E36 (1991 - 1999)
Old 02-05-2013, 08:49 AM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: 1996 328i
Got my Howard Leight electronic ear muffs in. Found out that I can plug an iPod into these bad boys and jam out while shooting.
insert witty signature quote
Old 02-05-2013, 09:01 AM
jonesin's Avatar
jonesin jonesin is online now
The Canadian Prick.
Mein Auto: '96 328is Cosmos
http://www.amazon.com/MEElectronics-...=meelectronics
I've got a set of these for riding, work well for shooting too
“No cop born isn't a sucker for a finely-executed hispeed Controlled Drift all the way around one of those cloverleaf interchanges. Few people understand the psychology of a traffic cop. A normal speeder will panic and pull over to the side when he sees the big red light and start begging for mercy. This is wrong. Contemptuous to the cop-heart. When running along about a hundred and you find a redflashing CHPtracker on your trail you accelerate.”
- Hunter S. Thompson,
Old 02-05-2013, 09:03 AM
Kdoherty's Avatar
in ear protection is nice if you're wearing a helmet or baclava but ear bud style things hurt my inner ear so much that i suck it up for overhead muffs.
Old 02-05-2013, 09:11 AM
EnserioJose's Avatar
EnserioJose EnserioJose is online now
e36 aint noise pollution
Mein Auto: 1996 328is
How much ken? I've been looking for some electronic ears.
Originally Posted by E36 Phantom View Post
We've tried this before and it never has really worked, but good luck bro.
Old 02-05-2013, 09:16 AM
Kdoherty's Avatar
47 dollars with free shipping on Amazon
Old 02-08-2013, 07:31 AM
Ken have you had a chance to try the ears out yet? I am looking for your personal experience with the clipping technology versus compression. A review on Ingo said its worth the extra $20 to upgrade to a noise compression pair.
Also, what are peoples thoughts between piston and DI? The current supply pinch has let me go deeper into the subject. However, the more I research, the less clear it becomes. What I've basically gathered is it doesn't really matter as long as they're kept clean. (same with chrome-lining unless you're putting lots of rapid fire events together).
Old 02-08-2013, 08:10 AM
Kdoherty's Avatar
Okay lot's of things to cover here. I have tried the ears out, they are pretty awesome, trippy at first but once you find the sweet spot on the volume they're perfect. they'll amplify voices and ambient noise so that you can hear things that you need to but they'll immediately block out anything over 86db. it's funny because you don't think that they're working when you have them turned on but when you turn them off they work like normal compression muffs, and when you take them off it's like being assaulted with a megaphone. i have a set of howard leights that are regular muffs and then the impact sports. i say spend the extra money, totally worth it.
now as for piston vs. gas impingement. this is like the glock vs. 1911 story. they both work normal under normal operating conditions. if you're experienced with DI guns then you'll most likely know how and why they have malfunctions. I personally think that piston driven guns are really neat, but totally unnecessary. I'll find the link, but this company has a loaner AR15 called "filthy 14" and has had 10's of thousands of rounds through it without ever being cleaned, they just douche it in slip2000 and put it away. and the only malfunctions to date were a broken bolt key and ejector. piston is nice because it doesnt blow gas straight into the BCG, however, DI is the way they're designed and have been proven time and time again to be reliable, all these stories of dudes with malfunction ARs have these problems because they're shooting sh!tty fcuking WOLF ammo out of a hobby grade (read: DPMS) rifle that wasn't made for military abuse.
tl:dr don't buy gas piston if you don't want to be laughed at buy gun fighters and operators, save the money and buy a real AR
Old 02-08-2013, 08:18 AM
Kdoherty's Avatar
http://www.slip2000.com/blog/s-w-a-t...ine-filthy-14/
Old 02-08-2013, 09:43 AM
Muffs: what were your surroundings (other shooters firing many rounds)? When I say compression I mean the other electronic technology. The clipping models should be fine as long as its not a busy and crowded indoor range. They'd keep switching to passive mode and sound choppy. Here's the main review I saw: http://ingunowners.com/forums/ingo_r...ny_budget.html
Originally Posted by Kdoherty View Post
Absolutely amazing performance. I think you've settled it. For reference the models I was considering were sig m400, colt le69XX, sig 556, and ruger Sr556.
Old 02-08-2013, 10:00 AM
Kdoherty's Avatar
I've personally used a Colt 6940 for a couple 1000 rounds and can say that it's a very well put together machine.
i was the only person on the range, it was indoors so it was pretty echo prone in there, and the heater and circulation fans were on. I don't know why the person in that review hated the Leights so much but i can say that they are more than sufficient and if the clipping bothers you, just turn them off if there's lots of other shooters around you, under rapid fire indoors i was still able to pick up ambient noises between shots and reloads and it didn't take too long for the amplification to come back, they fit my head fine, i don't even have mine adjusted all the way down when i use them, their slim profile is really nice too. I'm not going to say they're the best, obviously there are better more expensive models with superior clipping algorithms but for under 50 bucks, you'd be dumb not to try these first.
Old 02-08-2013, 04:59 PM
PHARMDVIPER PHARMDVIPER is offline
auto>manual swap crew
Mein Auto: 2 black ones
I like the trijicons...I think I am going to order the sights for my PPQ
ammo is getting redonkulous....I have about 800 rounds of 9mm and would like to get another 500 but can't find any good deals lately
oh if anyone knows how hard it is to get these then you will be jelly
4 17rd's and 2 15rds......I saw 4 17rds go on gunbroker for $740 bucks...ignore my lounging pants
Old 02-08-2013, 05:06 PM
FenderBender's Avatar
FenderBender FenderBender is online now
Needs Boost
Mein Auto: Red Sled
Nice. I didnt get any .40 ammo yet. However I luckily have 3 16 round mags.
Sent from my SCH-I605 using Bimmer App
Turbo Build Here
Parting Out Complete 96 328is
Old 02-08-2013, 05:11 PM
try slickguns.com
Old 02-11-2013, 12:29 PM
Kdoherty's Avatar
I got some more goodies in the mail today. Falcon Grips and a Pearce frame plug
ID:	361829   Click image for larger version
ID:	361830   Click image for larger version
ID:	361831   Click image for larger version
Old 02-12-2013, 09:44 PM
just curious as to what happens if the batteries go dead while you are in the middle of shooting? I had a set of those but not electronic and found them to not be that great at the indoor range...so I got these delivered today
Peltor ultimate 10...has a NRR of 30 which is the highest I have seen and they were only 20 bucks...can't wait to try them out at the range
Old 02-12-2013, 10:57 PM
Leovigilde's Avatar
Leovigilde Leovigilde is offline
4 Dro
Mein Auto: 94' 325i
Here is what I've got
2 Mosin Nagant M91/30's 1 original and 1 sporterized
1 Mosin Nagant M44
1 AK-47
1 Savage Stevens .22lr
1 Mossberg 500 Tactical
2 20g. single shot shotguns
1 CVA Hawkens .50 cal.
1 High Point 9mm
1 Beretta 92fs with a crimson trace laser grip and 4 mags
1 Ruger Standard (mk1)
1 Cobra arms .22lr derringer
1 .22mag single action rough rider
1 Taurus model66 357mag
and 1 Walter P22
Imma go fast turn left and maybe go fast turn left again!
Old 02-13-2013, 05:17 AM
Kdoherty's Avatar
they work like normal earmuffs when the batteries die. they have an NRR of 22, they work pretty well in the off position actually.
Old 02-13-2013, 06:13 AM
Dood those peltors look huuuuge! Can you use them with a rifle and not hit the stock?
Old 02-13-2013, 07:57 AM
probably not....I don't have a rifle so I am not concerned with that. This is mainly for indoor ranges where it is REALLY loud and I would like to keep my hearing
Old 02-13-2013, 11:58 AM
Leovigilde's Avatar
4 Dro
Mein Auto: 94' 325i
If you lose your hearing then you won't need them...
Old 02-14-2013, 03:37 PM
SCJon's Avatar
SCJon SCJon is online now
Mein Auto: 1997 BMW 328is
Just found this at the gas station (wtf?) when I got gas. Their first issue and that is my favorite type of gun, the old military rifles. Will post review later, was pricey though $10.
"It doesn't do any good for me to know more than you if you aren't going to listen to me"
Originally Posted by petriej View Post
So let it be written, so let it be done.
Jon is the Shakespeare of signature quotables.
Old 02-14-2013, 03:43 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is online now
King of the Ballers
Mein Auto: Dreier, Fünfer & Siebener
You're in the south, isn't it standard to have gun stuff everywhere?
Sent from my LG Revolution 4G using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium //
E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. .
Originally Posted by SlimKlim View Post
You're a derbanana
Old 02-14-2013, 03:46 PM
Kdoherty's Avatar
forrealz, even up here in libby land you can go to almost any gas station or corner store and find a whole rack of gun zines.
Old 02-14-2013, 03:48 PM
dirty325is's Avatar
dirty325is dirty325is is offline
Mein Auto: 93 325is
A few guns i used when i went shooting last weekend
Sent from my DROID BIONIC using Bimmer App
ID:	362266   Click image for larger version
ID:	362267   Click image for larger version
ID:	362268   Click image for larger version
Old 02-14-2013, 03:52 PM
Kdoherty's Avatar
someone has a 1911 and wheel gun fetish I am itching to get out to the range, but just like anyone else who didn't have enough money to hoard up all the ammo in december I can't find anything.
When I went to my LGS to have sights installed on my glock they had gotten in a shipment of ammo, literally everything EXCEPT .40 S&W.
chad was here, firearms, gtfo chad, guns, shooting
