The X5 SAV Forum
Old 02-04-2005, 05:11 PM
Expressx Expressx is offline
Mein Auto: 2012 X5 3.5
BMW CD Changer install question
Just finished installing the BMW CD Changer P/N 82 11 1 469 404 into 2005 X5, Nav, DSP, Premium Sound... Did not work, no sound. Followed the directions exactly.
Instructions said "For vehicles without DSP HiFi connect the 6 pin audio cable to changer. For vehicles with DSP HiFi connect the single coax digital audio cable to the changer (for DSP the 6 pin audio cableneed not be connected)."
After connecting the "optional?" 6 pin connector, it worked fine. ...what gives?
Old 02-04-2005, 05:22 PM
UCrewX5's Avatar
UCrewX5 UCrewX5 is offline
Member of the ® club
Mein Auto: BMW X5
Starting in 03 BMW stopped using the single coax cable and now uses the 6 pin audio cable for both DSP and non-DSP.
Old 02-04-2005, 05:35 PM
Well...that answers that! I'll try and return that cable the parts department was pushing.
Old 02-21-2008, 08:02 AM
dcane1982 dcane1982 is offline
Mein Auto: e90 330i
trouble installing oem cd changer in 2003 x5
I have a 2003 bmw x5 w/dsp and navigation. I purchased a cd changer and attempted to connect it. I connected the 3pin cable and the single coax cable to the cd changer but there is no sound coming out of the vehicle. There is no 6 pin connector in my x5 as i looked for a while. There is no sound coming out from the speakers.
Can somebody please help me on this. I can go through the tracks and the titles appear on the navigation screen but there is no music coming out from speakers.
Old 01-05-2009, 01:24 PM
petertn petertn is offline
Mein Auto: 2007 e60, 2003 e53
cd changer cables
Dcane, did you ever get this answered?can you tell me where your cd chnager cables were located? i open the compartment where my MK$ navigatipn is located but i cannot find my cables.
I also have a 2003 x5 with Nav & DSP
Old 09-24-2010, 01:11 PM
utahbandit utahbandit is offline
Mein Auto: 2001 BMW X5
Cd Install dilemna
decane1982, I also have new CD Changer went through all the cables in the L/h rear and found no 6 pin connector nor co-ax.
Spent 2 hours at local dealer with 3 techs trying to find hook-up cable and no luck.
CD player reads disk title and track no. but no sound.
Would really appreciate info and/or pics on this.
Old 02-12-2013, 02:14 PM
Alika808 Alika808 is offline
Mein Auto: X5 2002
Pre-Harness Pin 6 Connector for CD Changer
This is an old issue for you guys, but it's the same issue for me to installing the I Simple ISBM72 for the iPod. I cannot locate the pin 6 connector at the back left hand side. I have 2002 X5. Does anyone have answer or picture where the pin 6 is? Or any other option use as the audio input for the system since the 3 pin connector is for the control into the radio. I appreciate for your time. Thank you.
Old 02-12-2013, 03:26 PM
There are two three pins cables at the rear of the truck one is for the stereo and the other is for the factory telephone setup. Make sure you are using the one for the stereo and not the phone because although the plugs look the same, they are NOT INTERCHANGEABLE. Using the phone three pin plugs for the cd changer can damage the cd changer. If you don't have the six pin connector in your truck you will need to purchase a DSP converter cable. Both Dice and Grom have this cable.
Old 02-12-2013, 06:06 PM
Mein Auto: X5 2002
DSP Converter Cable
Thanks for your quick response. By the way, do you have idea where I can purchase the DSP converter cable?
Old 02-12-2013, 06:48 PM
Here's the link
http://gromaudio.com/store/accessories/cable-c-dsp.html
Link to instruction on how to hook everything up.
http://gromaudio.com/docs/bmw_dsp_kit_manual.pdf
Similar Threads
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 07:20 AM
1998 M3 = 540i = 740i = 20K rumratt General BMW 36 01-12-2007 06:26 PM
The 2006 Bmw 7 Series tim330i BMW News Articles and Announcements 0 01-27-2005 02:22 PM
Can't get BMW TrafficPro to work with BMW CD Changer H-Town_Blue E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 8 08-18-2002 01:57 PM
