Old 02-08-2013, 03:52 PM
skybmray's Avatar
skybmray skybmray is offline
Mein Auto: 2005 745li
Oil Leak Help Vacuum Pump ?
I have a oil leak and I believe it coming from the vacuum pump. I recently replaced the oil sender thinking it might be that as the oil was in that area. I cleaned up the area thoroughly and went for a run and took a picture near that area.
I have circled where the oil is coming out off, I found that the top outlet where the hose is moves a bit, I saw a little bubble around the seam when I tried to give a little nudge. Does this mean the vacuum pump has to be replaced or just the seals ?
The circles are were the fresh oil is seen.
Thanks,
Ray
Old 02-08-2013, 06:33 PM
skybmray's Avatar
anyone care to comment ? need to be sure before I order the whole thing.
Old 02-08-2013, 06:45 PM
flash_n flash_n is offline
Mein Auto: 745Li
if you have oil in the tube, the pump has to be replaced. Otherwise it could damage the brake booster, it is a recall BMW has. See my DIY.
Looks like your solenoids are leaking, too.
Silver 2004 BMW E66 / 745Li (DIYs):
ASK, Logic 7, blower, battery, guibo joint, active stabilizer bar bushings, diff oil, tranny sw update, vacuum pump gasket, window lift, a/c compressor, washer fluid reservoir, belt tensioner and deflector, crankcase vacuum hoses, crankcase vents, solenoid gaskets, headlight overhaul, ISM, hood lifts, driver mirror, sway bar end links, rear fog lamps, headlight washer, headlight vertical aim, VCGs
next up: P0492
Old 02-08-2013, 06:51 PM
skybmray's Avatar
Thx flash_n where are the solenoids located, is this a easy job ?
Old 02-08-2013, 06:57 PM
Mein Auto: 745Li
They are to the right of the pump. You can see the retainer and bolt in your picture.
Level 3 on my scale from 1-10.
http://www.bimmerfest.com/forums/sho...light=solenoid
next up: P0492
Old 02-08-2013, 07:48 PM
skybmray's Avatar
Just fired off a email to my service guy at BMW with the recall notice. Lets see if they honor it.
