Newbie with a question - Bimmerfest - BMW Forums
Old 02-08-2013, 10:32 AM
satjock satjock is offline
Mein Auto: 1995 750 iL
I own a 1995 e38, and have a nagging problem. When the car is running, I get a high pitched whine from somewhere in the rear end. It is not speed specific, it gets
louder between 800 and 1100 RPM'S, but it never gets higher pitched. And if it matters, the rear suspension creaks when any passenger gets out of the car. I don't suspect the diff, because it should br speed dependent. Is there a pump in the rear end for stability or ride i would appreciate any help or ideas. Thanks in advance.
Lance
Old 02-08-2013, 04:10 PM
Espresso Espresso is offline
Coffee Extraordinaire
Mein Auto: 2001 740i Sport
running is just idling, or driving?
Noises can travel, what you think is the rear could be transmission or even a lower pulley on the engine. get it in the air..on a lift. Start it & go from there.
Old 02-08-2013, 08:09 PM
Thanks for the response. I was just about to do the same thing, when I was talking to a couple of my reliable guys at Napa here in town. We went out and looked at it, and he told me the exact same thing happened to his wifes car. We looked under the car, and there is a big ding in the middle of the gas tank, and apparently we arehearing the fuel pump. I will have to drop the tank, remove the fuel pump, and see if I can knock the ding out of the tank.Also explains the problems with the fuel gauge. Again, thanks for the help, and looking.
Lance
Old 02-08-2013, 08:11 PM
P.S. if anyone has got tips about dropping the tank and pounding out the ding( I am aware of the explosive nature of this evolution) your tips would be greatly appreciated.
Old 02-09-2013, 01:36 AM
PETER NEWMAN's Avatar
PETER NEWMAN PETER NEWMAN is offline
Mein Auto: BMW 635 CSi BMW 730i E38
Smile Fuel tank
You do not need to remove the tank to replace the fuel pump, Just remove the rear seat base and the pump is underneath a round black metal plate which is held in with screws. Check the condition of the fuel pipe connected to the pump and replace it if needed but DO NOT use rubber fuel hose as it will rot away. Is your fuel tank really dinged or has it collapsed. Collapsing fuel tanks on e38's is caused by blocked carbon filters and the filter is located under the rear of the left hand side rear wheel arch liner, Peter
Old 02-09-2013, 05:51 AM
X2 on Peter's post.
My guess would be the float on the arm that reads the fuel level is impregnated with fuel. or fell off completely.
Old 02-10-2013, 10:26 PM
BMWFatherFigure's Avatar
Old School
If you have to knock the dent out use a wooden stake - no sparks.
Current:
E38 Parts Car
Previous:
