Violent Steering Shake, Shudder & Movement
Hey all,
I'm dealing with a pretty bad steering wheel shake as of last week. I was driving home and the wheel went ballistic and started to just shake back and fourth (so I thought). I pulled over and looked around, didnt find anything obviously broken so I limped the car home. Fast forward to last night, I got the car up and started inspecting the CABs, ball joints, and tie rod ends. Everything looks kosher, nothing broken or destroyed. My axles look fine too, the outer boots are ripped but that wouldn't cause any of this wobble. I also shook the car down, to try and hear any play and I can't hear anything. My guibo is going bad because I have a little clank in the steering wheel itself. I took it for a little drive after and here is exactly what it does: About 20mph the steering wheel will auto pull to the left as it shakes. It goes little by little until the wheel is half way turned. You can fight it back and drive the car straight but if you let off, it just pulls and turns itself. The only thing I can think of is the steering rack, any ideas? |
sounds like typical rear control arm bushings.
What you said, first thing that comes to mind is a bad steering rack.
http://www.luxury4play.com 2004 Maserati M128 GT 2000 3-series BMW supercharged Because race car.
Did you check your P/S fluid? Is it fresh or is it old and runny? Is there shavings in it?
Also worth checking is brake calipers. My wife's Jeep had a caliper seize up and it pulled hard left too (it was drivers side caliper). I was able to make it go straight when you hit the brakes (because the other side would engage and cancel out the pulling. Not saying that is your issue, but worth looking at. |
A sticking brake caliper is also my first guess. I had the same violent shaking on my front passanger wheels. Carefully check if that wheel is hot to the touch next time it happens.
Another vote for the brake caliper.. My son's E30 had the same thing, just a few weeks ago...
2006 330Ci ZHP Imola Red 1987 325iS Bronzit (retired) 2011 Z4 Space Gray (retired) 2008 X3 Sapphire Black (retired) 2005 330Cic Silver-Gray (retired) 2003 325i Sport Steel Blue (retired) 1967 2000CS Delphin Gray (retired) |
