards to the bit and socket sizes.
122K miles, hope to take it to at least 300K miles. Next job is a valve cover gasket replacement.
Old 12-04-2012, 10:37 AM
awdrev awdrev is offline
Mein Auto: 2004 BMW X3 3.0 Auto Tran
Just a quick question:
Does the radiator also have the transmission fluid cooler built-in?
I believe I'm leaking tranny fluid into the radiator so I was thinking to replace it and hopefully that solves the issue.
Thanks again!
Old 12-05-2012, 06:21 AM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
Automatic transmission cooler is near the bottom of the expansion tank.
See this attached DIY.
http://www.bimmerfest.com/forums/sho...d.php?t=415259
Old 12-09-2012, 07:58 AM
chagrin chagrin is offline
Mein Auto: M3/X3/XI
Great write-up - I did a cooling system overhaul on our X3 this weekend and the photos were helpful. I found the source of an oil leak while disassembling parts in the engine bay - the notorious oil filter housing gasket. My recommendation to others: if you're going to the effort to do this job and you have an oil leak from that area, it's not much more work to replace it. It's an expensive job if you have an indy or dealer replace it ($400-800 is a typical range) due to the amount of labor hours required to access the part. Save yourself some money and replace this $5 part while you're in there and check your CCV/hoses as well.
___________________________________________
BMWs currently in the garage: VF570 E46 M3, E46 XI Touring, E83 X3 "M" retrofit
Old 12-09-2012, 04:55 PM
mlukas161's Avatar
I have the same OFHG leak in our x3. Just turned 138,000 miles so I wasn't surprised. Gonna tackle it within the next couple of weeks.
Old 12-09-2012, 06:25 PM
Mein Auto: M3/X3/XI
@mlukas161, here's a photo of the OFHG mating surface on the block after the oil filter housing was removed. In the left (before) photo you can see how much of a mess it was creating on the side of the engine. After I cleaned it up a bit, you can see things more clearly on the right. I was adding 1/2 liter of oil every 2k miles, so this was a significant leak.
Old 12-10-2012, 07:28 AM
mlukas161's Avatar
Wow, thanks for sharing that photograph chagrin. I'm pretty sure mine is gonna be a mess as well. I just ordered the gasket today and will see how it goes.
Old 01-21-2013, 07:00 AM
Time to revive this thread.
Question regarding belt tensioners:
For anyone who has done either a full cooling system overhaul or the OFHG job, how do the belt tensioners work? Specifically, I know they have a little cap and that they are a TORX bit set, but I am wondering how much to tighten them when the job is done? I think that loosening them will be very straight forward but is there a "click" or another way to know when to stop tightening or do I need a Torque Wrench, etc
EDIT:
AHH It seems I finally found the information from an earlier post
Water pump tensioner pulley 8mm 10.9 class = 34Nm using 45 torx socket
Deflection pulley 8mm 8.8 bolt = 24Nm using 45 torx socket
Old 01-21-2013, 08:49 PM
Mein Auto: 2004 X3 2.5i
Be prepared for a few possibilities on how you release pulley tension and how the tensioners are bolted to the block.
With my 2.5 M54 the main accessory tensioner is mechanical, with a 16mm. hex head bolt release, and attached to the block by two 13mm. hex head bolts.
(The pulley itself is bolted to the tensioner with a torx bolt - T45 I think.
BMW don't consider this pulley to be replaceable, but it can be done with a Dayco 89133 pulley - less than $20 from rockauto.)
You may have the later hydraulic tensioner if a previous owner got it replaced, which will have torx bolts I believe.
And the pulleys for those are readily replaceable.
I think those were the torque values you referenced.
I would imagine about the same torque if you were replacing a pulley on a mechanical tensioner.
Even among the mechanical tensioners there may be differences in cover caps and how the tension is released depending on who the supplier was - INA, Febi/Bilstein, etc.
As a general rule, if the tension doesn't release easily with a c/w turn then you are in the wrong place.
The AC tensioner on an M54 is more likely to be a hydraulic type I believe. Not sure though.
(The N52 engine went to a single accessory belt, maybe because having an electric water pump made that feasible.)
There are also differences in how the air duct over the radiator is attached depending on engine type and/or model year.
Maybe even differences between the 2.5 and 3.0 - mine uses about 8 torx screws while others use plastic pins I think.
Old 01-26-2013, 09:46 PM
silentbob silentbob is offline
Mein Auto: X3
+1, my 2004 was mechanical pulley for the drive belt, no Torx needed. For the A/C belt, I couldn't figure it out, so I just pushed on the tensioner by hand with a long screwdriver as a lever. It was enough to get the belt on and off.
Old 02-02-2013, 12:12 PM
Wow interesting... I always thought these belts had to be tighter than just human power. I'll keep that in mind for when I do it.
Old 02-07-2013, 01:34 PM
Ryan Sweeney Ryan Sweeney is offline
Mein Auto: 1998 528i
This write up is gonna save my butt tonight, for sure. Gotta replace the radiator and expansion tank on my Mom's X3.
1998 528i, 5-spd MT
2005 X3, 3.0i
2003 X5, 3.0i 5-spd MT
Old 07-10-2015, 05:38 AM
Boggie Boggie is offline
Boggie
Mein Auto: E83 M Sport auto
X3 cooling overhaul
Hi, What a great write up!
I'm not planning to go so far with my cooling system if I can help it, but I am trying to troubleshoot why my cooling fan is not working. Have you any suggestions what I should look at first? I have checked the fuse box in the glove compartment and the fuses are ok. The fluid levels are ok and I have just had the A?C serviced. It could be that the A/C has not been working for some months, as we only have a couple of weeks of summer in the UK when the temperature noses over 20 degrees!
whe I switch on the A/C the clutch on the pulley kicks in, and the air in the cabin is now colde, so I am thinking that there is a suspect sensor or relay in the fan control system which is not completing the electrical loop, but where to start?
My car is a July 2010 X3 2.0 litre Diesel Msport ( UK spec car) with 45,000 miles
Old 01-26-2016, 07:46 AM
nfemus1 nfemus1 is offline
Loving this thread.
Old 01-15-2017, 11:57 PM
Salzar Salzar is offline
Mein Auto: 04 X3
Originally Posted by littleE46 View Post
Thanks bud. For me in the "olden days" I would have always taken it to my mechanic. I didn't even change my own oil until I picked up an E46 Dec '09. Mostly because I had a mechanic that I really trusted. He did a great job and would never do any unnecessary work. When I got the Bimmer it was gonna cost more cause he would have to learn about BMWs to do the work. Besides parts for BMWs up here in Canada are outrageous.
I decided to try a few basic things myself, always ordering parts online from the US (Pelican Parts, Autohausuz...) using a Bentley manual (awesome) and DIYs on E46Fanatics. It's been so easy I'm determined to do everything I can possibly do myself. Last year I replaced the seals on my Vanos and it made such a difference in my 330ci, that was very satisfying.
For me its been far better to DIY rather than take it to a BMW Steelership where I feel like I need a shower afterwards to wash away the feeling of being raped.
Honestly I can't believe how easy these cars are to fix. The biggest reason I bought an X3 for the wife was because I new that I could work on the engine. I think BMW has done a great job for their mechanics to charge an arm and a leg for jobs that are really simple.
I agree! I am a 27 year old female who is on her tenth car and i actually care to do stuff myself now and to take care of my car because I love it. I have done the expansion tank and AT Thermostat, replaced the plastig gear inside the transfer case actuator because I was getting ABS Brake 4x4, am about to replace the belts and tensioner pullys tomorrow, few other things, and mostly by myself with the help of research, youtube, and maybe a hand or two from a family member who had the muscles to pop under for a second and loosen a bolt or hold a bar here or there. Im pretty happy with the car as I only paid $7,400, it had only 113k miles, and I get loads of compliments on it.
Old 01-16-2017, 06:49 AM
swampX3 swampX3 is offline
Mein Auto: bmw++many
great attitude
>we always tell our female trainees that they accomplish much more complex stuff in everyday life and not to be intimidated by working on vehicles no matter what the badge says or how much they cost
>watch and subscribe to fiftees youtubes for your M54 engine etc ....you will learn much
>invest in some power tools to give you leverage
>get yourself unto speed on the free rheingold bmw software for your car on the FEST and you will go up another level.....no heavy lifting......just a good mental exercise and very very rewarding with great cost savings and deeper understanding....review this link
http://www.bimmerfest.com/forums/sho...=1#post9972460
Old 01-16-2017, 01:41 PM
abscate abscate is offline
Mein Auto: 2006 BMW X3... VOLVO... V
Originally Posted by salzar View Post
i agree! I am a 27 year old female who is on her tenth car and i actually care to do stuff myself now and to take care of my car because i love it. I have done the expansion tank and at thermostat, replaced the plastig gear inside the transfer case actuator because i was getting abs brake 4x4, am about to replace the belts and tensioner pullys tomorrow, few other things, and mostly by myself with the help of research, youtube, and maybe a hand or two from a family member who had the muscles to pop under for a second and loosen a bolt or hold a bar here or there. Im pretty happy with the car as i only paid $7,400, it had only 113k miles, and i get loads of compliments on it.
ygg
