E34 (1989 - 1995)
Old 02-08-2013, 09:51 PM
jhkim jhkim is offline
Mein Auto: 525i
Over cooling ?
When I drive a car during the day, my temperature gauge points the middle. However when I drive the car in highway at night, the temperature is low like in the attached picture. What could cause this low temperature at night ? Outdoor temperature is 60 at day and about 30 at night.
Old 02-08-2013, 11:39 PM
germx germx is offline
Mein Auto: 94 530i Man, 01 740iL
Watch out for black ice if you are driving on the highway during freezing conditions at night! I think your gauge pointing left of center during these conditions is normal.
Old 02-09-2013, 02:04 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
running between the arbitary 1/4 and 3/4 mark is, to a point, normal, though always running cold or always hot does indicate a problem.
In fact, if you sit in the drivers seat of an E46 they do not have the 1/2 mark at all, I'm not sure about other later BMWs.
Just keep an eye on it for now, but at the moment, i wouldnt be too bothered.
if it is indeed running cold, it is likely to be the thermostat, or could just be a faulty gauge sender.
E30 above Sold
Last updated 2nd January 2014
Old 02-09-2013, 06:37 AM
Monsignor's Avatar
BMW CCA Memeber #445389
Mein Auto: Sig
Faulty thermostat? Maybe nit closing 100%?
Sent from Joe's Galaxy Tab 2 via BimmerApp
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 02-09-2013, 08:42 AM
Mein Auto: 525i
After I started a car, I touched the hose that is connected to a radiator. Although temperature is lower than 1/4 mark, the hose was already warm. Maybe thermostat is always open ? It was cold when I start a car.
Old 02-09-2013, 09:05 AM
Mamij Mamij is offline
Banned
Mein Auto: BMW 320i M52 1996
I had the same symptoms in 4 months, replaced the thermostat with OEM, and voila now it's fine, it was stuck open. My upper hose was also hot even though the thermostat was open all the time.
Old 02-09-2013, 10:38 AM
Monsignor's Avatar
Mein Auto: Sig
The reason for that is that the hot coolant from the heating engine are flowing through the hose even though its not at op temp yet. E28 does it too.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 02-09-2013, 10:52 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Agree thta the t-stat is likely the problem and should be replaced.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 02-10-2013, 06:12 PM
BMWFatherFigure's Avatar
Old School
+1 on t'stat
Current:
E38 Parts Car
Previous:
Old 02-10-2013, 07:00 PM
Mein Auto: 525i
Yay! Another DIY project. Do you guys think this is not too bad to keep driving? I'm planing to replace tstat when I replace coolant. It might be after a few thousand miles more. I wonder if how bad this is. I see that it takes a while until temperature bar is at the middle.
Old 02-10-2013, 07:18 PM
cutter67 cutter67 is offline
Mein Auto: 530,m6,633
No it wont hurt anything. The stat is designed to get and keep the engine at a certain temperture so it heats up faster. This also effects your heater. If you are driving on the highway you may not have heat. I would change as soon as possible. ...you only have to worry when they are stuck closed
Old 02-10-2013, 09:04 PM
So, in post #2 I said this is normal while driving in freezing conditions. I'd like to retract that statement. Since then I've learned that thermostats open and close while the engine is running. For some reason I was always under the impression that a thermostat opened and stayed open once the engine reached normal operating temperature. But this is not true. A thermostat closes once the temperature starts dropping. Here is a cool youtube video showing this.
Now I fully agree that the OP has a bad (stuck open) thermostat.
To add to this, please read this thread (especially post #11) http://forums.bimmerforums.com/forum...d.php?t=292135 I don't know how true this is. But it is concerning.
Old 02-10-2013, 09:11 PM
BMR_LVR's Avatar
Humble E34 lover
Concerning and 100% correct.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 02-10-2013, 09:18 PM
Mein Auto: 525i
That's a really cool video. I can't stop thinking about a slowly closing and opening tstat while driving after watching this vidoe. Thanks !
Old 02-11-2013, 05:11 AM
Old School
Education is a wonderful thing. A little knowledge is dangerous......
Current:
E38 Parts Car
Previous:
Old 02-11-2013, 08:22 AM
damengoodsman damengoodsman is offline
Mein Auto: 1994 BMW 525i wagon
My temp gauge reaches the center mark, or maybe just a needle width to the left during highway driving at -25C, not getting up to temp at 30F is not normal. Although i think it would take a long time to get to the center mark/warm whem highway driving at 60F with a stuck open thermostat, no? I wonder what the actual coolant temp difference is between being 1/4 and 1/2 on the temp gauge is.
Replacing thermostat is not too big a job, replace the thermostat cover with an aluminum one while you are at it though. You might also consider replacing pump as well while you are in there, depending on miles and service history of course.
Old 02-11-2013, 08:50 PM
Old School
Keeping the oil cool is bad. It needs to up at normal operating temp.
Current:
E38 Parts Car
Previous:
Old 02-12-2013, 05:14 AM
The Ornery Old Man
Mein Auto: GTI
Yes, running too cool will cause problems. However, I suspect that by the time the needle moves off the cold section (blue) you are well out of the fuel enrichment cycle. This acts as a choke did on carburated cars. It doesn't take a long time for it to come off.
You should be fine for a short time. As simple as the stat is to change though, I would just do it. You wont lose much coolant, no real point in waiting.
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 02-12-2013, 10:58 AM
Monsignor's Avatar
Mein Auto: Sig
+1
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 02-14-2013, 11:26 AM
Black Water Black Water is offline
Mein Auto: 1990 535i 3.5L Ger A/T
Change it. It's cheap, easy and if I can do it, anyone can. Hell my wife could do it...but then my wife's pretty damn smart...just don't over tighten the bolts?
Old 02-14-2013, 11:45 AM
Mein Auto: 525i
Thanks for the advices ! I ordered the parts and waiting for them. Found a pretty good blog about it.
http://almostgonesblog.blogspot.com/...placement.html
I'm not changing a water pump so I'm wondering if I don't need to remove the fan. I will update the ticket after replacing the tstat if it fixes the problem or not.
Old 02-14-2013, 11:50 AM
Seems like I did have trouble with access to the bottom bolt...maybe I did take the fan off to do it properly...can't remember now. But the fan was easy to take off from what I recall...
Old 02-18-2013, 08:58 PM
Mein Auto: 525i
Fixed !
It wasn't that easy project because taking out a fan wasn't easy. However I found a good tip which you can borrow a wrench that holds the fan.
http://www.autozone.com/autozone/acc..._&target=shelf
Part Number: 27018
Alternate Part Number: AZ188
With this tool, it was pretty easy to taking out a fan. You guys are all right. It was a tstat problem. A surprising fact is that the tstat has very small gap. It wasn't that big but it caused big temperature difference. After replacing it, the temperature is on solid middle. I drove about 60 miles and it did not change at all. Also heater works well. Yay! Thanks for the advices.
P.S. Does anyone know what the arrow means on tstat ? I put the tstat the way that the original one is but I don't know whether the arrow means something.
ID:	362924   Click image for larger version
Old 02-18-2013, 09:09 PM
it indicates proper positioning of the thermostat; quoted from the Bentley "Install the thermostat so that either the arrow or hole are at the top." so it can bleed properly I assume...
