Old 02-10-2013, 10:53 AM
tamir15 tamir15 is offline
Mein Auto: 2006 750i E65
E65 aftermarket backup camera - NEED HELP
i am having issues installing an aftermarket camera on my E65.
i am connecting it to a monitor on the dash (not the nav screen).
my problem is with the 12v power to the camera. when i connect it to the reverse light bulb wire the image flickers and no steady image.
when i connect it to a regular 12v in the trunk (trunk light bulb or any other 12v) i get steady image and no issue.
does anybody know what may be the problem?
Old 02-10-2013, 11:17 AM
First_745Li's Avatar
Mein Auto: 2003 745Li
Can you post up some pictures of the wiring at the backend, meaning the wires you're trying to connect..
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 02-10-2013, 11:22 AM
Check this thread out..
http://www.bimmerfest.com/forums/sho...reverse+camera
Also see the attachment should include wiring diagram
File Type: pdf BMW Rear-View Camera Retrofit for E65 and E66.pdf (507.0 KB, 168 views)
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 02-10-2013, 12:04 PM
hey,
thanks for the quick reply.
sorry but i have everything put back together now so i cant take pictures.
i connected both to the connector that feeds the reverse light bulb and to the light bulb housing it self (same result). i verified the wiring so i know this is not my issue.
for some reason there is a distortion but i am not sure why or what it is.
the forum and pdf you attached is for a kit that includes control boxes and other items that go with it. it doesn't tie directly to the reverse light bulb wires.
i can run the camera power line to the front of the car (just like i ran the video wire) but where would i connect it to if i ran it to the front?
Old 02-10-2013, 01:08 PM
rippjd rippjd is offline
Mein Auto: '05 745i / '00 740i
It's possible the light module sends a pulsed (PWM) voltage to the reverse light. Your reverse camera kit likely needs a steady voltage.
2005 745i Individual
Old 02-10-2013, 01:15 PM
Nygel's Avatar
Nygel Nygel is online now
Mein Auto: BMW 750Li
you will need a relay for the 12volt activation
Old 02-10-2013, 01:37 PM
ok thanks Nygel and rippjd. i figured the car electronic module sends the voltage to the reverse light bulb and doesn't like another load or doesn't send steady 12v.
i need further help please: what kind of relay? where do i buy it?
once i get it where do i connect it? between the cable connector and the light bulb?
Old 02-12-2013, 06:17 AM
bk750 bk750 is offline
Mein Auto: 2007 750 li
was up go online and forget that monitor hook it to your nav screen its call navtool I have it installed u can also watch movies on it
Old 02-12-2013, 12:57 PM
ok finally got it to work. i bought an automotive relay at Radio shack and used it to switch the 12v from the reverse light bulb 12v to a steady 12v.
works like a charm.
cost me $40 for the camera and rear view mirror monitor and two days of work but it is definitely worth it.
thanks for the help
Old 02-27-2013, 12:56 AM
as3070971 as3070971 is online now
Mein Auto: 2002 bmw 745
Can u send of pic of camera installed on vehicle. Have the navtool connected already. Wasnt sure what kind of camera to use or how to Install. Thanks.
Sent from my SGH-T999 using Bimmer App
Old 02-28-2013, 09:13 AM
i will try to take some pictures and post them. this is much easier than connecting it to the nav screen. you will need to buy a rear view mirror monitor and route the video cable from the camera (mounted on the license plate) all the way to the rear view mirror
