E34 (1989 - 1995)
#26
Well what happens if you don't mark the driveshaft before you pull it out? I thought I got chalk marks on all the pieces but I obviously missed where the front of the driveshaft connects to the tranny, got it marked on the back of shaft and diff...
#27
You may be okay here. If you have not turned the output shaft of the transmission, then you can place the driveshaft back at the differential and line up the marks (you may need to run a bolt or two through to hold it), then you should be able to hold up the end that connects to the transmission and mark it.
Otherwise you risk it being slighlty off balance, but I don't think it would give any noticeable vibration, but can't say for sure.
Steve Calypso Red 1992 525i with 170K miles 1991 735i - Sold 1992 525i - Sold 1995 325is - Sold 2000 528i - Sold
#28
I think that it being off balance would almost certainly make it vibrate... or shudder, no?
Sent from Joe's Galaxy Tab 2 via BimmerApp
![]() 1995 525iA 250k mi Shifted Performance E34 2006 325i/6 48k mi 2003 350Z 87k mi Shifted Performance 350Z Garden State Euros |
#29
![]() Unless there's some other way that I don't know about (which is entirely possibe).
#30
a few teeth out MAY be okay, but any more than a 60 degree turn and its not going to be any good. but you should be able to get it balanced at a transmission shop or engineering outfit etc for a box of beers, so all is not lost yet.
#32
Wow i better get a fsm on 530 because i always thought the driveshafts were indepedently balanced and all you had to worry about was the yokes lined up right if you rebuild them. So they are balanced on the car complete
#33
correct.
..........I'm having a blast with these. I got 5 out...these things take a lot of torque to remove
#35
#36
The drive shaft is still together, I just didn't mark where it connected on the yolk ( I guess thats the term for that y looking piece on the rear of the transmission. I just have to get those last 2 torx bolts out the top of that transmission now. So I still need to go get it balanced correct? Was trying to figure out if I should replace the center bushing while its off...I'm trying to do maintenance but also get the car back on the road for the wife. Will post some pictures of it in a while.
#37
Does anyone have a picture reference as to the bolt removal on removing the transmission? I thought I got all of them out, counted 10 so far 9 on back side and 1 small one on the front, Bentley book shows 11 but the transmission is not pulling away easily like it says it should.
#38
Via Pelican Parts Tech Article
![]() Sent from Joe's Galaxy SIII via BimmerApp
![]() 1995 525iA 250k mi Shifted Performance E34 2006 325i/6 48k mi 2003 350Z 87k mi Shifted Performance 350Z Garden State Euros Last edited by Monsignor; 02-10-2013 at 01:55 PM. |
#39
You see that little small picture in the bottom corner? Well it appears that the smaller bolt of the two on mine is missing/broke off in there. I can see the bolt in there. It looks like someone used a grinder or something near it. What in the world...
#40
Why do you only have one of those two? And it doesnt seem threaded, it should just pull off of it. Then you can replace it once the tranny is off. And those two arent a part of the larger picture's 11 I believe. So you still may be missing some...
#41
as far as the driveshaft goes i have removed hundreds and never marked them. someone will have to explain how replacing a rotating object on a fixed axis changes the balance if rotated to a different location. but i can be stupid. i wonder how tires are balanced and put back on. need pictures please and it sounds like things are going good |
#42
The tranny weighs about 85lbs. It is not to bad to take out, I have done it by myself with a regular floor jack. I just put a board on it and slowly lower the tranny. It is much easier then the auto tranny that weighs 142lbs after being drained(that is with out the converter)
You might think about going to a single mass flywheel. You can use a m20 one from either a 528e or a 325i/e. It is lighter. You do also have to replace the starter for a m20 starter. But you can get the fly wheel for 60 to 70 dollars and the starter from 35 to 55. Andy |
#43
Here are some pictures...you can tell my transmission bushings were shot, my cats holding the car down so it don't move, these are all of the bolts I pulled off the transmission and it still seems locked down...as you can see I got it to move a little but its not wanting to come off. My slave cylinder leaked some fluid when I removed it, is that normal if the plunger gets moved? Was a tight fit to remove it. Kinda messed up the head of 1 bolt, my breaker bar let it slip off.
EDIT: I don't think I removed enough of the transmission mount to pull it off now that I look at it Last edited by CJ74753; 02-10-2013 at 04:14 PM. Reason: pic detail |
#44
i only see one bolt with a nut i think there should be two one on both sides of bellhousing right across from each other. are you using a torx socket or a 12 point socket if you are using a 12 point socket dont buy a set of torx sockets. if the transmission is not moving there still has to be a bolt somewhere if one side is moving check other. when all else fails get out from under the car and pet the cat holding the car down take some deep breaths and clear your mind and then dive back under there and find the bolt..repeat as needed. dont let this piece of metal out think you
edit: the slave cylinder will seep a little and in colects in the boot when you pulled it away it freed the passage for it to leave the boot. replacement is a judgement call. it might last another 100k or it could fail pulling out on the test ride...the question is do you feel lucky
#45
I would check again for a bolt up there 90% of the time thats where they are missed
#47
I'm 99.999% sure there are no more bolts up there, I bear hugged the transmission and felt all empty holes...is there anything that could bind it up and not let it loose? I can see it wiggle as I yank on it...I am stumped here
#48
Have you tried a prybar between the engine and bellhousing yet
#49
I have been slowly prying around it with a long flat head and have got it spaced apart some...guess I might just need to keep working it apart
#50
If its coming even then its stuck on the alignment pins. Just keep doing it from side to side
