Old 02-10-2013, 02:18 PM
teklord69 teklord69 is offline
Mein Auto: 2001 330ci 5-Spd
Any ideas where this oil leak is coming from?
I started to notice drips of oil on my garage floor in the last few months and finally lifted the car to see where this leak is coming from. By looking under I cannot determine exactly where is the leak. By looking in the engine compartment down, there is nothing visible to tell me an oil leak. So where is this leak coming from? Rear main seal? Oil filter gasket? What are the typical oil leaks that would cause this?
Old 02-10-2013, 02:39 PM
bkgreene39's Avatar
bkgreene39 bkgreene39 is offline
Mein Auto: 1998 BMW 528i
I'm in the same boat. Check by the oil filter housing area, that's where mine appears to be forming. I will tackle it once this miserable winter leaves NY already.
"And if you no longer go for a gap that exists, you are no longer a racing driver because we are competing, we are competing to win."-Senna
Old 02-10-2013, 02:56 PM
filon102 filon102 is offline
Be american, get a bimmer
Mein Auto: 00' 540i, 87' benz 300DT
you aint lying... im tired of winter. Helpfully spring comes soon!
Old 02-10-2013, 03:31 PM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator, 5-Series
Mein Auto: Trek 6500 MTB
Clean your engine really well and then watch for the leak. At this point, it could be from ANYWHERE.
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (sold) *very rare interior/exterior color combo*
2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease over)
2014 335i/8-spd, Mineral Grey/Black (lease take over)
Old 02-10-2013, 06:31 PM
mda185 mda185 is offline
Mein Auto: 95 525iT w/S52, 03 530i
I am in process of solving a similar problem with my 530i. Oil pan has been wet for 2-3 months but source is not obvious from below. Try looking under the valve cover on the block to see if there is any obvious signs of leakage. You can do this from the engine bay with a flashlight. In particular, look at the engine block behind the oil filter housing and under the intake manifold. This will definitely require a flashlight. My problem is at least partially due to a failing CCV system that must have been cracked and was leaking oil onto the block. I may also have an oil filter housing gasket leak but no way to tell yet. The CCV on my car failed big time ~10 days ago and I was suddenly burning tons of oil. I replaced the CCV and all hoses this week and found the engine block behind the oil filter housing and underneath the intake manifold was covered in oil. I also found the power steering hoses are leaking and contributing to what is dripping from my car. The best way to inspect these is to drop the plastic cover underneath the engine. My car has about 130K miles on it.
Old 02-10-2013, 08:53 PM
Im at 130K now also. Dealer replaced the Oil filter gasket maybe 3-4 years ago. My CCV is new. My Valve cover gasket is still orginal and I will focus on that. Will definitley go over the engine with a flashlight more thorough. Thanks
