Old 02-07-2013, 01:05 PM
tettes tettes is offline
Mein Auto: 2003 540i/6
Second coolant leak in 8 months
Guys, back in May I had a coolant leak in my 2003 540i that i thought was fixed. Parts replaced include:
Expansion tank
Thermostat
Fan clutch
Radiator hoses
I got the 'Check coolant level' warning light today, and I opened the hood and saw the dreaded white splatter.
My question is: Should the work that was done have prevented this from happening? Or is it possible that I didn't get everything overhauled, which lead to another leak?
I want to be fully informed when I go back to the shop so he doesn't try to sell me parts I don't need. If any of his parts failed, they are still under warranty.
Any ideas?
Thanks!
Old 02-07-2013, 01:37 PM
acoste's Avatar
acoste acoste is offline
Mein Auto: 2010 550i MT
Depends what's leaking now.
Just because you didn't replace something won't cause other parts to fail. But when removing and installing the coolant hoses from/onto plastic parts will stress that piece of old plastic. So it is possible to have a crack shortly after the overhaul but not months later.
Expansion tank failure is very common even if it was recently replaced. Search this site for the best source of exp tank.
Old 02-07-2013, 01:39 PM
Good info, thanks, acoste. I'll take the car into the shop tomorrow and see what they say.
Any other bits of knowledge that could help?
Thanks again!
Old 02-07-2013, 01:51 PM
crazy4trains's Avatar
crazy4trains crazy4trains is online now
Mein Auto: 2002 530i Sport
Water pump and radiator are other likely sources, among others too numerous to list. I recommend you look at cn90's cooling links and consider anything that has coolant flowing through it as a potential source.
http://www.bimmerfest.com/forums/sho...hlight=cooling
Good luck and please report back!!!
2002 530i
Old 02-07-2013, 03:45 PM
mbell666 mbell666 is offline
Mein Auto: e39 2002 540i6
If it was a Behr OEM Expansion tank, 8 months is right on time for failure. Easy check is, when fully cold, to stick your hand under the expansion tank and feel for coolant.
The Behr ones have been made in China very badly, I had two fail both ~8 months. The fix is have a genuine BMW one fitted, if your shop deals with a few 540i they will have had this issue already.
An e39 is like a beautiful wife, needs constant attention, lots of money, lets you down at the worse times but you’d never be without it.
Old 02-07-2013, 04:05 PM
champaign777's Avatar
every time i see "coolant leak" i run to check my
please no more posts like this ..
Old 02-07-2013, 04:09 PM
AnotherGeezer's Avatar
Entwicklung 39
Mein Auto: 2003 530i/5
Leakers.
Old 02-07-2013, 04:12 PM
SFbay SFbay is offline
Account Under Review
Mein Auto: BMW 745i
Don't forget 105C!!!!
Any small air in the system will increase pressure!!
Bleed it well
Old 02-07-2013, 04:28 PM
Nline6's Avatar
Nline6 Nline6 is offline
Slip slidin around town
Mein Auto: E36 M3
Suprised you didnt replace the radiator while you were replacing the other things. I bet there is a "micro" leak or crack in the radiator. All depends on where the white spots are coming from.
Old 02-07-2013, 05:24 PM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/Stick Blown
Your is not V8 why worry?
Old 02-25-2013, 09:04 PM
I'll find out if they used the Behr version tomorrow when I pick the car up. As it stands, they replaced the expansion tank under the warranty, thank goodness.
Will report back.
Old 02-26-2013, 01:48 AM
Burning2nd's Avatar
Burning2nd Burning2nd is offline
Under the lift arms
Mein Auto: E39 540, E36 328is, E83x3
I had a great run.. I got 15 month between my last leak and this one...
BUt my behr tank failed...
seeping right thur the side... I went with a BWM one this time... see if there's any better quality
These cars have a lot of plastic in the cooling systems... It happens... you have to stay on top of it... If you want a car that will run 100k with out problems... get a honda
Wish i had a warranty On my self... so i could contact (Me) and have my self replace my tank at no cost
Specializing In BMW, Audi, Mercedes Benz ,Volkswagen, Volvo
15486372<-----
Old 02-28-2013, 12:57 PM
i just picked up the car and the shop told me it originally used the behr tank, but this time used the oem tank.
burning - yeah, i did a lot of research on the e39 on this site before bought it, so i pretty much knew what i was getting myself into. i'll be curious to see how long yours lasts...
thanks, all!
Old 02-28-2013, 02:20 PM
Burning2nd's Avatar
Under the lift arms
Msg me so i have you in my inbox... and when this one... (the 2nd) fails ill let you know... Im installing it tomarrow
15486372<-----
Old 03-01-2013, 10:50 AM
Mein Auto: BMW 745i
You need lower temp tstat and it'll last like honda
Get 95C
Old 03-02-2013, 07:10 PM
Burning2nd's Avatar
Under the lift arms
https://sphotos-b.xx.fbcdn.net/hphot...29601310_n.jpg
Brass for the win
15486372<-----
