E30 (1982 - 1993)
Old 01-04-2013, 06:15 AM
Chaunceton Chaunceton is offline
Mein Auto: 1989 325i
Oxygen Sensor not Budging
The oxygen sensor on my car will not come out. Maybe rusted in? I've downed it in WD40, but it still won't break loose. Any ideas?
Old 01-04-2013, 06:30 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is online now
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
WD-40 is useless in this application. Get a proper penetrating oil such as Liquid Wrench or Kroil. Try several applications, waiting a half-hour or so each time to give it time to work. If it still won't budge, heat the bung red-hot with a propane torch to loosen its grip. You may still need to whack the wrench handle with a sledgehammer to break it free.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 01-04-2013, 06:42 AM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
Or just let the car run for about 15min. It'll heat up enough normally to help crack it free.
1999 540i M-Sport
Silver/Black
Still fresh and Minty
1985 335i
Black on Black coupe 5spd
R.I.P
1979 Trans Am 10th Anniversary
#16 of 5,683 made
KOI Import Parts-- 513-771-7777
Old 01-04-2013, 06:44 AM
That looks pretty thorough, thank you sir, I'll give that a try. Will liquid wrench still be effective in temperatures close to 0 degrees Fahrenheit? I live in Utah and the weather has been brutal lately.
Old 01-04-2013, 06:45 AM
But if I do that then the pipes will also be hot. Then it's difficult to wrench it off without burning the hand/arm.
Old 01-04-2013, 06:58 AM
Zeichen311's Avatar
Whether you run the engine or use a torch, you run the risk of burns--you should be wearing long sleeves (cotton or wool, no synthetics--they melt!) and mechanics' gloves for this job if you're even the least bit clumsy. Helps avoid the near-inevitable bloodshed when it finally lets go, too.
Most penetrants will not work well in deep cold. Use the torch or the engine to warm the assembly before each application.
Old 01-04-2013, 08:40 AM
Newman271's Avatar
That Guy
A company I sell through my work (KOI Autoparts) "Roadmaster" sells a kevlar heat sleeve. Part number KVBK18TS-T .. you can google it if you don't know what it is. But it basically allows you to accidently hit the hot pipe and not burn yourself because it will happen lol. We sell them for 20.99 for walk in customers so Im sure it could be found cheaper.
1999 540i M-Sport
Silver/Black
1985 335i
R.I.P
#16 of 5,683 made
Old 01-04-2013, 03:43 PM
downhiller's Avatar
livin large
unplug and drive. mpgs may suffer a lil but you dont have to worry about burning yourself
Old 01-09-2013, 02:58 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Post Stud removal
Women are attracted to us mechanics, because of our scars
I believe in safety first, so if you do not feel comfortable doing a job leave it
I always wear slip slops & I had a melting piece of steel fall between toes & burn itself into the flesh, where I had to rip it out forcefully The infection afterward was caused by me jumping into the nearest pan of fluid availiable to ease the pain- it was a old Antifreeze concoction
I have also burnt myself, by barefootedly stepping into a BBQ coal that had fallen out of my 44 Gallon drum BBQ
Recently my Cousin stepped barefoot onto a yellow scorpion. It only hurt when the Alcohol wore off
But the above only hurts a short time, whilst Safety boots are always a pain- Your choice
But to get back on topic:
These sensors seize, like exhaust studs, because people do not apply a thin coat of Coppa slip on the thread during assembly
It is easy ! Spray penetrating oil onto the offending fastener when hot (keep away face) and then let it penetrate through the engine cooling off. You should even be able to undo said fastener without needing to heat engine up again
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 01-10-2013, 12:09 PM
Boy it's a real bugger. I heated it up through running it, torched it, liquid wrench, pipe on the end of the wrench, nearly everything. I'm beginning to deform the bolt, and yet it still doesn't budge. Not sure where to go from here.
And sorry about your foot man, that sounded pretty brutal.
Old 01-10-2013, 07:10 PM
BMWFatherFigure's Avatar
Old School
On ya Nick!! Back to the plot - Use the correct socket or a good ring spanner. Work on it cold. Try to TIGHTEN IT SLIGHTLY first and then remove. I'm amazed the pipe has not torn open with the force you say you are using. If possible soak with your favourite penitrant over night (cold) before having another go.
Current:
E38 Parts Car
Previous:
Old 01-10-2013, 08:32 PM
downhiller's Avatar
livin large
my idea is starting to become a prime choice........
or if you are very careful and good aim, hit the o2 sensor with a hammer. the best way it to hit it from the top (yeah i know virtually impossible while exhaust is mounted on the car) but, that leads me to the next part, remove the exhaust then try
Old 02-09-2013, 11:37 AM
Well the trick was getting the car up on a lift. That gave me a better angle and it was easier to put all my weight into it. We heated the bung to red hot and started torquing it off. The threads were pretty shredded, but after a quick cleaning out the other sensor fit in nice and snug. Thanks for everybody's input!
