Old 02-01-2013, 06:41 PM
lazlazor lazlazor is offline
Mein Auto: 2010 X5 xdrive35d
xdrive35d exhaust smell
I have a 2010 X5 xdrive35d and whenever I am backing out of my garage or at a stop light I smell burnt diesel fuel inside the cabin, and the smell is not overly strong but is definitely noticeable. I was wondering if this is a concern I should take into the dealership to have them look at. Please note that the windows are not rolled down nor is the sun roof open.
Old 02-01-2013, 07:30 PM
smyles smyles is offline
Mein Auto: X5
Most likely cracked EGR cooler. Open the hood and take off the plastic engine cover. If the front parts of the engine are covered in black dust, there's a leak. You can also sense it by placing back of your palm next to it when engine is running (obviously don't touch it).
Old 02-01-2013, 07:50 PM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 535i; 428 GC; Twin X1's
The EGR cooler is definitely a possibility. Has happened to a lot of us.
But if your problem is intermittent, it could also be the particulate filter cooking off accumulated crud. Stinks like shyte, and very alarming the first time it happens to you. (Smells a lot like fresh roadkill on a hot cat.)
Sent from my HTC Inspire using BimmerApp
Current BMW's:
2016 428 GC MSport
2014 535i MSport
2015 X1 28i xDrive
2015 X1 35i xDrive
Prior BMW's
2014 328i SportWagon
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Technic
Old 02-01-2013, 08:43 PM
Thanks a lot for all your help. Much appreciated. Will take into dealer soon and update with what they have to say.
Old 02-02-2013, 04:11 PM
update: I popped the hood and took the cover off, the engine is covered in soot and I can feel the exhaust coming out from the engine. Will be taking it in shortly.
Old 02-03-2013, 10:03 PM
serge1's Avatar
serge1 serge1 is offline
Mein Auto: 2011 BMW X5 35D
Yup, that's it. I had mine taken to dealer and EGR changed. Before the change, I could smell the problem by popping the cover.
After they replaced the EGR a week ago, the smell haven't occured. I am positive it will fix for you as well.
Old 02-03-2013, 10:20 PM
RockChips RockChips is offline
Mein Auto: 2008 X5 3.0si
If its common, there should be a recall or something.
Its a safety issue.
Old 02-03-2013, 10:50 PM
I have attached an image I took from the under the hood..
Is very dirty for a 2010, I believe this is the EGR cooler.
Old 02-04-2013, 04:04 AM
jashearer jashearer is offline
Mein Auto: Holden Wagon & Sedan
My favorite part is that all that sh!t is being purposefully force-fed back through the engine...
Jay
Rover - 2013 Holden Commodore SV6 Sedan
Clark - 2013 Holden Commodore Sport SV6 Wagon
Brumby - 1955 Holden FJ Ute
Old 02-04-2013, 09:31 AM
serge1's Avatar
Jay
That's not the worst part. Worst is to have your cabin full of that sh!t.
Old 02-04-2013, 10:58 AM
Mein Auto: X5
I hope there's enough stink (pun intended) raised for BMW to recognize and address the issue, esp. considering they plan on bringing more diesel models to US they should be extra sensitive to any bad publicity.
Old 02-04-2013, 11:20 AM
If you are serious about getting a recall, here is the process that other people have used.
https://www-odi.nhtsa.dot.gov/ivoq/
Old 02-04-2013, 11:36 AM
serge1's Avatar
If i am not mistaken, there was already a recall for EGR. My vehicle did not need to be brought in at that time (apparently had the "good" EGR already). Looks like there needs to be another recall.
Old 02-09-2013, 12:59 AM
Update: took the BMW to the BMW dealership, they said everything is "normal" with the EGR cooler even though it's covered in soot. I showed them this thread and they printed off the picture I took of the EGR cooler and showed the technician. Will be picking up vehicle soon... wondering if the smell will continue..... if it does, should I take it to another BMW dealer? The dealer I took it too is Moritz BMW in Arlington, Texas.
