E46 (1999 - 2006)
Old 02-11-2013, 05:54 PM
TacoBuster's Avatar
TacoBuster TacoBuster is offline
Mein Auto: 2003 325Ci Conv
Help coolant..!!
So heres the deal.. Ive checked every single hose.. O-rings.. Checked my expansion tank. And my water pump. Everything is in top shape. Yet my coolant leaks a bit when topped off. Bled it 3 times and refilled.. Stops leaking and after three days.. Leaks again.. I dnt know wat to do.. Should i just change out everything?
Old 02-11-2013, 05:59 PM
TacoBuster's Avatar
Btw 03 325ci vert
Old 02-11-2013, 06:03 PM
QAfred QAfred is offline
Mein Auto: 328i, 330ci, R1200C
NO, you are missing the leak...sometimes it is so small it will only leave dried up (usually white spots) where the coolant is leaking from. I had a WP that was leaking this way, I never found it while inspecting it, but when I pulled the pulley it had dry white stains on it. Pump seemed okay, but fragged a month later since it had a tiny leak at the bearing, apparently.
Also, there are two O-rings that seal the lines going to the tranny cooler, just under the radiator, check them for minor leaks.
I have also heard of ET's that would not show any sign of leakage until engine was hot- so look for dry white specks. Also, since I park in the garage, I can always smell when I have a coolant leak, finding it is sometimes the fun part.
Old 02-11-2013, 07:56 PM
TacoBuster's Avatar
Thats the first thing i did.. Check for white spots and near the tranny and pulley area.. Im checking every 5 to 10 min to check for leaks but so far nuthing
Old 02-11-2013, 08:10 PM
How many miles are on the car?
How long have you had it?
Do you know the last time the WP, Thermostat, Expansion Tank, upper / lower rad hoses were changed?
http://www.oembimmerparts.com/produc...oolrefrkit.htm
If all else fails you may need to have a leak down test accomplished to ensure you do not have a tiny head gasket leak and are blowing it out the exhaust-rare, but possible.
Old 02-11-2013, 08:16 PM
halltristan's Avatar
halltristan halltristan is offline
Bimmer Enthusiast
Mein Auto: 325i and X3
You need to have a pressure test done. You're probably checking for a leak when the car is cooler, which is understandable so you don't burn the **** out of yourself. However, a small leak may not actually leak until the coolant system is pressurized. Go to a local mechanic and have it done. It shouldn't cost more than $20 and it will provide definitive results.
Member No. 470379
Old 02-11-2013, 09:12 PM
Mein Auto: '04 330Ci 6-speed
Don't overlook the radiator leaking. Happens around the seal at the edges, metal to plastic.
How old is your rad?
Old 02-12-2013, 06:45 AM
vandyboy vandyboy is offline
Mein Auto: 01 325i automatikgetriebe
I had a problem losing coolant and had a pressure test done. The expansion tank was the culprit, although I could not find a leak when examining it. Later on, I had to replace the bleeder screw, but you would have noticed dried white coolant on your top hose.
Old 02-12-2013, 09:29 AM
TacoBuster's Avatar
So i got the car checked. The bleeding screw on the expansion tank is the problem. Should i just replace the expansion tank? I dnt know when was the last time it was replaced. Or if it was ever replaced
Old 02-12-2013, 09:49 AM
TacoBuster's Avatar
And to top it off.. I went to the store after. Parked my car away from all the other cars and yet someone still managed to hit my car. Not a major hit but its really noticeable.
Old 02-12-2013, 10:23 PM
Bad enough so I'd curse not catching them. Probably drunk.
Unless expansion tank looks close to new, best to replace. How's the rest of the cooling system?
I use the brass replacement bleeder screw to avoid running into any problems that the plastic oe causes. Looks nice too.
Old 02-13-2013, 11:21 AM
TacoBuster's Avatar
I cleaned up the engine and everything so it all looks new. Lol but i think im just going to replace it so that i know its good. Where did you get the brass bleed screw
