E34 (1989 - 1995)
Hello everyone, I know I have posted about this issue before but that was long ago and I'm still having problems, so here I am. I'm really losing my sanity with this car, many times have I considered selling, only reason I didn't is because I would never get near what I put into it. I've had a love/hate relationship with my E34 since I bought it, lots of love, and lots of hate. Right now, it's hate.
![]() So as some of you may know I had a misfire a while back, one which I thought was resolved, it wasn't. I'm going utilize some listing action to make this post as easy to understand as possible, here goes. SYMPTOMS -Difficulty starting when cold, long cranks but still starts, starts much quicker once hot -Seemingly random "COOLANT LEVEL" notification when turning the car off -Poor fuel economy, 15-16mpg, about equal highway and city driving -Misfire when below 2000rpm, occasionally above but much less often, also seems to be correlated with medium to fast acceleration -Idles fast at first, about 1100rpm, then usually settles to 700rpm after a few seconds, sometimes will continue to rise to 1500rpm -Frequently hesitates when starting off, when letting off the clutch it jumps forward a bit then takes off like normal -Closing the throttle when cruising will sometimes cause it to rock forward because it decelerates so fast -Feels like there's a bit of power that's being held back, not too much though -Occasional groaning inside the dash that varies with rpm, lasts only a few seconds I'm fairly certain those are all the symptoms, I'll be sure to add more as they arise. Now, so no ones throwing out things I've already done here are two more lists to make life even easier! IGNITION -NEW coil -NEW wires -NEW plugs -NEW distributor -Crank sensor FUEL -NEW AFM -NEW fuel pump -Fuel pressure regulator (already ordered) -Injectors -Idle control valve -Throttle position switch -Engine coolant temperature sensor -Oxygen sensor
Year: 1990 Model: 525i Transmission: 5 speed Mileage: 250k |
I remember the misfire thread. I dont know if this was discussed or not but I am very perplexed by your situation and theres no harm in a suggestion...
Battery? When was the last time it was changed? how old is it? Are we so close to the forest that we can't see the trees... EDIT: I see you have Spark and Fuel lists but no Air. I know its not a major player in a misfire situation but it doesnt hurt to look at the quality of the air filter.
![]() 1995 525iA 250k mi Shifted Performance E34 2006 325i/6 48k mi 2003 350Z 87k mi Shifted Performance 350Z Garden State Euros Last edited by Monsignor; 02-07-2013 at 01:39 PM. |
I'm probably just gonna end up throwing parts at it until it's fixed... By now I wouldn't even call that reckless considering there aren't many parts that I haven't replaced.
Well a miss is either fuel or spark and it looks like you covered everything. I would check the leads to the injectors see if there is any wear or cracks in the insulation on the wires also check the grounds. The way i check is disconnect while the engine is running if the miss gets worse then its working if it doesnt you know you have a problem do the same with the plug wires
How is the power on the car? Do you feel the engine is lacking power?
Do a compression test?
BMW 530I Silver Gray 6M |
Since you guys brought it up I guess I will run both of these tests again, just to confirm
I have a jumper harness for the injectors sorry....is this just a high rpm miss or at low rpm's miss? Or is it constant i read where you said 2k or lower but sometimes higher. If it is a lower you should be able to find the the dead spot by pulling the sparkplug leads
Didn't you recently change your fuel injection system, and got yourself a new chip and a free flow maf to replace the stock afm ? Could there be something wrong with all that?
Okay so, I've decided that the "cold start" problem may actually be a result of not retaining fuel pressure, I recently noticed there was a small crack in the fuel line connecting to the rail. I'll fix that soon and see what effect it has. The misfire has miraculously gotten much better, but still exists, and my miles per gallon hasn't improved a bit. Given that Should I be looking for a faulty O2 sensor? There is no check engine light but I don't know when it was last changed so it could be clogged up.
O2 and check charging voltage.
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
I apologize if this is a stupid question, but what would charging voltage have to do with it? The battery light isn't on and I've replaced the alternator brushes so it should be good, but I suppose it never hurts to check.
So my new fuel pressure regulator from Ireland Engineering came in the mail today
Okay so my O2 sensor came in the mail today, I got it installed and it's made quite a big difference
It seems like now the misfire almost exclusively occurs with light throttle, particularly at low RPM as usual. I'm no expert on diagnosis solely based on sound but to me it sounds like it's too rich. I still plan to do another compression test soon, very hopeful that's all good. Also I want to bring her in for a valve adjustment and see whatever wisdom they can give me. Here are the things I haven't replaced: CPS - I have a new one, but mine tested okay so I left it. ECT - Tested multiple times, seems good. TPS - Tested, probably should adjust WOT setting. ICV - Cleaned and tested, works fine. Fuel pressure regulator - I also have a new one, just need to find a place to mount it since it doesn't sit on the rail like it should.
Agh, double posted
Year: 1990 Model: 525i Transmission: 5 speed Mileage: 250k Last edited by Microtesties; 02-15-2013 at 06:13 PM. |
