The X5 SAV Forum
Old 02-11-2013, 11:33 AM
Lav20 Lav20 is offline
Mein Auto: 2006 X5 4.4i
Rear Lightbulbs (X5 2006 4.4)
OK I received a check brake light warning. I removed the both bulbs and bought replacement bulbs for both sides even though one was working fine.
I replaced the bulbs. One SIDE (right side) works, the other does not. So it's not the bulbs. Any thoughts or easy fixes I should try before getting the pro's involved?
Are the brake lights on independent fuses? Also the interior unlock botton also decided to stop working.
Any help appreciated.
Old 02-11-2013, 12:21 PM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
Most likely the bulb holders are the problem. This is a very common failure point on the X5. A 50k+ vehicle that uses cheap crappy plastic/metal fittings in the main light units that have been causing problems for years across all the model lines. (RANT OFF)
Take the units out and examine the contact points for the bulb holders and also the bulb holders themselves. Look for evidence of burning. Clean off the black residue and they should work. Some have used solder to build up the contact points and found it to help. I have used the conductive grease electricians use in meter boxes and had great success with it. I used it on the front turn signals and had no problems for 6 years. You might also consider the newer LED units as they really improve the look and visibility and eliminate the problem.
Old 02-11-2013, 12:25 PM
Great thanks. Youtube also suggested the same and YES I did notice the scorch spot on the holder. I will clean up both points and see what happens.
