Old 02-09-2013, 02:23 PM
cpodunc cpodunc is offline
Mein Auto: 2003 735LI
heater wont turn on
hello all, this is my first post so please forgive me if I am repeating something from old but I have had a look and can't see the same problem as me...
I have a 2003 735Li, basically the heater works fine along with the cold however it will turn itself off when it feels like it, the orange light on the off button is illuminated and nothing i can do will override this, i can turn the ac on by pushing the ac button but the orange off light stays on until randomly going out, then the system will work until it decides to switch off again, i have had the aircon regassed, any thoughts before I spend a small fortune at a garage? it's very cold and I need to fix this before I can take my new born in the car!
any thoughts / ideas would be great, thanks all
Old 02-09-2013, 02:46 PM
BMW7_CEO's Avatar
BMW7_CEO BMW7_CEO is offline
BMW7_CEO
Mein Auto: 2005 745LI
Try to go to the climate control on the Idrive and go where it says automatic and click it then it should over ride it and click heat then after adjust how you want the vent system to work
Old 02-09-2013, 03:11 PM
Thanks ill give it a try, someone else suggested I replace the final stage resistor!!!
Old 02-09-2013, 03:37 PM
BMW7_CEO's Avatar
BMW7_CEO
I don't think it's that but it's sometimes the automatic heat or ac turns on or off automatically when the temperature in the car is at it's point but this happen to me I just override it by the idrive climate control
Old 02-09-2013, 03:39 PM
thanks, i just went and tried that but it is working fine at the moment, i will wait for it to turn itself off then see if i can override it!
Old 02-09-2013, 10:35 PM
BMW7_CEO's Avatar
BMW7_CEO
Alright and good luck man let me know if anything
Old 02-10-2013, 09:33 AM
SFbay SFbay is offline
Mein Auto: BMW 745i
Usually you read errors from ihka.
Old 02-10-2013, 04:33 PM
Busarider Busarider is offline
Mein Auto: 745LI
First option is the use the iDrive settings, if it doesn't work then you need to reprogram.
Old 02-10-2013, 04:37 PM
Reprogram? I have had all the faults cleared off the system and it still happened, it was ok yesterday and I'll see tomorrow of I can get it to turn off, it seems to happen later in the day kind of like its been on for a while and possibly heated up a lot? Apart from the idrive override are there any sensors I can replace, is it worth trying to change the final resistor thing??
Old 02-10-2013, 07:26 PM
Jerry 745Li Jerry 745Li is offline
Mein Auto: 03' 745Li
Its the control panel itself. Had mine replace several years ago. The AC would just turn off by itself if I hit a bump. If you press on the AC control panel in various spots I could get it to turn off and on without actually touching any of the buttons.
You need this: http://www.ebay.com/itm/BMW-e65-e66-...9d4548&vxp=mtr
Jerry
I don't have all the answers, but I can do one helluva Google search!
Old 02-12-2013, 01:22 PM
Bmw say its the blower regulator / final stage resistor, it's being changed next week I will keep you informed
