Sparkplug change time - Page 2 - Bimmerfest - BMW Forums
Old 11-01-2011, 05:30 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
I swapped in NGKs for my 328iC and must have over tightened one. Took it to my trusted indy to remove and he replaced them with Bosch. Said the NGKs never did well for him so he always uses Bosch. Charged me less than $200. $285 seems high, but maybe labor in LV, NV is higher than Silicon Valley.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 11-01-2011, 05:42 PM
vegas645 vegas645 is offline
Mein Auto: 2005 645ci convertible
The price of $285 includes a comped dinner Buffet for 2 and a show, that's how we do it here in Vegas!!!
Old 11-01-2011, 06:21 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Originally Posted by petriej View Post
...Charged me less than $200. $285 seems high, but maybe labor in LV, NV is higher than Silicon Valley.
The 6er has 2 extra spark plugs, so that's $40 right there. Plus more labor - 2 engine covers to remove vs 1 and less room by the firewall. My 330Ci plugs were a piece of cake to change.
The general consensus is NGK plugs perform better than Bosch but Bosch last longer. Note all the M cars use only NGK while the lower performance engines typically spec both NGK and Bosch.
lol...
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 11-01-2011, 06:45 PM
petriej's Avatar
$20 spark plugs are a bit tough to swallow, but at shop/dealer rates are probably par for the course.
GGC BMW CCA #443004
Join the BMW CCA!
Old 11-01-2011, 07:39 PM
Zeke77 Zeke77 is offline
Think Solar
Mein Auto: 2008 X3; 2007 650i conv
Question on this topic: Unless I'm missing a few pages (or just blindly missing the obvious, which has been happening more than I'd like lately....) I don't seem to find a specific spark plug change interval suggested in the manual. Where does it say 100k miles? I know we have the on-board service indicator lights, but....I like to keep just slightly ahead of the maintenance schedule if I can.
Here is my exact question: Is the need to change spark plugs driven solely by mileage, or is time also a factor? My 2007 still has less than 40k on it, and I baby it with 90% highway miles. Still, the plugs/coils are now approaching 5 years old. No service lights to date. Do I wait for them to come on, or is it time to pro-actively replace them?
MY2007 650 conv | Stratus Gray | Black Pearl | HUD | Night Vision | Sat | Logic 7 | RT Traffic | Cold Weather | 6-speed Euro Delivery completed 9/15/06
MY2008 X3 3.0si |Monaco Blue| Sand | Sport | Prem | NAV | Auto | Euro Delivery 9/21/07
2004 X5 4.4i (retired)
Old 11-01-2011, 08:26 PM
Yorgi's Avatar
Originally Posted by Zeke77 View Post
... Where does it say 100k miles?....
That comes from the Service and Warranty booklet that comes with the car. You can download a .PDF copy here if you don't have one. The Owner's Manual is also available on that site.
Here is my exact question: Is the need to change spark plugs driven solely by mileage, or is time also a factor?...
It's strictly mileage, time has no effect on the condition of the plugs. That being said, if your car is not running well (eg: misfires caused by bad sensor, running on cheap gas, oil leak) then the plugs can be damaged after a few thousand miles.
'04 M3 - track
Old 11-01-2011, 09:08 PM
Think Solar
Ahh, yes....thanks Yorgi. I have the Service & Warranty booklet and found it on page 6. I was looking at the manual only. Thanks for the tips.
Old 11-01-2011, 10:02 PM
Bmwaudivwdude Bmwaudivwdude is offline
Big Mike Brown
Send a message via AIM to Bmwaudivwdude
Mein Auto: 09 BMW X5/11 Audi A5
The plugs are not that hard to change.
1. Remove the cabin filters and the housing.
2. Remove the top engine cover
3. Remove the side engine covers,
Passenger side
4. Remove the 2 each 10mm nuts on the power steering tank (lift to move out the way and disconnet sensor on the bottom)
5. Remove the 2 torx screws on the coolant tank (lift and move out the way and disconnect the sensor on the bottom).
6. You can access the rear plug on the passenger side by removing the plastic cover under the wiring harness 3 each 10 mm screws
7. Remove the 2 each 10mm nuts on the A/C lines. Slide the line off the 2 side post and push it down while removing the rear plug. Use a handle on a hammer to force it down.
As for the driver's side,
8. Disconnect the battery 10 mm nut (negative side)
9. Remove the grey plastic nut on the drivers side holding the protective cover for the battery cable to the side wall.
10. Disconnect the two battery cable from the terminal. This will give you the clearance to remove the rear coil. Just remember there is only 3 milimeters of clearance to remove the rear coils, ensure the tops are closed, and ensure the part of the coil that opens out is facing the rear of the engine when removing.
About two hours total time I have did this job on 3 BMW 645s and 1 BMW 545.
11 Audi A5 2.0T 8 Spd Tripotronic w Sport Pkg, 19" Anthracite Wheels
12 VW CC 2.0T [/B] stock
05 VW GTI 1.8 T 5 Spd, Coilovers, Big Brakes,
(Previous rides)
04 BMW 645 CiC Auto
97 VW Jetta Jazz 5 SPD
06 Mazda 6 Grand Sport Auto
05 BMW X5 3.0 6 SPD
05 Infiniti G35 6 SPD
04 Volvo S60 "R" 6 SPD
99 Nissan Maxima 5 SPD
91 Nissan 300ZX 5 SPD
92 Honda Prelude Si Auto
76 Fiat Spyder 124 5 SPD
Old 11-02-2011, 03:59 PM
pmathis pmathis is offline
Mein Auto: 2004 645CI
I like this post and I think I'll give this a try. 110k miles so its way past due. How do I GAP the plugs and is there anything else I should know before diving in. I'm pretty handy but I've never done this.
Old 11-02-2011, 04:40 PM
Yorgi's Avatar
Thankfully they are pre-gapped. You just open the box, put on a little bit of anti-seize paste on the threads and screw them in.
'04 M3 - track
Old 11-02-2011, 08:32 PM
Big Mike Brown
Put anti-sieze on the plugs.
Always install the plugs by hand ( to prevent cross-threading)
If you do not have a torque wrench, after tightning by hand, tighten with a wrench another 1/8th of a whole turn and you should be good.
Note: ensure you have a extension that will reach the plug. After removing the first coil, check then. I tape the socket and extension together to keep them from seperating, while pulling the plugs out or after tightning the plugs.
(Previous rides)
04 BMW 645 CiC Auto
05 BMW X5 3.0 6 SPD
Old 11-03-2011, 09:05 PM
hipertec hipertec is offline
Brown, thank you for the steps. If u end up doing another 6, we all would love ifyou did a pic DIY.
Sent from my Transformer TF101 using Bimmer
2005 BMW 645ci - DPE 3pc Forged Rims, Coilovers, Britalman full cat-back exhaust system, , K&N Air Filter, LUMMA Roof & Trunk Spoiler.
Old 11-05-2011, 08:05 PM
Tosh.645ci Tosh.645ci is offline
Mein Auto: Bmw 645ci
I use pulsestar plugs... They're not oem, and a bit pricey but they come highly recommended from those I know who used them. Do a search... There's some interesting reading on them.
Old 11-14-2011, 05:38 PM
Blaknificent Blaknificent is offline
Mein Auto: '05 Black Sapphire 645ci
Hey Yorgi!
I was resetting the oil light and accidentally reset the sparkplugs to 15K....what is the proper mileage spark plugs should be set at? I just had all coils and plugs replaced 6k miles ago...
Thanks!
Old 11-14-2011, 05:42 PM
Big Mike Brown
100,000 miles
(Previous rides)
04 BMW 645 CiC Auto
05 BMW X5 3.0 6 SPD
Old 11-14-2011, 05:45 PM
Thanks! I got it reset. I love this forum.
Old 11-14-2011, 06:33 PM
EmM HoLLa EmM HoLLa is offline
Mein Auto: BMW
So is there a consensus on when to actually change the plugs?.. 100k?.. Or sooner?..
Old 11-14-2011, 06:38 PM
petriej's Avatar
It's huge, like 50k or something.
GGC BMW CCA #443004
Join the BMW CCA!
Old 11-14-2011, 07:55 PM
ProRail ProRail is offline
"Clunker" *****
Mein Auto: 1999 BMW 528A-220K-traded
Sounds pretty cheap to me, unless you change every 20K. (Even then it's not that bad.)
Old 11-14-2011, 08:46 PM
Big Mike Brown
I used the Bosch Iridium Plugs $8 each vs $20 each for OEM plugs.
(Previous rides)
04 BMW 645 CiC Auto
05 BMW X5 3.0 6 SPD
Old 11-14-2011, 08:49 PM
Yorgi's Avatar
The problem is not the overall cost, it's the fact that BMW charges 130% more than your average retail for these plugs. Paying $100 more for 8 plugs at the dealer vs online is a little annoying.
'04 M3 - track
Old 11-15-2011, 03:50 AM
645/333's Avatar
645/333 645/333 is online now
Michael
When I changed my plugs and reset them the idrive reset changed to 75000 miles. I did the procedure correctly so I think that this must be the mileage the plugs are set to for my car. If you look at your vehicle service data you will see the condition based mileage numbers for each item, ie plugs oil, filters etc.
The interesting things was my plug interval dropped very quickly to 67000 miles and I have not driven more than 3k from when I first installed them.
There are the recommended change windows for each vehicle (in the vehicle/service data in the idrive) and will not be the same for every car as we all drive them differently.
I know that many ignore these numbers and prefer to change when they feel the need, especially oil intervals.
I personally like to keep my car operating within what I feel is the optimum window so will definitely change some things a lot earlier, brakes! plus plugs being one of them which I did change at 50K. Lets bear in mind that this could equate to 5 years driving ie one set of plugs in 5 years.....
Old 02-12-2013, 01:48 PM
reytran's Avatar
reytran reytran is offline
Nothing quite like a 6
Mein Auto: 09' 650i Cabrio
But besides the Strip, rest of the city cost of living is pretty fair compare to California. I stayed there for a month before. There is 1 thing annoy me the most is I can't find a carwash, where there is more carwash than 7-Eleven here. It was fun staying in Vegas though.
Btw, I will try to call some Indy around my area to check the price for sparkplug change. It sounds like I'm not for DIY this then.
2009 BMW 650i Cabrio (daily drive)
2011 Audi A4 (groceries, bully, road trip, winter beater, family car)
BMW CCA ID: 473647
Old 02-12-2013, 06:28 PM
Big Mike Brown
When I changed my plugs and reset my 645 iDrive. It reset to 100,000 miles.
(Previous rides)
04 BMW 645 CiC Auto
05 BMW X5 3.0 6 SPD
Old 03-18-2014, 08:37 PM
DrPsyber DrPsyber is offline
Mein Auto: 2006 E63 650i
Part # please
Do you mind posting the part number for the spark plugs that worked for you?
I do see that the +4 works the best, but I am having a hard time finding the correct part #
