Old 02-12-2013, 06:56 PM
JULES747 JULES747 is offline
Mein Auto: Z4 3.0si
Aux IPOD kit Install 2006 Z4
Looking at installing the Ashtray style Radio Auxiliary kit (part number 82 11 0 142 174 ) to play my newly aquired IPOD.....It sounds like a simple plug and play set up, apart from the stress of removing the air vents.....My question is, will the fact that I have the factory fitted CD changer fitted together with factory fitted Blue tooth effect the simplicity of plug in and play or is there a load of wire splicing to be done?. ......Thanks in advance.
Old 02-12-2013, 08:31 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
http://www.bimmerfest.com/forums/sho...highlight=ipod
Old 02-12-2013, 10:02 PM
DaleWA DaleWA is offline
Mein Auto: 2004 Z4 3.0i/2011 X3 35i
Buy the much cheaper E46 aux-in from South Motors on Amazon and ask them for instructions for the Z4 plug. http://www.amazon.com/gp/product/B00...ls_o04_s00_i00
That's what I did. I'd post the pdf of the z4 plug connector but I can't find it on my PC. You remove the pins from the aux-in plug and reinsert into them into the existing connector on the back of the radio (at least for my unit with Nav). I just drilled a hole for the plug in the panel under the dash where the aux-in is located on 2007 & later Z4s.
2004 Z4 3.0i / 2011 X3 35i
Old 02-13-2013, 12:35 AM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
Welcome to Bimmerfest!
As a newbie you should acquaint yourself with the Search function, found on one of the bars above. Also, and I hate to say it, be aware that there is far more info for Z cars on Zpost than on Bimmerfest.
Short answer to your question is no, having the CD changer and the factory Bluetooth will not affect the simplicity of your plug and play although you may have to pull some pins and re-insert them in the existing connector. The ashtray adapter is a rather poor implementation though because you have to give up your 12V port, so it's probably better to just drill a hole in the center dash trim below the radio for the AUX input jack. The AUX input for the Mini is even cheaper than the E46 AUX input and they're exactly the same thing.
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
