Old 02-12-2013, 07:39 AM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
Originally Posted by FiFi411 View Post
When you flip the washer switch to splash water to clean your windshields, the headlights also have their own washer that splashes water on them (it comes out & goes back in).
And some people HATE that headlight washer feature so much that they desperately have the dealer deactivate it. I just hit the windshield washer stalk in short bursts to clean the glass without activating the headlight washers.
Old 02-12-2013, 10:22 AM
ALTY ALTY is offline
Mein Auto: 2004 530i Sport package
The headlight washers on come on when the headlights are on... Soo if you don't want the headlights washed make sure your headlights are turned off... Turn off of auto... Your lights are on more then you think...
Sent from my LG-LS840 using Bimmer App
Old 02-12-2013, 06:12 PM
German Steel German Steel is offline
Mein Auto: 2008 535xi
Originally Posted by Mike Swing View Post
I discovered that with comfort access, you can roll up the windows & sunroof by keeping your finger on the handle to lock it. Just takes a couple seconds to start. The car will also prevent comfort access locking if any door is not completely closed. Figured it out the hard way.
For the heavily medicated......please clarify. Are you keeping your finger on the door opening handle to lock it? Do you mean the door handle outside?
Old 02-13-2013, 07:29 AM
Campfamily's Avatar
Campfamily Campfamily is offline
Mein Auto: 2008 550i
Put your finger near the keyhole on your drivers door handle. The doors should lock immediately. If you leave your finger there, the windows and sunroof will close. This assumes you have comfort access.
2008 550i, Carbon Black, Black Dakota, 6MT, Sport Package, Nav, Logic7, Comfort Access, Cold Weather, Folding Rear Seats, iPod SOLD, but not forgotten
Old 02-13-2013, 09:05 AM
Mike Swing's Avatar
Mike Swing Mike Swing is online now
Mike Swing
Send a message via AIM to Mike Swing
Mein Auto: 2000 Z3M 2007 530i
Yes, I meant the door handle outside. The same procedure as locking the door with comfort access but you just leave your finger there a little longer to start the windows.
Mike Swing
Old 02-13-2013, 02:36 PM
NoQuarter's Avatar
NoQuarter NoQuarter is online now
Originally Posted by booyaazaa View Post
Nope. Got to have the brake pushed to start the engine in my auto.
I'm pretty sure it works the same as described with the clutch. Happens to me by "accident" every once in a while and I never remember to try it on purpose. Sometimes I get in, push the button - nothing happens - then it starts. I think it starts after I press the brake pedal.
Old 02-16-2013, 11:38 PM
etnav382 etnav382 is offline
Mein Auto: 06 550i
I DO have an oil dipstick. This is after 3 years of reading that on the earliest models had one. I was replacing my enigne air filter and saw something coming from the back of the engine bay and started pulling on it because it looked like a dipstick and it was!! BTW my car is an 06 550, so maybe they removed it in 07 and later models.
Old 02-17-2013, 07:01 AM
UltimateDriving UltimateDriving is offline
Mein Auto: A Car
Yeah, someone mentioned this in another thread, i wish the I-6 had a secret dipstick.
Old 02-17-2013, 07:19 AM
NedB NedB is offline
Mein Auto: 550i
Are you sure that isn't the transmission dipstick? Redd fluid on it?
Old 02-17-2013, 07:57 AM
E60black E60black is offline
Mein Auto: 545i
Originally Posted by JCW3rd View Post
Going hrough the First Aid kit and found nearly 1/4 of the volume taken up by two, uh, femine napkins.
That sh*ts hilarious
Old 02-17-2013, 02:42 PM
chinesestunna chinesestunna is offline
Mein Auto: Acura TL
Just bought 545i
Realized rear sun shade is jammed (stealer wanted $1200 to fix and previous owner declined) and slight slip going from 1st to 2nd that I detailed in this thread: http://www.bimmerfest.com/forums/sho...d.php?t=676902
Old 02-17-2013, 03:58 PM
DIY'er
Mein Auto: 2004 545i
I know (at least on mine) that there isn't a transmission dip stick.
I hope to god they added one--it's a royal pain trying to check transmission fluid level without one (i.e. engine on, under the car, taking bolts out to see if oil drains out or not..)
Old 02-17-2013, 05:02 PM
2chill's Avatar
2chill 2chill is offline
Mein Auto: 2008 528XI
If you have the four way flashers on and you activate the left turn signal, the right side flasher turns off and vice versa.
PP, CWP, NAV, satelite radio, USB, Folding Rear Seats.
Old 02-17-2013, 05:05 PM
boramkiv's Avatar
Propellers Up Front
This is awesome during a caravan. It lets the other bimmer drivers know your intentions (lane changes) without having to deactivate the hazards momentarily by hand.
Old 02-20-2013, 01:54 PM
I just noticed the driver side make up mirror and how the ceiling light just above it is activated when you slide open the mirror cover.
Old 02-20-2013, 02:40 PM
H F H F is online now
Mein Auto: 2005 545i
How bout this one guys,,,, when ur driving along loving your car... Then out of nowhere that dreadfull sound.... the chime goes "DING !! " Idrive says MALFUNCTION !! .... makes ur heart drop and ur like.. OH **** !! What the HELL ! .. and can practically feel ur wallet open up ... lol!....
Old 02-20-2013, 02:56 PM
Robert A Robert A is online now
Mein Auto: BMW 535d
I found out you could reset the State Inspection and the Emission Inspection service indicators in the iDrive menus.
Robert A
BMWCCA Member
Current
2014 535d, M Sport, Space Gray/Mocha Nappa
Prior
2007 530i, White/Black, 6MT
2001 530i, Orient Blue/Beige, 5MT
1994 325is, White/Black 5MT
1984 325e, White/Black 5MT
1983 318i, Delphin/Beige 4MT
Old 02-20-2013, 03:25 PM
gmcclintock's Avatar
gmcclintock gmcclintock is offline
Maintainin'
Mein Auto: 2006 750Li
Exactly lol
Sent from my GT-N8013 using Bimmer App
<div align=center>
85 Honda Accord(Sold), 93 Lexus GS 300(Gave to lil Bro), 96 Lexus LS 400(Sold)
03 BMW 525i(Traded/Sold), 09 BMW 750Li, 07 BMW 530i, 04 Pontiac Grand AM (Daily Driver), 08 Ford Focus (Wife's Daily Driver)
Old 02-22-2013, 08:37 AM
Phil75070 Phil75070 is offline
Mein Auto: 545i
Went to use navigation in my '05 545i and the street address was too new to come up. So, I put the address in my iPhone using Google Maps. To my surprise, all of the voice directions from Google Maps on my phone came through the car's speakers! I tried it with Apple's Map app and the Mapquest app and neither of them utilize the Bluetooth connectivity to provide turn-by-turn directions through the car itself.
2005 545i, Jet Black, Black Leather, Cold Weather pkg, Logic7, 6 disk changer, Sport Package, Automatic, moonroof, electric rear sun shade, dark wood trim, PDC, Xenon Adaptive lights, Nav, Sat radio, 245/40 ZR18 - 275/35 ZR18 tires, Progman 30.02
Old 02-22-2013, 09:18 AM
legend700's Avatar
legend700 legend700 is offline
Mein Auto: 2008 535i
Good one! Also, whatever entertainment is running, fades out and in to allow the voice instructions to be heard.
Actually, it happened to me last week unexpectedly ( but one time only) while using the Apple app, and took me fully by surprise. I tried to duplicate it, but it never happened again. Did not try any of the other nav apps on my iPhone.
Should work great with the map showing on the iDrive screen. Will try that later.
2008 535i Monaco Blue
PP, SP, SAT w/paddles, ARS, CA, L7,
NAV, PDC, Heated F Seats, SIRIUS,
iPod+Aux, Bamboo Anthracite Trim,
Gray Dakota Leather
Old 02-22-2013, 09:21 AM
st1sj st1sj is offline
Mein Auto: 08 Honda S2k; 09 BMW 550i
Re bluetooth map voice, I found out the Google Maps will work, but not Apple or Waze. I actually find it a little annoying, because Google keeps cutting into my music. In my old G35 with Nav, the music would be turned down while she told me where to go. In my 550 with no Nav, Google just interrupts the music! Is there a way to turn off the bluetooth map voice?
Old 02-22-2013, 11:01 AM
DIY'er
Same thing happened with me! I was pleasantly surprised.
If it ever stops doing it (happens to me if I force the phone to use the built in speaker/mic sometimes), you need to hold the home button to get siri to pop up, then change the output source via the button to the right side of the screen to switch it back to using bluetooth/your car speakers.
Old 03-02-2013, 06:06 AM
NathO NathO is offline
Mein Auto: 07' 530i LCI
Awesome thread! wow at the things I would stumble across most likely months after purchasing! Thanks everyone!
Originally Posted by scriss View Post
I discovered to my chagrin that there's a little warning illustration on my cupholders that instructs me not to use wine glasses in them. Imagine my dismay! What ever will Mimsie and I do on our way to the club!
LMFAO.
Old 03-02-2013, 09:19 AM
DIY'er
i discovered to my chagrin that there's a little warning illustration on my cupholders that instructs me not to use wine glasses in them. Imagine my dismay! What ever will mimsie and i do on our way to the club!
hahaha
Old 04-01-2013, 08:38 AM
MachtSchnell's Avatar
MachtSchnell MachtSchnell is offline
Mein Auto: 2008 535
Or you hear it and get all those feelings and its just the car telling you it's 37 degrees...
Schwarz | Premium | Sport | Nav | Sat | Paddles | PDC | Lead Foot | Hardwired Passport 9500ix w/ Escort Live | Convenience | Matte Grill | JB4 | DCI | ALP Jammers w/BT | smoked side markers | Specdock | rear spoiler | AutoWerke BOV | BMS Oil Catch Can | R1 Cross Drilled Rotors w/ Hawk HPS pads |
