Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 02-03-2013, 06:21 PM
Jaysea7 Jaysea7 is offline
Mein Auto: 2011 M3 coupe
Question Oil Blowby from Filler Cap
I noticed some oil streaks around the oil filler cap. Is this normal?
Old 02-07-2013, 09:06 AM
TeaRex714's Avatar
TeaRex714 TeaRex714 is offline
Mein Auto: 2015 740Li
I just discovered Monday that mine has started doing that! It hasn't before now, so I don't think it's normal. A new cap is about $20; I might just replace mine in case it's the seal getting stiff or something.
2015 740Li Black Sapphire Metallic. Her name is Samantha
2008 M3 Sedan Alpine White / Fox Red - Sold at 219K miles
Old 02-07-2013, 12:08 PM
thekurgan's Avatar
thekurgan thekurgan is offline
Bad Lieutenant
Mein Auto: S62B50 Powered
This is a known issue. There was a part change on the cap after '10 I believe. One key thing is to keep the cap rubber ring clean as well as the mating surface. Make sure neither surface is dry, or the rubber will bunch up. You can also gently bend the fasteners to make a tighter seal.
Ilse
2002 E39 M5 / TiAg / Tubi Rumore / E60 SSK / Blanton 3.45:1 7 disc 40/100% locking diff / NCS Coding / Coby Alcantara / StrongStrut STB
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 02-07-2013, 03:33 PM
Thank you for the tip.
I'll have a look tonight.
Jaysea7
