Old 12-16-2009, 04:31 AM
davemg davemg is offline
Mein Auto: 520
fuse 75 76
can someone please tell me where to find fuse 75 and 76 please for my 520
Old 12-16-2009, 05:12 AM
dalekressin's Avatar
dalekressin dalekressin is offline
Mein Auto: 2010 M3
Search the site as this has been discussed several times. I believe it can be found behind the glove box in various models. Sorry; not sure about yours.
Old 12-16-2009, 05:13 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
They are listed on the card that is in the glovebox on e39s imported to the USA. If they are not in that grouping..then they may be next to the GM and other electronic components on the firewall BEHIND the glovebox.
I'm not sure where Hull is located...but if your car is left hand drive....then it should be easy to find. If you are in a right hand drive car...the fuses up front are accessed differently (see your owners manual) and fuse 75/76 may be accessed from the engine bay. Again, I'm not sure how your car is set-up...and we didn't get the e39 520i here in the States.
Good luck
(fuses up front in the glovebox)
Q {BMW CCA Member #191509}
(SOLD)
Old 07-03-2010, 07:08 PM
rog5878 rog5878 is offline
Mein Auto: 540ia
Fuse 75/76 location on 2001 540i
What a trip.
Auxilary fan or heater fan just kept running when my wife and I picked up my mother to take her to dinner to a restaurant in Plains, Va. That was around 4 pm. When we got to the restaurant and turned off the car, the fan just kept running.
Unfortunately, it was July 3 and after 3 pm -- I couldn't reach my independent BMW service -- Fairfax Service Center. Went in to eat and when we came out, the fan was still running with the car off.
Was planning on heading to a movie but decided that I better take care of this problem first. Got back to my mother's house, checked Internet and bimmerfest and found out that the heater or auxiliary fan running uncontrollably during driving and staying on after turning the car off occurs on occasion. Also, found out where the fuses were in the glove box -- along with the fuse listing but no fuse 75 and 76 in glove box.
When I got home around 8:30 pm, checked Internet again and found out that some could never locate it. Others said that it was in the glove box.
Well, it is not in the glove box as noted here. Rather, close the glove box and behind the glove box is a plastic panel with a hole in it (the panel is directly behind the glove box) Pull it towards you. Takes a bit of a nudge.
Then there are all kinds of wires bound together and various connectors that if you pull out will probably incapacitate the car -- who knows. I had to contort myself to lay on my back and look up in the well on the passenger side.
Yes, the two large fuses -- 75 and 76 are in the middle of this mess, and yes, it is a tight fit (took forever to locate them with the little flash light; some say they are obvious but they weren't to me; of course, now I know exactly where to look). God knows how one gets them in. To get the fuses out, I had to nudge the first fuse on each side -- couple of sparks -- God knows what those shorts did -- and finally it came out -- the fan stopped. Before, I pulled the fuse out completely, I nudged it back in and the fan started up again. Then pulled the fuse all the way out and left the other fuse in.
Checked to see that the car started up OK -- it did -- no fan or air conditioning that blew out of course.
Will take it in on Tuesday after the holiday. Hopefully, it is just a resistor as some have found. Didn't want to leave it running all night and drain the battery or -- who knows -- cause a fire (tending to the melodramatic.
Also, didn't want to drive it to the service center and leave it -- after disconnecting the battery (didn't know if this was a good idea with the fan running; manual says don't disconnect battery if car is running.
Will definitely get BMW dealer or independent service center to show me where all the fuses are in my other car -- a 335i.
Old 07-03-2010, 09:14 PM
cn90 cn90 is offline
Originally Posted by rog5878 View Post
....Auxilary fan or heater fan just kept running when my wife and I picked up my mother to take her to dinner to a restaurant in Plains, Va. That was around 4 pm. When we got to the restaurant and turned off the car, the fan just kept running....
Check the diagram but in your car, the control of the fan is from the DME.
Very likely it is the temp sensor (located in the lower radiator hose) that is defective:
Temp Sensor is #12 here:
http://www.realoem.com/bmw/showparts...67&hg=11&fg=35
Old 07-04-2010, 05:03 AM
Mein Auto: 540ia
CN90,
Your diagnostic advice is greatly appreciated.
Old 07-04-2010, 06:37 AM
QSilver7's Avatar
What a trip.
Auxilary fan or heater fan just kept running when my wife and I picked up my mother ...
Which fan is running...the aux fan...or the heater blower? These are two different fans in two diffent locations...used for two different things?
The aux fan is the one in front of the radiator which helps facilitates cooling when engine coolant temps get to a specific degree...and when the AC is initiated etc. The heater blower controls the air velocity for the cabin/interior HVAC system. Which fan is running after the car is shut down?
BTW, when the manual says to not disconnect the battery while the car is running...that refers to the engine. When you shut the car off...but your heater blower fan or aux fan is still running...the car is off & the engine is not running...you can disconnect the battery at this point because the engine is NOT running.
(SOLD)
Old 07-04-2010, 06:48 AM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
QSilver7,
I read rog5878's post. It's his HVAC blower, no doubt the FSU.
Old 07-04-2010, 07:08 AM
Mein Auto: 2010 M3
Cn90
Very useful electrical diagram!
94 530i sold (That was difficult for me)
01 530i >144,500+ miles SOLD
06 330XI winter's especially fun drive (SOLD)
10 M3 Sedan (sweet)
13 Nissan GT-R Black Edition
14 Porsche Cayenne Platinum Diesel
15 Porsche GT3
16 Porsche GT4
BMWCCA 4215
Old 07-04-2010, 08:31 AM
CN90,
Oh, I just read QSilver post. May be your problem is the "FSR".
There is a DIY in the forum, very very very easy to do, don't pay the dealer for that.
Next time is happens, as a temporary measure, simply use a 10-mm wrench to disconnect the battery ground so it does not drain the battery, no need to lay on your back to pull Fuses 75/76.
Just re-connect thebattery ground when you go somewhere.
For the FSR, Use BMW OEM part only, the aftermarket parts have high failure rates, even brand new out of the box. So stick to BMW OEM.
Old 07-04-2010, 06:21 PM
Mein Auto: 540ia
Hvac
QSilver7 is correct. It is the heater blower.
After I thought about it, the fan that was blowing when the car was shut off was not near the radiator but was close to the front windshield.
Thanks for the advice re: battery.
Will check out DIY in forum.
Thanks again
Old 03-08-2011, 10:45 PM
Today, in another auxiliary fan related thread:
- Auxiliary fan stays on after shut off
The OP opined that a new car battery should be able to handle the auxiliary fan running overnight.
I have no idea what current the auxiliary fan uses; so I ask here what you think it uses?
For the purpose of that thread, I took half the value of the fuse #75, which, in QSilver7's post above, is 50 amps divided by 2 = 25 amps.
So, over a ten-hour period, if my assumption is anywhere near close, the auxiliary fan will cause the (new) battery to source 250 amp hours.
Does this seem like a reasonable calculation for the current draw of the E39 auxiliary fan that is constantly running?
(I do realize that motors draw current mostly in the starting phase, hence the dimming of the lights with the washing machine ... so maybe the unloaded current draw is vastly less?)
Old 09-01-2011, 01:41 PM
crazyb0064 crazyb0064 is offline
Send a message via AIM to crazyb0064 Send a message via MSN to crazyb0064 Send a message via Yahoo to crazyb0064
Mein Auto: 1997 528i
97 528i, my aux fan isnt kicking on either, i checked the fuse
and it wasnt blown, but notice the discoloration on the blades? might that be part of the problem? or should i statr trying to test the fan itself?
and on a different note, my fuse 76 wasnt right next to 75, is it supposed to be? or do i just not have it?
Old 09-02-2011, 06:08 AM
QSilver7's Avatar
I would test aux fan and see if when you jump the wires...does the fan turn on at high speed. If it does, then more than likely the inline resistor has failed. Most times this is the issue with a failed aux fan of your production build. (there are multiple aux fan set-ups...so you can't follow just any instructions you see...always look at the model year/build date of the DIY you're reading to make sure it applies to your situation).
Again, look thru the DIYs for the aux fan for e39s/e38s that were built BEFORE 9/98...and see how they dealt with the issues with their failed aux fans...and compare/test your aux fan for similarities.
(#8 is the resistor...that causes issues with the early aux fans)
(SOLD)
Old 09-02-2011, 06:30 AM
i will check it when i get home tonight, been looking into it the past couple days, just dont have much time between work and kids.
Old 09-25-2012, 06:12 PM
rcatank rcatank is offline
Mein Auto: 2003 BMW 530i E39
does any one know what 19 does? its on the charts, and there is a fuse... but no description...
Old 09-26-2012, 06:35 AM
My #19 (5A, light brown) fuse slot is empty:
- Where to find E39 fuse boxes (1)
Old 09-26-2012, 08:31 AM
QSilver7's Avatar
If you are referring to the chart below...F19 is a 5 amp fuse that is in-between the ignition switch and an unloader relay terminal 15. If the space is empty on your car...then it is not required. Here's a link to the online WDS that shows what is in-line with F19:
link to WDS Fuse 19: http://wds.spaghetticoder.org/en/svg...10.svg?m=e3902
(you may need to "click & hold" your cursor to move the diagram (at the link above) up/down/left/right to see everything...or you may have to use another keyboard short-cut to enlarge or decrease the diagram so that you can read it...check your VIEW pull down for keyboard short-cuts to ZOOM-IN or ZOOM-OUT)
K93 = terminal 15 relay location in trunk
(SOLD)
Old 09-26-2012, 10:55 AM
pleiades pleiades is offline
Mein Auto: '99 5-spd
Depending on the e39 model and year and market, these fuse 75 and 76 locations seem to move around a bit.
I Googled some pics. In some models, these fuses are located to the side of the connector housing with the general module etc (all tucked behind the glove box).
I include a couple shots [see attachments] of such an arrangement, from a right-hand drive car I believe.... http://forum.bmw5.co.uk/topic/29533-...the-tech-guys/
Also found an arrangement where the GM connector housing could be tilted downward for easier access to all that stuff, but lost the link. I haven't seen it again, maybe a figment of my imagination?
I went with the assumption I'd find the fuses to the side when looking for my setup and couldn't spot anything similar. I finally found the fuses in my car after looking at a photo in SleekBMW's auxiliary fan write-up here on the 'fest.
That's a single, square socket housing for two large fuses, unlike the individual socket arrangements shown in the attached photos. And yeah .... it's hard to get your hand up in there (be sure to disconnect the battery first), let alone finagle the fuses upward and out with your fingers. Be sure to put the right fuse back into the right slot, too. Easily interchangeable.....
ID:	343364   Click image for larger version
Old 02-07-2013, 08:42 PM
I just removed my yellow 40amp fuse F76 and it was right next to the red fuse 50 amp F75.
See gory details in this thread today:
- Detailed step by step diagnostic DIY ... dead battery ... parasitic current drain
See how to remove the diabolical GM3 connector hindering access to fuse F75 & F76:
- What is the secret to removing the diabolical connectors hindering access to Fuse 76
Old 08-22-2014, 06:58 PM
For the record, this was asked today ...
> E39 (1997 - 2003) > Picture & amperage & description of every single fuse & relay in the BMW E39
Originally Posted by gvelco View Post
can someone confirm that 2002 models have 50amp fuse for aux fan behind glove box?searched in my car and found nothing(will post pics in situ).bentley and others say that aux fan is secured with 50amp fuse.
Old 06-28-2015, 07:08 PM
mge_1 mge_1 is offline
Send a message via AIM to mge_1 Send a message via Yahoo to mge_1
I need to check #75 and #76 as well. Darn hope I find it on my 98 528i. Thanks for pics, I'll tackle this soon before I replace the blower motor.
Old 06-29-2015, 08:03 AM
See also:
- One users experience diagnosing parasitic dead battery overnight current drain (1) & what's the secret to removing FSU blower motor fuse F76 (1)
