Cold Starts - No power - Bimmerfest - BMW Forums
Old 02-12-2013, 04:52 PM
Calum G Calum G is offline
Mein Auto: 2001 316i E46 1.9 M43
Hi guys,
I'm looking for help as to why when I start the car I'm getting next to no power when the engine is cold. I know it wont perform properly when its cold but this feels seriously lacking, the problem being I'm an on call firefighter so sometimes the car needs driven hard at 3 in the morning when the engine is totally cold and cant be given time to warm up.
Its a 2001 316i, its petrol too so I didnt expect this sort of problem, on my last one (exact same car) I didnt encounter this.
Any help would be much appreciated,
cheers
Calum
Old 02-12-2013, 05:17 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Driving this car hard at cold temps is a great way to grenade the motor. If you must drive in the manner you describe you need to find an old pushrod engine without overhead cams. You are going to starve the top end for oil and BOOM!
Old 02-12-2013, 05:44 PM
Cheers lol but its worth wrecking a motor to save lives haha any suggestions on how i could improve the cold performance without buying a different car?
Old 02-12-2013, 05:49 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Don`t be stupid, take the advice you`re getting here to heart ! What good will you be sitting broken down on the side of the road while Rome`s burning ???
You need a more appropriate vehicle for your job....this AIN`T it !
The road goes ever onward....
(R.I.P. Jever)
Old 02-12-2013, 05:50 PM
what would you advise? an old escort haha top notch motors
Old 02-12-2013, 06:35 PM
bmw330ci04's Avatar
bmw330ci04 bmw330ci04 is offline
Mein Auto: 04 330Ci 6 Spd, 07 335Cic
engine block heater? if possible?
Old 02-20-2013, 01:30 PM
ChipD95613 ChipD95613 is offline
Mein Auto: 325xi, 528i, 535i, 9000
You need 0w synthetic oil if you are going to go at it that hard, that fast. The engine is still going to get chewed up faster than normal if you abuse it like that, though. Overhead Valve engines are better for drivers who insist on abusing their engine at low temperatures. BMW doesn't do that, however.
Do you have an automatic? They work by pushing the car along with hydraulic pressure, which isn't available in abundance when the fluid is thick and cold. A stick shift with the right fluid will perform much better much quicker than an automatic will.
Block heaters will make a difference if you have a stick, but it most likely won't heat up your transmission fluid sufficiently if you have an automatic. They do cost ~$2 a night in power, FYI.
Old 02-20-2013, 04:15 PM
aye its a manual man, thinkn the 0w oil sounds like a good plan, cheers think the throttle body needed cleaned as well coz it was stickin a bit bt didnt make a huge difference. Block heaters a good idea haha thanks for the help!
Old 08-11-2013, 04:49 PM
Just a follow up to this it turned out to be a bad cam sensor and MAF, also had a vacuum leak from secondary air pump. Iv changed the sensors n air pump been sorted n its runnin top notch
cold, help advice needed, help advice newbie, no power
