E30 (1982 - 1993)
Old 01-13-2011, 10:21 AM
Nick Wilkinson Nick Wilkinson is offline
Mein Auto: 1988 325i
Question Clutch Pedal drops to floor. What's the problem?
I recently got into my car and the clutch pedal dropped to the floor. Their is absolutely no pressure in the system. There is fluid coming from somewhere, I can't really tell. I don't think the master cylinder or the slave are the faulty parts. Any ideas what else it could be?
The car is a 1988 BMW 325i.
I have not really done much maintenance to my car, except routine things like oil changes etc.
thanks
-Nick
Old 01-13-2011, 10:30 AM
Bking Bking is offline
Mein Auto: 10 528, 02 330i, 92 535i
On my 86 325es it was the master cylinder but i did not have a leak.
Is the leak under the dash, under the hood or under the car?
Is the reservoir filled up to the line?
Trace the leak back to the problem.
Old 01-13-2011, 10:33 AM
The leak is coming from somewhere under the car, around the transmission. It is not dripping enough to see where it is coming from. (The problem is I don't really know a whole lot about cars.) All I have is the Haynes manual.
Old 01-13-2011, 10:45 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
Why do you rule out the slave cylinder as being the problem? (It almost certainly IS the problem).
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 01-13-2011, 10:49 AM
Well, I guess I ruled it out because it didn't seem like fluid was leaking from there, however I could take a closer look. And, as I said before I am an amateur in the realm of vehicle maintenance.
Old 01-13-2011, 11:08 AM
Billwill Billwill is offline
Mein Auto: BMW E30 318i 1991
It is probably your master cylinder or slave cylinder.
Either one can pack up without any loss of fluid....the early E30s had a major problem with the master cylinder packing up, requiring a replacement of the master cylinder seals and a complete bleeding of the system....I had to do this a few times on my early E30s!
Old 01-13-2011, 11:56 AM
bimmeupscottiee's Avatar
bimmeupscottiee bimmeupscottiee is offline
Send a message via Yahoo to bimmeupscottiee
Mein Auto: 1987 325is
Its the salve cylinder. The fluid will leak out of the little drain hole on the bottom of the bell housing. Pull the slave and push the rod in, you will know if thats the problem as soon as you do this. It will possibly just fall out also. Same thing happened to me a month or so ago. Make sure you bleed the system up towards the res. Go buy an oil can from a parts store and a 3mm hose and pump the fluid up till you see no more bubbles in the res. and its bled. GL
"I knew a guy who bought a used car through a newspaper. Ten years later...bam...Herpes."
Old 01-13-2011, 04:52 PM
Bleeding the slave cylinder
I just replaced the slave cylinder on my e30 and I am now trying to bleed the air out. No matter how many times I pump the clutch peddle, no pressure is built. Does anyone know how many times I have to do this? Could there be another problem?
Old 01-13-2011, 05:01 PM
Try&CatchMy325's Avatar
Try&CatchMy325 Try&CatchMy325 is offline
E30's,Work,Eat,Sleep
Mein Auto: 1997 328i
It's your master Cylinder I had the same problem. Very simple to replace did it in my driveway. Don't worry about any leaks there are none I had the same thought. Just the cylinder isn't pushing fluid you're fine just replace it.
Old 01-13-2011, 07:32 PM
Read my post its right before yours it answers your question.
Old 01-14-2011, 08:42 PM
bimmerboy08's Avatar
bimmerboy08 bimmerboy08 is offline
Mein Auto: 1988 BMW 325i
just an fyi, when my master cylinder went the fluid was traveling down the line and outside the car, where it was dripping from where the hard line connects to the rubber line going to the slave cylinder.
The E30 is what all actual driving enthusiasts are after. It's an unpretentious machine, quietly capable of spectacular feats of handling. It's light, simple design is rugged enough to run against $400k rally cars, but on the street it' communicative chassis delights even the most disinterested driver. It really is one of the world's ultimate driving machines
Old 02-07-2013, 08:41 AM
BarranVilla BarranVilla is offline
Mein Auto: 325i BMW
What is the price range to repace the master and or slave cylinders on my 325i?
Old 02-07-2013, 08:35 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
thanks for using search button.
are you wanting to pay someone to do it as well or just to buy the parts and do it yourself? i recommend getting someone to do it, bleeding the clutch without the correct tools is a pain in the ass
E30 above Sold
Last updated 2nd January 2014
Old 02-07-2013, 09:26 PM
Titan_Omega Titan_Omega is offline
Mein Auto: 89 325iX and 97 328is
I had this issue and had to replace the master cylinder in the dark ......it was a pain in the butt. Good luck man if you have the time to do it, Do the research and do it its a interesting experience.
Old 02-07-2013, 11:28 PM
BMWFatherFigure's Avatar
Old School
I lost track. How many thread jumpers on this? To OP - change both the master and slave. Both have been used the same number of times.
Current:
E38 Parts Car
Previous:
Old 01-01-2014, 12:27 PM
CLBrooks CLBrooks is offline
Mein Auto: 1991 BMW 318is
How about OEM vs. aftermarket (Febi or Metelli) parts when it comes to slave/master cylinders? I've been told replacing small parts that are plastic with metal are the way to go.
Old 01-02-2014, 12:49 AM
This^^^^ Always replace slave and master at the same time.
If you replace a faulty master with a good new one then the slave gets pushed beyond its old working range and the seals ride on a ridge....failure of the slave cylinder soon follows.
I replaced my slave and master cylinders at the same time with cheap Pirate Parts from China...still works fine.
In SA we do not have all the options available in the USA to get good replacement parts other than OEM...which are very expensive.
Very easy to bleed the system...have a clear section of tubing placed into a glass jar with some clean fluid in the bottom. Have a helper pump the pedal a few times then leave it deppresed...at this time open and close the bleed valve on the slave cylinder.
Repeat the above while looking for new-clean fluid without bubbles to appear in the glass jar...make sure clutch/brake resevour is topped up at all times.
Old 01-07-2014, 05:36 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Billwill as you said correctly
I bring mine in through the local FEBI agent.
Masterparts is also starting to gear up on E30 parts.
But pray why does our local stelership have to be more expensive than same in München, Birmingham or San Francisco ?
Wonder how the OZ prices compare to the rest of the world ? Do we get punished for our good weather & empty beaches...
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 01-08-2014, 08:24 AM
D'oh, You Kids!
No, you're being punished for having the coolest E30 ever built, the 333, and not sharing.
Quotes to live by:
Old 01-11-2014, 12:56 AM
I think were punished by not getting the 4 cylinder M3 E30 ever!
Old 01-11-2014, 02:24 PM
very important to replace the master and slave at the same time. its possible to do without, but you will just create lots of pressure in the system because of the new parts (which is good) though it will exaggerate the wear of any parts already starting to give way. they are only rubber seals and they do deteriorate with both use and age/time
E30 above Sold
Old 07-27-2016, 05:22 AM
rbelton rbelton is offline
Mein Auto: E39
Agree with this 100%, replace the clutch master and slave at the same time. I replaced my clutch master first when it went bad, the slave cylinder failed a week later. Like others have mentioned, the new master will push strong pressure through the system which the 20+ year old slave cylinder is not ready for, and it will blow out. Here's a DIY for the clutch master:
manual transmission
